Local Time 22:01 24 Oct 2026 Privacy Policy
Forum Index : Solar : Grid connected inverter off grid
     Page 11 of 11
renewableMark
Posted: 08:42am 21 Jan 2018
I have seen a few that would make it worth it.
Cheers Caveman Mark
Off grid eastern Melb
renewableMark
Posted: 07:36am 23 Jan 2018
  Madness said   This is what I have.
The link you included has a very basic iron by the look of it, the SMB hot air rework station is great if you are doing a lot of surface mount stuff but chances are it would collect dust and not much more.
Tinker the link I posted is just flux not solder paste.
That link doesn't work, is this clone ok?
Cheers Caveman Mark
Posted: 08:00am 23 Jan 2018
Yeah thats it, I would get spare tips and a couple spare elements while you are at it. The tips you will need so you have a range of sizes, best to have spare elements on hand because if you don't it will fail when you need it most, they cost next to nothing anyway.
Boppa
Posted: 10:26am 23 Jan 2018
They are a good little unit, I bought a second replacement handpiece as well, its got a bigger chisel bit in it, and the one that came ith it has a much smaller tip for surface mount stuff- I found it meant swapping tips for soldering wires etc, and after burning myself a couple of times, I got the replacement handle for about $7 off alibaba, now I just swap irons instead
     Page 11 of 11
