Local Time 18:37 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Unix on the Pico Computer 3
     Page 10 of 10
Bleep
Posted: 05:08pm 10 Sep 2026
Hi Peter,
Thanks for the explanation about THUMB_BUDGET & BCODE_ONLY, I have now got PETSCII running, though I still wonder if I'm not doing something wrong as I'm seeing a much greater slow down than 2.7X if I use BCODE_ONLY, I'm seeing about 10X slower?
Also thanks for the pointer about the Frame bufferlayers, I forgot that Fuzix effectively uses the LCD model for layers. :-(
I have also been looking at problems I am having using Vi.
First thing I have found is that if I use Tera Term, Vi seems to behave well, but If I use just a USB keyboard and a HDMI monitor I have problems.
1. Vi doesn't work in Mode 1, it only uses the top half of the screen, and then does not scroll when the cursor gets to the last line of the file as displayed on the screen, that last line changes as you scroll down further, but the lines above it do not move up.
2. when using the monitor, in Mode 2 the first line of a file is missing, this puts all subsequent lines 1 line too high, so for example if I scroll down to a line and do yy (yank line to buffer) then immediately do p (put line(s) in buffer at cursor) the line that is inserted is not the one I (appeared to) copy from the screen, the inserted line also gets put in apparently the wrong place, so things now start to get very confusing, if you redraw the screen, I do it with G followed by 1G (go to end of file, go to line 1 of file) the positioning of the line is now corrected, but it is still not the line I yanked.
This is a poor explanation, if you have both a terminal and a monitor going side by side it will become obvious.
Getting Mode 1 would be nice, more screen area, but not essential, but getting it working in Mode 2 would be a nice minimum. Thanks.
Regards Kevin.
Edited 2026-09-11 04:07 by Bleep
Arne
Posted: 10:44am 11 Sep 2026
Hello,
I have connected an US keyboard and have the following problem, when I press the @ character I get “ and vice versa.The keys seem to be swapped ?
Any idea?
Arne
Posted: 11:39am 11 Sep 2026
It looks like the US and UK settings are swapped. What do you get on Shift-3?
Posted: 11:49am 11 Sep 2026
US keyboard.
Shift   ~!@#$%^&*()_+
Normal  `1234567890-=
Posted: 12:00pm 11 Sep 2026
UK keyboard (mine anyway!)
¬!"£$%^&*()_+
`1234567890-=
Arne
Posted: 12:55pm 11 Sep 2026
On Fuzix:
°1234567
Printed on keyboard:
`1234567
Posted: 01:00pm 11 Sep 2026
The keyboard defaults to UK.  To get the US layout enter:
picoctl keymap us
The picoctl command can set the keyboard to a variety of layouts including us uk de fr es be.  When you have got used to the editor in Unix you can add the picoctl command to the file /etc/rc and the keyboard will then be automatically configured when you login as root.
Arne
Posted: 01:26pm 11 Sep 2026
With your hint: picoctl keymap us its o.k.
Thanks,
Arne
ville56
Posted: 10:29am 16 Sep 2026
If someone needs to transfer files from the Pico running Fuzix to e.g. a PC it can be done easily with the FUZIX webserver and a curl command on the PC side (Linux shoud do as well, of course).
- Start a webserver in the file system root (e.g. "cd /" -> "httpd 80 &")
- and at the PC in a terminal window type e.g.
 "curl http://pc3_ip/root/MMBasic/eclipse.bas > exclipse.bas"
 where pc3_ip is the IP or DNS-name of the FUZIX node.
This transfers the file eclipse.bas in /root/MMBAsic from Fuzix to the host system.
Binary files probably must be uue encoded before transfer, but haven't tried it. At least the filesize is the same on both ends also with binary files. Didn't check if they are byte-identical.
The transfer is lightning fast and no need to swap SD cards. Unfortunately the webserver does not understand POST or PUT requests, so no transfer from PC to FUZIX the same way.
Gerald
73 de OE1HGA, Gerald
Posted: 10:40am 16 Sep 2026
Also, if you replace the sd image with the one from github it now includes a tftp server which will transfer files very fast
ville56
Posted: 11:01am 16 Sep 2026
Peter,
if you mean from https://github.com/UKTailwind/FUZIX/releases/tag/pc3-v0.27 I can't find a tftp server binary ...
where should it be in the directory tree?
Posted: 11:49am 16 Sep 2026
Should be there now
ville56
Posted: 02:20pm 16 Sep 2026
Thank you Peter, perfect !!
ville56
Posted: 02:30pm 16 Sep 2026
btw, DIG delivers garbage ...
# dig router-1
qust: 1, ans: 1, ns: 1, add: 3
questions:
router-1.
answers:
router-1.              A     0.254.192.12
authority:
additional:
the IP should be 192.168.0.254
ville56
Posted: 03:36pm 16 Sep 2026
Peter,
tftpd makes the system instable, tending to panic. I can reproduce it with
wifi -f
tftpd / &
man setdate (several times)
and the system panics with
panic: validblk: invalid blk
Without tftpd running there is no tendency to panic.
Gerald
ville56
Posted: 07:26am 17 Sep 2026
there seems to be a bug in ntpdate:
ntpdate does not take any of it's arguments (-o -O) to set the timezone one lives in. It always uses UTC. Also -p -d -s are not obeyed. From what I can see in the source, these params should be usable.
Gerald
Posted: 10:29am 17 Sep 2026
V0.28 is now available on https://github.com/UKTailwind/FUZIX/releases/tag/pc3-v0.28
Fixes a nasty kernel bug and a bug in the sdcard image causing the system panics
Note: command line parsing in Unix 7 is not as flexible as modern Linux - see the manual for correct ntp usage.
You are highly recommended to move to this release with a newly imaged sdcard.
ville56
Posted: 01:37pm 17 Sep 2026
Thanks Peter.
It is running now rock-solid as far as I could test it. Great work and I really pull my hat as an answer to your reaction time and expertise in the analysis!!!
Gerald
P.S. DIG still produces garbage, but not an issue atm.
     Page 10 of 10
