Local Time 07:32 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : speed tests
Posted: 02:37pm 20 Jun 2017
could someone please run the following code on various micromites and report the times returned:
Print "Sieve of Eratosthenes Speed Test"
Start = Timer
10 W=500:Dim F(W):P=1:A=3
20 F(P)=A:P=P+1:If P>W Then GoTo DONE
30 A=A+2:X=1
40 S=A/F(X):If S=Int(S) Then 30
50 X=X+1:If X<P And F(X)*F(X)<=A Then 40
60 GoTo 20
DONE:
Print (Timer-Start)/1000
so far: MX170 @ 40MHz reports 5.31 seconds.
i'm intetested in getting the results for MX470, MZ, RPi zero, and RPi 3.
rob :-)
Posted: 04:45pm 20 Jun 2017
E100 MM+ 470 @ 100MHz = 2.958
E100 MM+ 470 @ 120MHz = 2.462
Edited by Grogster 2017-06-22
Lou
Posted: 05:42pm 20 Jun 2017
Rob,
I ran your program on a Grogster SkinnyMite board with an MX470F512H chip, version 4.6b++b16 software, CPU 40, all old stuff. The result was 7.282 (CPU 80, result 4.097)
I also ran it on an MX150F128B version 4.5 Beta 10 software, CPU 40, result 6.857
Even older stuff (I know, a 150 who cares) but I had it handy and ran it.
Lou
Edited by Lou 2017-06-22
palcal
Posted: 05:50pm 20 Jun 2017
E100 MM+ 470 @ 100MHz = 2.972
MMX @ 200 MHz = 1.121
Paul.
jman
Posted: 05:51pm 20 Jun 2017
Hi Rob
PiZero (not w)
Jman
led-bloon
Posted: 06:41pm 20 Jun 2017
Hi Rob
Raspberry Pi B+ v1.2: 0.666
Raspberry Pi 2B v1.2: 0.221
(running off 8GB USB Flash drive)
Raspberry Pi 3: 0.217
Of course, it varies on whether the Pi's are being over-clocked
[My Pi 2 & 3 are throttled to 1 GHz: not the fastest kids on the block!]
Rgds
don
Edited by led-bloon 2017-06-22
Miss you George
Posted: 08:17pm 20 Jun 2017
do you know what clock speed the B+ is running at? i believe the default should be 700MHz from what i can see online.
rob :-)
led-bloon
Posted: 09:23pm 20 Jun 2017
Raspberry Pi B+:
1GHz arm
core freq=500MHz: sdram freq=600MHz: over volts=6: gpu mem=128
Rasbian wheezy
Miss you George
Posted: 09:38pm 20 Jun 2017
Pi zero W
0.63
Pi 3 Model B V1.2
0.185
MMX 252MHz
0.934
Phil23
Posted: 12:33am 21 Jun 2017
I think I have the record!
Is this cheating?
Phil23
Posted: 12:39am 21 Jun 2017
Sorta makes the Pi 3 look pretty impressive Vs the 2.4Gig Core i7 with 16Gigs.
And a bit more than the $60.00 price tag.
Phil.
Posted: 03:11am 21 Jun 2017
there does seem to be quite a variation in what different people are seeing on the same RPi hardware. i'm guessing this is caused by clock tweak differences, and perhaps even power quality (if a RPi detects sagging power it seems to throttle back the clock to reduce current draw).
peter: are all your RPi's running at the standard out-of-the-box clock rate? that is 1GHz for the zero, 1.2GHz for the 3.
jman: your RPi zero seems much slower than peter's RPi zero W, is it doing anything else at the same time that might be slowing it down?
btw, i'm wanting the numbers for a speed comparison chart in a magazine article. the article will be mostly about the MX170, but i'm keen to include a couple of the RPi results for speed comparisons. results for several 1980's machines will also be included.
here are the results so far plus the 'historic' figures from the net:
How Fast Were Those Late 1970s Home Computers?
8-Bit Home Computer Benchmarks
computer model clock CPU time lines/sec
TRS 80 model I with Level II Basic 1.77 MHz Z80 421 s 378
Sinclair ZX Spectrum +3 3.55 MHz Z80A 388 s 411
Tandy 102 2.40 MHz 80C85 367 s 434
Atari 130XE (Atari BASIC Rev. C) 1.79 MHz 6502C 338 s 471
Atari 800XL 1.80 MHz 6502 316 s 504
Tandy 64K CoCo 2 0.90 MHz 6809E 271 s 588
Commodore Plus/4 1.80 MHz 8501 267 s 597
Sony F1XV MSX2+ (MSX Microsoft BASIC 3.0) 3.58 MHz Z80A 260 s 613
Commodore C64 1.00 MHz 6510 254 s 627
Commodore VIC-20 (Microsoft BASIC 2a) 1.00 MHz 6502 234 s 681
TRS-80 Micro Colour Computer (MC-10) 0.90 MHz 6803 220 s 724
Apple IIe Enhanced (Applesoft II) 1.00 MHz 6502 211 s 755
Sharp MZ-731 4.00 MHz Z80A 182 s 875
Commodore 128 2.00 MHz 8502 152 s 1048
Tandy 64K CoCo 3 1.79 MHz 809E 147 s 1084
Amstrad CPC464 4.00 MHz Z80A 140 s 1138
Acorn Electron 2.00 MHz 6502 138 s 1154
BBC Model B (BBC BASIC 2) 2.00 MHz 6502 101 s 1577
BBC Master (BBC BASIC 4) 2.00 MHz 65SC12 76 s 2096
Micromite MX150 40 MHz mips M4K 6.86 s 23232
Micromite MX170 (Mk II) 40 MHz mips M4K 5.31 s 30000
Micromite MX470 (plus) 100 MHz mips M4K 2.96 s 53854
Micromite MZ2048 (extreme) 200 MHz mips M 1.12 s 142105
MMbasic on RPi Zero (JG) ARMv6 0.89 s 178387
MMbasic on RPi B+ (DH) ARMv6 0.67 s 239189
MMbasic on RPi Zero W (PM) ARMv6 0.63 s 252857
MMbasic on RPi 3 (DH) ARMv8 0.22 s 734101
MMbasic on RPi 3 (PM) ARMv8 0.19 s 861081
MMbasic for WIN32 2400 MHz i7 0.06 s 2569355
rob :-)
Posted: 03:20am 21 Jun 2017
  Quote  peter: are all your RPi's running at the standard out-of-the-box clock rate? that is 1GHz for the zero, 1.2GHz for the 3.
Yes
Note that my Pi zero is a "W" jman's isn't - don't know if this makes a difference. I'm running Raspbian Jessie Lite on the W (no GUI). - full Raspbian Jessie on the Pi 3
isochronic
Posted: 11:06am 21 Jun 2017
I am a bit surprised at the '170 time, it should be faster I think.
I copied a sieve-of-eratosthenes [from a page of Peter M. Maurer], bodged
it a bit to match my f77 interpreter, on a '170 at 50MHz it takes about half a second, including printing the list of 95 numbers.
Phil23
Posted: 03:04pm 21 Jun 2017
Hi Rob,
Just couldn't resist trying it....
Had to power up my old AMD Athlon 1200 that's been parked under the front bench.
Think it's been retired for around 11 years.
0.251 is the best I see.
Put's it in amongst the rPi's.
DOS MMbasic 4.5 of course.
Phil.
twofingers
Posted: 04:26am 24 Jun 2017
  chronic said   I am a bit surprised at the '170 time, it should be faster I think.
Just outta curiosity: which "list of 95 numbers"?
Printing a list of 500 numbers takes on my MM2 (48 Mhz, MMBasic 5.1, 38400 Baud ) 0.6s.
Start = Timer
For i = 1 To w:Print f(i);:Next
At 115200 Baud takes it 0.2s.
This code
  Quote  CPU 48
Start = Timer
30 A=A+2:X=1
50 X=X+1:If X<P And F(X)^2<=A Then 40
60 GoTo 20
DONE:
takes 3.8s.
MichaelEdited by twofingers 2017-06-25
Posted: 01:15pm 24 Jun 2017
the below provides a more complete set of results, including counting the number of statements and lines. the core bit of code is exactly the same as posted on the net here:
http://www.retroprogramming.com/2010/01/8-bit-home-computer-benchmarks.html
rob :-)
Print
Start = Timer
30 A=A+2:X=1
60 GoTo 20
DONE:
Elapsed = (Timer-Start)/1000
Print Elapsed " seconds"
Print
I = 0 ' statement counter
J = 0 ' line counter
Erase F
110 I=I+4: J=J+1: W=500:Dim F(W):P=1:A=3
120 I=I+3: J=J+1: F(P)=A:P=P+1:If P>W Then GoTo FINI
130 I=I+2: J=J+1: A=A+2:X=1
Print ,P Chr$(13);
140 I=I+2: J=J+1: S=A/F(X):If S=Int(S) Then I=I+1: GoTo 130
150 I=I+2: J=J+1: X=X+1:If X<P And F(X)*F(X)<=A Then I=I+1: GoTo 140
160 I=I+1: J=J+1: GoTo 120
FINI:
Print I " statements"
Print J " lines"
Print
Print I / Elapsed " statements per second"
Print J / Elapsed " lines per second"
Print
> run
5.403 seconds
48122 statements
19747 lines
8906.53 statements per second
3654.82 lines per second
Edited by robert.rozee 2017-06-25
isochronic
Posted: 05:51pm 24 Jun 2017
I guessed it produces the prime numbers under 500 ?
(or is it the first 500 prime numbers ?- I probably made a mistake )
Posted: 06:42pm 24 Jun 2017
Anything that contains a PRINT statement is not measuring the speed of the processor but the speed of the output device.
twofingers
Posted: 06:51pm 24 Jun 2017
  chronic said   ... I probably made a mistake )
You did!
Best regards
Michael
