Forum Index : Microcontroller and PC projects : Micromite Firmware Update V5.04.04
Unfortunately the last version of the Micromite firmware (distributed only 5 days ago) contained a number of serious bugs. Most of these have been reported in other threads and a huge thanks to the guys who went to the trouble of documenting and reporting them. MMBasic is getting so complicated now that it is very hard to test everything. In the past I relied on an automated script for testing but with things like LCD display panels, embedded programs, support for sensors, etc their testing cannot be automated and it is impossible to try every variation. I suppose that this means that the bugs will keep sprouting with every change. You can download the new version (V5.04.04) which from http://geoffg.net/micromite.html (scroll to the bottom of the page). In summary the bugs fixed are: • Fixed: The TEXT and GUI CAPTION commands could cause out of memory errors. • Fixed: Embedded display drivers would lose their configuration when a program was run. • Fixed: The LOAD command would generate an out of memory error (MM+ only). • Fixed: XMODEM could not read or write from an SD card file (MM+ only). • Fixed: Corrupted +-= symbols in font 6 (MM+ only). More details are in the Change Log which is included in the firmware download. There has been no new functionality so the manuals remain essentially unchanged. Geoff Geoff Graham - http://geoffg.net |
Now that's Murphy's law if I've ever seen it! I'm reading the above, while the CGMicro64 is in my lap being flashed from 5.04.02 to 03 for a few tests. Just jumped over for a look. Guess it's still plugged in, so good to go again!. Cheers Phil. |
What a pity that the SELECT CASE statement is deemed non essential in the Lite version. I guess it is just an opinion just like mine. Mine is that SELECT CASE is very essential because it saves a lot of space compared to nested and or large number of IF statements. Also maintainability is with SELECT CASE a lot better. I don't even have a single program that does not use it, as most use a kind of 'state machine' which is very straightforward when using select case and really obscure using other statements. Did it use that much memory to validate its removal? Microblocks. Build with logic. |
+1 |
| PicFan Senior Member Joined: 18/03/2014 Location: AustriaPosts: 133 |
Please, could someone try this? MM.Ver = 5.0404, Micromite+ PRINT FIELD$("aaa,bbb,ccc", 2, ",") ERROR: Expected a number Thank you ! Wolfgang |
Got the same result here. I had other code loaded & didn't erase it, just went to a prompt & typed the above. While I was at the prompt, I also tried:- [code]Dim String Stuff Stuff="aa,bb,cc" Print Field$(Stuff,2,",") [/code] It also returned the same error. Sorry can't dump the loaded code right now; getting dinner ready.... Phil. |
This is because the field$ function has disappeared in 5.4.04. Geoff knows about it and it trying to ascertain the cause. field$() is being treated as a array hence the error as it expects a number as the array index |
Amazingly, it did just vanish. I had a bad hiccup on my development system and had to recover the files and somewhere in the middle of that it went missing in action. Not a bigie, it will be in the next version. Geoff Geoff Graham - http://geoffg.net |
As an experiment I wrote the FIELD$() function as an MMBasic subroutine. It is so simple that I am not sure that it is worth putting it into the language. Function Field$(s As String, n As Integer) Const delim = "," ' set this to the field delimiter Local Integer i, StartIdx = 1, EndIdx ' get the start of the field in StartIdx For i = 2 To n StartIdx = Instr(StartIdx, s, delim) + 1 If StartIdx = 1 Or StartIdx > Len(s) Then Exit Function Next i ' get the end of the field in EndIdx and extract the field EndIdx = Instr(StartIdx, s, delim) If EndIdx = 0 Then EndIdx = 255 Field$ = Mid$(s, StartIdx, EndIdx - StartIdx) ' trim leading and trailing spaces Do While Mid$(Field$, 1, 1) = " " : Field$ = Mid$(Field$, 2) : Loop Do While Right$(Field$, 1) = " " : Field$ = Mid$(Field$, 1, Len(Field$) - 1) : Loop End Function Geoff Graham - http://geoffg.net |
It looks like a TRIM$ function is more needed. Those Do While alternatives get the job done but look clumsy and use a lot of string manipulation which takes up space and time. If there is room in flash then having the functionality in flash will save room for more basic code. A FIELD$ might not be as handy as a SPLIT function. It would require that it returns an array. I guess that is only possible from a function in firmware. A SPLIT function that returns an array of values would be very handy to have. Every other language has a SPLIT function and basic sure could use one. Microblocks. Build with logic. |
For VB lovers everywhere 1 2 hugs |
based upon previous forum discussions about only adding things that can not be accomplished with a few lines of basic code, my opinion (and it is just an opinion!) would be to leave FIELD$() out. the same holds for TRIM$(). on the other hand, adding an optional position parameter that the VAL() function adjusts would be extremely useful in robustly parsing strings of numeric data: x = VAL( string$ [, position]) where position must be a variable, and is set upon exit by the VAL() function to the location of the first non-number character in string$, or zero if the full string evalutes to a number. the next line of your basic code can then trim off the processed numeric portion with: string$ = MID$(string$, position) cheers, rob :-) |
| GoodToGo! Senior Member Joined: 23/04/2017 Location: AustraliaPosts: 188 |
@CaptainBoing, Be stuffed if I could get the Split routine link above to work under 5.04.04 on a MM+. It kept complaining about ERASing and DIMming arrays in the function for some reason. So, take 2, I hashed the Split routine with the new you-beaut FIELD$ out of the Manual. Ha! After spending a good chunk of my life I will never get back trying to make it work I went back to this same Topic and of course re-read how it's stuffed. So, take 3, I bastardised (easier to read?) the Split routine by swapping out the many IF THEN loops for DO UNTIL LOOPS and combined it with Geoff's MM+ FIELD$ routine above and came up with this:- '------------------------------------------------------------------------------ ' My Message Split Routine. '------------------------------------------------------------------------------ FUNCTION Split(s$, delim$) as integer 'Returns the number of fields in S$ LOCAL INTEGER z, n, m DO 'Count number of fields in s$ (1 + # of deliminators) z = z + LEN(delim$) z = INSTR(z, s$, delim$) n = n + 1 LOOP until z = 0 if n = 1 then 'Only one field (No deliminators) RxdDataField$(1) = s$ Split = n exit function endif DO m = m + 1 RxdDataField$(m) = field$(s$ ,m ,delim$) LOOP until m = n Split = m END FUNCTION '------------------------------------------------------------------------------ ' Geoff's Message Field$ Routine (with one amendment) '------------------------------------------------------------------------------ Function Field$(s$, n, delim$) Local Integer i, StartIdx = 1, EndIdx ' get the start of the field in StartIdx For i = 2 To n StartIdx = Instr(StartIdx, s$, delim$) + 1 If StartIdx = 1 Or StartIdx > Len(s$) Then Exit Function Next i ' get the end of the field in EndIdx and extract the field EndIdx = Instr(StartIdx, s$, delim$) If EndIdx = 0 Then EndIdx = len(s$)+1 ' makes it smaller than 255 Field$ = Mid$(s$, StartIdx, EndIdx - StartIdx) End Function I didn't require the TRIM side of things and also edited the 255 out above for 'len(s$)+1' to remove the need for trimming Appears to work real good now for chopping up my serial data streams between an Explore 28 and MM+ Backpack. I was going to completely combine the two into one function, but realised that both functions are handy. Cheers, GTG! ...... Don't worry mate, it'll be GoodToGo! |
OK, just flashed my test rig (44pin MM, 5.03) and tracked that down - The ON ERROR SKIP command now requires a number (previously didn't) so a single modification and it now works as it should - I will update the Wiki But... I didn't get any complaints about ERASE or DIM. Only difference you are on MM+ and I am on a bog-standard 44pin MM > ? mm.ver 5.0404 > list all z=Split(Time$,":") For n=1 To z Print n,SP$(n) Next Function Split(a$,b$) ' returns the number of dimensions in SP$ always starts from 1 regardless of OPTION BASE Local INTEGER z,n,m On ERROR SKIP 1 ' if SP$ doesn't exist, next line will cause an error Erase SP$ z=1:n=0 Do 'count instances of delimiter for DIM SP$() z=Instr(z,a$,b$) If z=0 Then If n=0 Then ' no delimeters Dim SP$(1):SP$(1)=a$:Split=1:Exit Function ' only one substring Else Exit Do End If Else n=n+1:z=z+Len(b$) End If Loop m=n+1:n=1 Dim SP$(m) Do z=Instr(1,a$,b$) If z=0 Then SP$(m)=a$:Exit Do Else SP$(n)=Left$(a$,z-1):a$=Mid$(a$,z+Len(b$)):n=n+1 End If Loop Split=m End Function > run 1 00 2 01 3 14 > need to be aware of that as changes to the firmware on existing devices may also require changes to the software. It would have been nice to have it so that if no number was specified then it assumed 1 to maintain backward compatibility but I am sure there is a reason it is like it is... small point anyway h |
The ON ERROR did burn me at the start, but I worked through that one, I flashed the MM+ with your code incorporating your routine and it worked. Then I changed the SP$ array to my RxdDataField$ array and it went pear shaped. A typo on my behalf, in my code there was RxdDataField$() and RxdDataField(). Both referencing the same strings of course, but MMbasic moaned about it already being declared. Changing all references to $ or making the DIM as STRING fixed the errors and it works as advertised. In my defence, I'm sure the $ is optional? eg. run Sending Payload. 8 Bytes long. [870] RxdDataField(m)=a$:Exit Do Error: RXDDATAFIELD already declared According to the manual and in this example, RxdDataField(m) and RxdDataField$(m) should reference the same string? Keeping in mind that I have OPTION EXPLICIT and OPTION DEFAULT INTEGER on, why would MMBasic being trying to declare it again without a DIM or LOCAL? I blanked an explore28 and programmed your example above, with one difference, "SP(m):Exit Do" (got rid of the $) and it failed with the same message. ? mm.ver 5.0404 > run [35] sp(m)=a$:Exit Do Error: SP already declared > list z=Split(Time$,":") For n=1 To z Print n,SP$(n) Next Function Split(a$,b$) ' returns the number of dimensions in SP$ always starts from 1 regardless of OPTION BASE Local INTEGER z,n,m On ERROR SKIP 1 ' if SP$ doesn't exist, next line will cause an error Erase sp$ z=1:n=0 Do 'count instances of delimiter for DIM SP$() z=Instr(z,a$,b$) If z=0 Then If n=0 Then ' no delimeters Dim sp$(1):sp$(1)=a$:Split=1:Exit Function ' only one substring Else Exit Do End If Else n=n+1:z=z+Len(b$) End If Loop m=n+1:n=1 Dim sp$(m) Do z=Instr(1,a$,b$) If z=0 Then sp(m)=a$:Exit Do '<<<<<<<< The missing $ issue I had Else sp$(n)=Left$(a$,z-1):a$=Mid$(a$,z+Len(b$)):n=n+1 End If Loop Split=m End Function > As before, if I change the two DIM SP$() statements to be AS STRING then the code works. Or of course, inserting the $ in SP(m) also works. Strange, because I was sure DIM SP$(m) and DIM SP$(m) AS STRING should work the same. Your thoughts? GTG! ...... Don't worry mate, it'll be GoodToGo! |
glad you got it working. perhaps not strictly TYPEing the array caused problems between the ERASE & DIM... I have to say I am a dinosaur in that way - I always like $ after strings... number variables I tend not to TYPE explicitly unless I have variables with the same name - which i also try to avoid. Self documenting code principles dictate really nice variable names and that is good in any compiled/assembled code but uM code, being interpreted, suffers time penalties with long variable names so anything that runs in tight loops or is used often tends to get simple names - hence SP$ - which is MY limit on avoiding collision with variable names as an aside, I do wonder that with the new FIELD function if SPLIT is really worth continuing with... I need to do some experimentation on timing with multiple FIELD calls to chop a string versus the timing and redundancy of splitting the string but then having every sub-string only a variable away... might come into its own with CSV data etc but the time for a bit of MIPS code versus an interpreted loop or several... but, with the maximum size of a string, I can't see how SPLIT could really be faster unless you were referring to the same sub-string loads of time with sloppy code, FIELDing it each time instead of assigning it to a variable.. Now I have flashed my test rig to 5.04 ( ) maybe I'll do that this weekend and see where the limit is just for fun. Drop the CPU right down to 5MHz to really accentuate the delays and see what pops out... I am such a sad case |
It is simple but the speed difference over doing it in MMBasic is what makes it desirable for me |
Geoff and CaptainBoing, I've been looking at your Field functions above. Is it me or do they have a problem picking the last field as in "E" the following real NMEA (0183) sentence (and all the last fields - because the last delimiter is "*" not ",")? (It is still important to get the last field - in this case the E is for East of the prime meridian.) $GPRMC,034600,A,3747.3072,S,14502.7606,E,000.0,097.2,081016,011.6,E*6A Can you see a way of neatly picking the E (OK - it could be the character(s) between the last "," and the "*" but there has to be a neater way?) Cheers, Andrew (By the way, whilst 99.99% of GPS output NMEA 0183 sentences beginning "$GP . . ." some specialised chart-plotters replace the "GP" with their own code. eg my Raymarine chart-plotter output is: "$ECRMC,024800,A,3830.721,S,14521.651,E,0.1,000.0,120412,012.0,E,A*12" ) |
I have not tested this but it should work. Function Field$(s As String, n As Integer) Const delim1 = "," ' set this to the field delimiter Const delim2 = "*" ' set this to the second field delimiter Local Integer i, StartIdx = 1, EndIdx ' get the start of the field in StartIdx For i = 2 To n StartIdx = Instr(StartIdx, s, delim1) + 1 If StartIdx = 1 Then StartIdx = Instr(StartIdx, s, delim2) + 1 If StartIdx = 1 Or StartIdx > Len(s) Then Exit Function Next i ' get the end of the field in EndIdx and extract the field EndIdx = Instr(StartIdx, s, delim1) If EndIdx = 0 Then EndIdx = Instr(StartIdx, s, delim2) If EndIdx = 0 Then EndIdx = 255 Field$ = Mid$(s, StartIdx, EndIdx - StartIdx) ' trim leading and trailing spaces Do While Mid$(Field$, 1, 1) = " " : Field$ = Mid$(Field$, 2) : Loop Do While Right$(Field$, 1) = " " : Field$ = Mid$(Field$, 1, Len(Field$) - 1) : Loop End Function Geoff Graham - http://geoffg.net |
Hi Geoff (you're a marvel), That works! It also gives an easy way of reading the checksum. Thanks again, Andrew |
