Forum Index : Microcontroller and PC projects : Prototyping PCB
Hi all, Check this one out: Routaboard Probably needless to say - one of mines
http://rittle.org -------------- |
| MM_Wombat Senior Member Joined: 12/12/2011 Location: AustraliaPosts: 139 |
Cool. Wanted to buy one to test, but must be sold out... MM_Wombat Keep plugging away, it is fun learning But can be expensive (if you keep blowing things up). Maximite, ColourMaximite, MM+ |
Look's like a great concept for lots of users who aren't into PCB design. Will get my hands on a couple when they are available. Especially like the ability to play with the layout in software, even though I had to use 2 DIP14's to represent a MicroMite. Any Idea when they will be available? And DIP28 added to the component library? Thanks Phil. |
You can actually define your own components. Select the component mode (the orange icon), right click and select "Add New Component". Then choose the one on top which says "BLANK", give it a name and place the holder somewhere on the board. Now you can add and remove pins within the component area, and you can drag the pins to change the component area. So you place 28 pins, give them names or numbers and then when ready right click again and choose "Add to Library". http://rittle.org -------------- |
Ahhh, Thanks, didn't know the usage & saw that add to library was greyed out, so thought it wasn't implemented yet. Phil. |
Yes, I understand. A small help file is what the software needs right now. You can also use other features in a way similar to Altium - you can rotate components with the space key when placing them on the board. And you can also move them to the other side of the board with the L key. http://rittle.org -------------- |
Can I flip my 28 Pin or do I need to create a separate one for different orentations? |
Error on add to library. NTFS file permissions on C:\Program File(x86)? Not usually writable by default, but strange as I have full permissions to the file and have ownership. Phil |
Looks like that. Try to run the program as administrator Will be fixed in the next revision http://rittle.org -------------- |
That's what I'd just been trying. Worked fine. |
| hitsware Guru Joined: 23/11/2012 Location: United StatesPosts: 535 |
I can't find the prices ? Looks good. I go through dozens of the Adafruit proto boards .......... |
They will be available soon. I have boards now, but haven't worked out the distribution yet. Prices will be quite reasonable. http://rittle.org -------------- |
Can say that Royal Mail seems fairly cheap & reasonable delivery times to Australia. |
It is on http://rittle.org -------------- |
kiiid I really like the design of the board. The key limitation for me is in the software. Rather than inventing your own decriptor language (RDBL) why not use something like Protel or other already defined version At the moment I use VeeCAD with stripboard. This has the huge advantage that I can import a netlist from a range of schematic design tools and then VeeCAD will check my layout against the netlist, identifying missing links, missing components, as well as links that shouldn't be there. Once I have a layout that checks out in VeeCAD I can be sure that the prototype will work (assuming the schematic is correct). If I need to change the design I can edit the schematic, re-import it to VeeCAD and then it will identify the changes I need to make to the prototype to bring it back in-line with the schematic. Once the prototype is working I can then use the same schematic to layout a dedicated PCB and I can be guaranteed it will work as long as I follow the design rule checking. I can't imagine how much time I would have wasted by trying to design direct to the prototype. For me this is a showstopper at the moment but I would certainly move to your system with the sort of integration described above. |
I understand. After all this is only a first version of it. It is quite possible the software will support other formats in the future. http://rittle.org -------------- |
| Bill7300 Senior Member Joined: 05/08/2014 Location: AustraliaPosts: 161 |
I wanted to support several of the choices but it seems as if you can only make one pledge? Bill |
I am sorry, don't know how to allow more than one. It seems the limitation comes from Kickstarter itself. http://rittle.org -------------- |
I think it (prototype layout language) is a brilliant idea !
It will of course be resisted by the pcb design program vendors though.. A standard form output file or array format, maybe even an xml would be good. The programs that already have a scripting capacity could then incorporate it easily, using a script in their own setup. I can see a cheap quick-protype printer - feed it the board and it solders the tracks on the spot ! Pity no smd yet though.. best of luck ! |
Ah, yes. I can see that printer in my mind... Probably as a first step though I will try to think a small pen-like tool for placing bridges without the need of a soldering iron... http://rittle.org -------------- |
