Local Time 22:02 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite and Micromite Plus Beta 30
     Page 1 of 3
Posted: 08:15pm 16 Sep 2015
Another beta (B30) for both the standard Micromite (MX170) and the Micromite Plus (MX470) is out. It can be downloaded from: http://geoffg.net/Downloads/Micromite/Micromite_4.7_Beta.zip (clear your browser cache first).
The changes are listed in the file Changes.txt but the important ones are:
- The LIBRARY feature has been modified to automatically run the code in the library space before the program in the main memory is run. This can be used to set constants and I/O pins which are normally cleared before a program is run. It will NOT be run at first startup as in the previous beta. The manual has been updated to reflect this behaviour.
- At startup or reset MMBasic will now look for a subroutine with the name MM.STARTUP and, if found, the code in the subroutine will be run before the command prompt is displayed. This subroutine can be in the library space and can be used to replace the old LIBRARY functionality. The manual has been updated to document this feature (page 21).
- OPTION LIST can be used to list all options that have been changed from their defaults and saved in flash.
With these betas I have been concentrating on fixing the MX170 version and any important new features that it required - and I believe that with this beta it is mostly there.
These changes have flowed through to the MX470 version (Micromite Plus) but now I plan to concentrate on the MX470 specific bug and feature list - so future betas should see improvements particular to that chip (such as the 100-pin version and the USB/Win10 issue).
As before, please add comments to this thread if you find a bug.
Posted: 08:31pm 16 Sep 2015
Liking the OPTION LIST feature
. . . and TEMPR Thanks for this one (although I had written a LIBRARY sub to do this!)Edited by WhiteWizzard 2015-09-18
Posted: 10:19pm 16 Sep 2015
@Geoff
Is there a way of MMBasic knowing when the COMMAND PROMPT is initiated (either after a program 'ends' OR when the EDITOR is exited? If so, then can there be a LIBRARY sub that gets called so that code can be run in this instance.
Main purpose is to define pins with names that can be used at anytime from the command prompt.
Likewise, a sub for when the editor is initiated. This way certain things can be set such as colours and font sizes.
This is not a priority request - just an enquiry as to if it is possible and/or easy with near zero impact on memory/token limitations.
WW
EDIT: I always consider the MM as having three modes: 1>Command Prompt 2>Editor 3>Run mode.
The above is just seeing if Library subs could be created for the initiation of the first two modes - obviously the Run mode can have user code to setup anything so no Library sub required for this one!
Chris Roper
Posted: 10:45pm 16 Sep 2015
It was inevitable that someone would do this so I decided to jump in first
[code]
> list
Sub mm.startup
Print "Hello World!"
> library save
> Micromite MKII MMBasic Ver 4.7 Beta 30
Copyright 2011-2015 Geoff Graham
Hello World!
[/code]
I like it, thanks Geoff
Chris
http://caroper.blogspot.com/
Posted: 10:57pm 16 Sep 2015
@Geoff,
I have set OPTION SDCARD 12,14,33. However, OPTION LIST only shows SDCARD 12,14
Would you not expect to see 33 listed for the WP pin too?
WW
Posted: 11:05pm 16 Sep 2015
@Geoff,
If you have a library startup where you define COLOUR x,y to try and set foreground and background colours to something different than the default white on black, then upon MM starting up the colours revert back to white on black (I used CLS in start to effectively observe this).
This implies that the MM.Startup sub is run prior to some firmware start-up things. Is there any reason why the MM.Startup can not run after the firmware stuff so that things like colours can be changed?
You may have a 'technical' reason in which case ignore the above. However, if there was no reason, then I see the users MM.Startup being more beneficial if run 'last' i.e. just prior to the prompt showing (or program auto-running)
Posted: 11:26pm 16 Sep 2015
@Geoff,
Sorry - I don't want to be seen as asking thousands of questions - but I am busy testing B30.
Out of curiosity, with OPTION LIST, what sequence are you using to display them? I see it isn't the order they were set, nor alphabetical. No problem - just curious
WW
Chris Roper
Posted: 12:06am 17 Sep 2015
not sure if it is me or if there is a bug in the EDITOR:
if I edit I get this as soon as I press any key:
I did try re-flashing with Beta 30 just in case I had corrupted anything but the problem persists with or without a library loaded and on any program I try to edit.
The second issue is if I run it:
Cheers,
Chris
Edited by Chris Roper 2015-09-18
Posted: 12:31am 17 Sep 2015
Chris,
If you reboot and then type
? ds1
Does it show 7 or 0?
Also - should be pin(ds1)=1 i.e. normal brackets!
WW
Posted: 12:34am 17 Sep 2015
@Geoff,
With LIBRARY LIST, is it possible to add a 'press any key' message whenever the listing extends beyond the number of text-lines on the screen?
Posted: 12:42am 17 Sep 2015
@Geoff
Just used LIBRARY DELETE in B30 and got XMODEM RECEIVE message (then timed out).
This was on the first time using LIBRARY DELETE. Second time worked ok
Chris Roper
Posted: 12:50am 17 Sep 2015
  WhiteWizzard said   Chris,
? ds1
[code]
> XMODEM RECEIVE
Saved 226 bytes
> library save
LPCDB Edition
> ? ds1
0
[/code]
[quote]
WW[/quote]
They are normal brackets, just the low res screen capture makes them look weird
Basically the code runs as the message appears on reset but the constants are being cleared before the prompt loads.
If I include pin(ds1) = 1 inside the mm.startup then the LED lights.
Chris
Posted: 01:04am 17 Sep 2015
@Chris,
I get the same as you if CONSTs declared in MM.Startup i.e. they equal zero at command prompt after a re-boot.
This must be a bug surely??
I am trying to get constants declared (for pin names) so that in Command prompt at any time, or in a user program, I can refer to the pin by a name rather than a number.
If I don't use CONST (but just say ds=7) then I can get a solution apart from at the command prompt AFTER the editor is trigger. Hence my post above asking if other LIBRARY Subs could be created to trigger when Command prompt entered, or editor entered.
WW
EDIT: Could be the sequence of things as I also mention in an earlier post - would be better if MM.Startup runs AFTER the firmware has done it's stuff (i.e. just before the command prompt appears)Edited by WhiteWizzard 2015-09-18
Posted: 01:08am 17 Sep 2015
  Quote  I get the same as you if CONSTs declared in MM.Startup i.e. they equal zero at command prompt after a re-boot.
AFAIK this has always been the case, nothing to do with libraries or the new code, just the way Geoff designed it to work.
CONST declared in a subroutine or function only have scope inside that function. For this reason when developing the early display drivers things that I wanted as constants but I also wanted to define in an initialisation subroutine had to be defined as DIM and not CONST
Edited by matherp 2015-09-18
CFLY
Posted: 01:29am 17 Sep 2015
Geoff, Jim
With MMbasic V4.7 B30, MMEdit 3.6.4 and Micromite+ Explore64 (just received) connected by the USB:
When I make:
PUSH RESET SWITCH => card disconnected
CPU RESTART => card disconnected
OPTION LIST => card disconnected
After, I disconnect the card, I restart MMEdit, and I redo the connection.
Pb known?
Chris Roper
Posted: 01:54am 17 Sep 2015
  matherp said  CONST declared in a subroutine or function only have scope inside that function.
That makes sense so I tried this:
[code]
Const ds4 = 4
Const ds3 = 5
Const ds2 = 6
Const ds1 = 7
Const sw1 = 16
Const rp1 = 26
Sub mm.startup
Print "LPCDB Edition"
setpin ds4, dout
setpin ds3, dout
setpin ds2, dout
setpin ds1, dout
setpin sw1, din
setpin rp1, ain
[/code]
and the result is:
> RUN
> ? ds1
7
> library save
LPCDB Edition
[LIBRARY] SetPin ds4, dout
Error: Pin 0 is invalid
I must be misreading Geoff's notes but I certainly can't see a way of using Const and then setting up predefined pins at this stage.
I have built a tray for the MicroMite that plugs into the Low Pin Count Demo Board and am trying to use this to define the LED's etc. in place of the #include file that I use for the PIC/12/16/18 devices in the same board.
Chris
p.s. anybody else having editor issues?
I am having to edit external and then send the file which also hampers testing slightly Edited by Chris Roper 2015-09-18
Chris Roper
Posted: 02:06am 17 Sep 2015
Tried this to get around the scoping issue:
[code]
' LPCDB Include file
Sub mm.startup
setpin 4, dout
setpin 5, dout
setpin 6, dout
setpin 7, dout
setpin 16, din
setpin 26, ain
Const ds4 = 4
Const ds3 = 5
Const ds2 = 6
Const ds1 = 7
Const sw1 = 16
Const rp1 = 26
[/code]
But the result is the same, even if I put the constants before or after mm.startup
Chris
Posted: 02:10am 17 Sep 2015
@Chris,
We're both trying to do the same thing (naming pins). If you don't mind using DIM as opposed to CONST (or simply dropping the CONST prefix) then there is a 'partial' solution as I keep mentioning.
Let's wait to see if Geoff (or someone else) can propose a method other than what we have posted/requested so far . . . Edited by WhiteWizzard 2015-09-18
Chris Roper
Posted: 02:27am 17 Sep 2015
Thanks WW,
I am also happy to wait, was just curious as Geoff specifically says to use Const in the MM Reference manual.
I am stuck till the Editor works anyway :)
Chris
Posted: 02:36am 17 Sep 2015
Geoff may well be saying to use CONST as that is correct, but there might be a bug here - he will let us know. Watching this thread with interest.
     Page 1 of 3
