Local Time 05:48 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : uM2(+): CFunctions
Posted: 03:48am 06 Sep 2015
Unfortunately the support site for CFunctions is no longer online so I have programmed a clunky but workable replacement for CFuncGen
This is written in MMBasic V4.5 for DOS. Unfortunately this doesn't support OPTION EXPLICIT or INTEGER datatypes so some of the variable usage may be a bit unclear. However, I was impressed how reliable MMBasic for DOS is doing some quite complex logic.
The program reads the .ELF file created by MPLabX and outputs the CFunctions in Basic format.
There are simple instructions for use in the file header. If you can write CFunctions you should be able to work out how to use it, but any questions do ask.
I used this document as my source of information on the .ELF file
The program is tested on a selection of my CFunctions including display drivers and works properly on the tested examples but please let me know if you find any bugs. The program includes a fairly primitve mechanism for replacing Jump and Link instructions which are not position independent with Branch and link which are. This has only been tested with backwards references, e.g. calling the first function in a merged file from the second.
2015-09-06_134007_cfgen.zip
' CFGEN.BAS V1.0
' Program to convert a .ELF file to Basic statements formatted for use as CFunctions
' Runs under MMBasic for DOS V4.5
' It is recommended that the .ELF file is copied to the same directory as this file
' and that the filename is shortened to make life easier
' To run open a DOS box on the computer
' navigate to the directory containing the MMBasic.exe file and this program
' run MMBasic and you will get the normal ">" prompt
' Load this program
' Type run
' Then give the filename of the .elf file including the extension
' Choose "join" or "merge" to define the output format
' "join" is typically used for individual CFunctions, each function in the .ELF file is given
' its own header, all the CFunctions are output to a single file but can then be copied and
' pasted as required. When "join is chosen the "main" function is a dummy and is not included in the output
' "merge" is used for CFunctions such as drivers where one C function can be called from another
' Choose the name of the file for the Basic output. Do not include ".BAS", this will be appended automatically
' You can run MMBasic for DOS from MMEDIT, but in this case you will need to specify the correct directory information for the .ELF file
dim program_header,section_header,program_header_size, program_header_num, section_header_size, section_header_num
dim string_table_sector, string_table, text_section, text_position, text_size, text_link, symtab_section, strtab_section
dim symtab_offset, symtab_num, symstr_offset, first
dim text_add$ length 31
dim symbols$(100,2) length 31
line input ".ELF filename ? ",inname$
do
line input "mode(join, merge) ? ",m$
loop while (m$<>"join") and (m$<>"merge")
mode =0
if m$="merge" then mode=1
line input "CFunction name ? ",cname$
print "Created "+cname$+".bas"
open cname$+".bas" for output as #2
first=1 'first time into the various loops
print "processing ",inname$
open inname$ for random as #1
SEEK #1, 0
dat$ = INPUT$(16, #1) ' Get the .elf identification
dat$=input$(12,#1) 'Get unused header
dat$=input$(4,#1)
program_header=getnum4(dat$)
dat$=input$(4,#1)
section_header=getnum4(dat$)
dat$=input$(6,#1) 'step past the flags and header size
dat$=input$(2,#1)
program_header_size=getnum2(dat$)
dat$=input$(2,#1)
program_header_num=getnum2(dat$)
dat$=input$(2,#1)
section_header_size=getnum2(dat$)
dat$=input$(2,#1)
section_header_num=getnum2(dat$)
dim sections$(section_header_num+2)
dat$=input$(2,#1)
string_table_sector=getnum2(dat$)
i=section_header+ (Section_header_size*string_table_sector) + 16 'get to the offset in the string table sector
seek #1,i
dat$=input$(4,#1)
string_table= getnum4(dat$) 'get the offset to the string table
Print "Functions found:"
print "Address",chr$(9)+"Function"
for j=0 to section_header_num-1
i=section_header+ (Section_header_size*j) 'get to the next sector header
seek #1,i 'point to the .text section header
dat$=input$(4,#1) 'get the pointer to the sector name string
k=getnum4(dat$)
seek #1,k+string_table 'point to the name string for this sector
s$=""
d$=input$(1,#1)
do while asc(d$)<>0 'read in the zero terminated string
S$=S$+D$
d$=input$(1,#1)
loop
if s$=".text" and text_section=0 then 'store text sector number
text_section=j
endif
if s$=".symtab" and symtab_section=0 then 'store symbol table sector number
symtab_section=j
endif
if s$=".strtab" and strtab_section=0 then 'store symbol table strings sector number
strtab_section=j
endif
next j
i=section_header+ (Section_header_size*text_section) 'get to the .text offset
dat$=input$(12,#1)
dat$=input$(4,#1)
text_add$=getadd$(dat$)
dat$=input$(4,#1)
text_position=getnum4(dat$)
dat$=input$(4,#1)
text_size= getnum4(dat$)
dat$=input$(4,#1)
text_link= getnum4(dat$)
dat$=input$(4,#1)
text_info= getnum4(dat$)
dat$=input$(4,#1)
text_addralign= getnum4(dat$)
dat$=input$(4,#1)
text_entsize= getnum4(dat$)
i=section_header+ 16+ (Section_header_size*(symtab_section))
dat$=input$(4,#1) 'get the offset to the symbol table
symtab_offset=getnum4(dat$)
dat$=input$(4,#1)
symtab_num=getnum4(dat$)/16
i=section_header+ 16+ (Section_header_size*(strtab_section))
symstr_offset=getnum4(dat$)
m=0 'counter for the stored symbols array
for i=1 to symtab_num 'loop through all the symbols
seek #1,symtab_offset+(16*i) 'point to the next symbol in the .symtab section
dat$=input$(4,#1)
k=getnum4(dat$)
dat$=input$(4,#1)
a$=getadd$(dat$)
dat$=input$(4,#1)
dat$=input$(1,#1)
l=asc(dat$)
seek #1,k+symstr_offset 'point to the symbol name
s$=""
d$=input$(1,#1)
do while asc(d$)<>0
S$=S$+D$
d$=input$(1,#1)
loop
if l=18 and left$(s$,1)<>"_" then 'Only store function names
symbols$(m,1)=a$
symbols$(m,2)=s$
print symbols$(m,1),symbols$(m,2)
m=m+1
if s$="main" then main_offset$=a$
endif
next i
s$= hex$(subtract(right$(main_offset$,5),right$(text_add$,5))) 'calculate the offset of the main function
if len(s$)=1 then s$="0000000"+S$
if len(s$)=2 then s$="000000"+S$
if len(s$)=3 then s$="00000"+S$
if len(s$)=4 then s$="0000"+S$
if len(s$)=5 then s$="000"+S$
if len(s$)=6 then s$="00"+S$
if len(s$)=7 then s$="0"+S$
main$=s$
seek #1,text_position
k=0
currentfunction=0
s$=text_add$
for i=1 to text_size step 4
for j=0 to m-1
if s$=symbols$(j,1) then 'address matches the start of a function
currentfunction=j
if k<>0 and mode then print #2,"" 'The last function didn't end with a newline so output one
if k<>0 and (not mode) and symbols$(j,2)<>"main" then print #2,""
k=0
if first and mode then ' First time in for a merged file output the Cfunction name
print #2,"CFunction "+cname$
print #2,chr$(9)+main$
endif
if mode then print #2,chr$(9)+"'"+symbols$(j,2)
if not mode and symbols$(j,2)<>"main" then
if not first then
print #2,"End CFunction"
print #2,"'"
endif
print #2,"CFunction "+symbols$(j,2)
print #2,chr$(9)+"00000000"
endif
first=0
endif
next j
if k=0 then print #2,chr$(9);
dat$=getadd$(input$(4,#1))
if left$(dat$,3)="0F4" then 'Jump instruction found convert to a branch
a$=getjumpaddress$(right$(dat$,5)) 'this the address for the jump
branchoffset=subtract(right$(s$,5),right$(a$,5))
branch$="0411FFFF"
do
decrement(branch$)
branchoffset=branchoffset-1
loop while branchoffset
if not mode and symbols$(currentfunction,2)<>"main" then print #2, branch$+" ";
if mode then print #2, branch$+" ";
else
if not mode and symbols$(currentfunction,2)<>"main" then print #2, dat$+" ";
if mode then print #2, dat$+" ";
endif
k=k+1
if k=8 then 'deal with line feed every eight words
if not mode and symbols$(currentfunction,2)<>"main" then print #2,""
if mode then print #2,""
k=0
endif
increment4(s$) 'step on the program counter
next i
if k<>0 then print #2,""
close #1
close #2
end
function subtract(b$,c$)
local a,b,c,d,e,f,g,a$
a=asc(mid$(b$,5,1)) : a=a-48 : if a> 9 then a=a-7
b=asc(mid$(b$,4,1)) : b=b-48 : if b> 9 then b=b-7
c=asc(mid$(b$,3,1)) : c=c-48 : if c> 9 then c=c-7
d=asc(mid$(b$,2,1)) : d=d-48 : if d> 9 then d=d-7
e=asc(mid$(b$,1,1)) : e=e-48 : if e> 9 then e=e-7
f=((((((((e * 16) + d) * 16 ) + c ) * 16 ) + b ) * 16 ) + a)
a=asc(mid$(c$,5,1)) : a=a-48 : if a> 9 then a=a-7
b=asc(mid$(c$,4,1)) : b=b-48 : if b> 9 then b=b-7
c=asc(mid$(c$,3,1)) : c=c-48 : if c> 9 then c=c-7
d=asc(mid$(c$,2,1)) : d=d-48 : if d> 9 then d=d-7
e=asc(mid$(c$,1,1)) : e=e-48 : if e> 9 then e=e-7
g=((((((((e * 16) + d) * 16 ) + c ) * 16 ) + b ) * 16 ) + a)
subtract=(f-g)/4
end function
function getjumpaddress$(a$)
local a,b,c,d,e,f
a=asc(mid$(a$,5,1)) : a=a-48 : if a> 9 then a=a-7
b=asc(mid$(a$,4,1)) : b=b-48 : if b> 9 then b=b-7
c=asc(mid$(a$,3,1)) : c=c-48 : if c> 9 then c=c-7
d=asc(mid$(a$,2,1)) : d=d-48 : if d> 9 then d=d-7
e=asc(mid$(a$,1,1)) : e=e-48 : if e> 9 then e=e-7
f=((((((((e * 16) + d) * 16 ) + c ) * 16 ) + b ) * 16 ) + a)*4 + 1048576
getjumpaddress$=left$(text_add$,3)+right$(hex$(f),5)
end function
function getadd$(d$)
local a,b,c,d
a=asc(left$(d$,1))+256
b=asc(mid$(d$,2,1))+256
c=asc(mid$(d$,3,1))+256
d=asc(right$(d$,1))+256
getadd$=right$(hex$(d),2)+right$(hex$(c),2)+right$(hex$(b),2)+right$(hex$(a),2)
end function
function getnum4(d$)
local a,b,c,d
a=asc(left$(d$,1))
b=asc(mid$(d$,2,1))
c=asc(mid$(d$,3,1))
d=asc(right$(d$,1))
getnum4=((((d*256)+c)*256)+b)*256+a
end function
function getnum2(d$)
local a,b
a=asc(left$(d$,1))
b=asc(right$(d$,1))
getnum2=b*256+a
end function
sub increment4(p$)
local a,b,c,d,e,f,g,h,v
a=asc(mid$(p$,8,1)) : a=a-48 : if a> 9 then a=a-7
b=asc(mid$(p$,7,1)) : b=b-48 : if b> 9 then b=b-7
c=asc(mid$(p$,6,1)) : c=c-48 : if c> 9 then c=c-7
d=asc(mid$(p$,5,1)) : d=d-48 : if d> 9 then d=d-7
e=asc(mid$(p$,4,1)) : e=e-48 : if e> 9 then e=e-7
f=asc(mid$(p$,3,1)) : f=f-48 : if f> 9 then f=f-7
g=asc(mid$(p$,2,1)) : g=g-48 : if g> 9 then g=g-7
h=asc(mid$(p$,1,1)) : h=h-48 : if h> 9 then h=h-7
a=a+4 : if a=16 then
b=b+1 : a=0
if b=16 then
c=c+1 : b=0: if c=16 then
d=d+1 : c=0: if d=16 then
e=e+1 : d=0 : if e=16 then
f=f+1 : e=0 : if f=16 then
g=g+1: f=0 : if g=16 then
g=0: h=h+1
endif
endif
endif
endif
endif
endif
endif
endif
a=a+48: if a> 57 then a=a+ 7
b=b+48: if b> 57 then b=b+ 7
c=c+48: if c> 57 then c=c+ 7
d=d+48: if d> 57 then d=d+ 7
e=e+48: if e> 57 then e=e+ 7
f=f+48: if f> 57 then f=f+ 7
g=g+48: if g> 57 then g=g+ 7
h=h+48: if h> 57 then h=h+ 7
p$=chr$(h)+chr$(g)+chr$(f)+chr$(e)+chr$(d)+chr$(c)+chr$(b)+chr$(a)
end sub
sub decrement(p$)
if a<>0 then
a=a-1
else
a=15
if b<>0 then
b=b-1
else
b=15
if c<>0 then
c=c-1
else
c=15
if d<>0 then
d=d-1
else
d=15
endif
endif
endif
endif
p$=left$(p$,4)+chr$(d)+chr$(c)+chr$(b)+chr$(a)
end sub
Edited by matherp 2015-09-07
Posted: 03:52am 06 Sep 2015
I've never played with MMBASIC for DOS. Does it compile it's code to an exe or something like that you can run from the DOS command prompt?Edited by Grogster 2015-09-07
Posted: 05:02am 06 Sep 2015
  Quote  I've never played with MMBASIC for DOS. Does it compile it's code to an exe or something like that you can run from the DOS command prompt?
It just runs the interpreter in a DOS box. The language is basically the same as Maximite less the various PIC specific hardware support. What makes it very useful for me is that the file handling is really easy just like on the Maximite. Because you can't do 32-bit integer arithmetic when you only have floats I've had to do some very inefficient coding with addresses maintained as 8 character hex strings but despite this the code runs perfectly acceptably quickly.
If you need to do any sort of simple file format conversion and, like me, don't know things like python then MMBasic for Dos is a great solution.
MMBasic for DOS is available here Edited by matherp 2015-09-07
paceman
Posted: 07:25pm 06 Sep 2015
One of the very handy things that MMBasic for DOS has is the SYSTEM command.
Format: SYSTEM command$
Useage:
Submit 'command$' to the operating system. It can be any command recognised by the command window in Windows XP/Vista/7. The available commands are listed here:
http://ss64.com/nt
For example, this will set the window to blue lettering on a yellow background: SYSTEM "COLOR 1E"
Note that the command is executed in a different instance of the command processor to MMBasic so some commands (like "CD ..") will have no effect.
SYSTEM allows you to use Windows system commends for a range of things - it's particularly useful for multiple file handling. You can do things like:
ProcessFolder:
'Create a DOS "DIR" command to list .txt files from the folder and re-direct
'the output .txt file list (filenames only) to a temporary data file "songlist.dat".
SYSTEM "DIR *.txt /B/O:N >songlist.dat" 'MS Windows comand
Songlist$ = Source$ + "songlist.dat" 'Build full filePath for songlist.dat
'Request file no. to process. Add folder path, process, then request next file.
Also you can build batch files to be executed, like:
'Read lyrics.txt file via lyricline$ variable into lyric$ array & count lines
FileLines = 0
Open FileName$ for input as #2
Line Input #2, lyricLine$
FileLines = FileLines + 1
lyric$(FileLines) = LyricLine$
Print "Line" filelines,lyric$(filelines)
Loop Until filelines = 12 'EOF(#2) shortened for testing********
Close #2
'Identify music codec file type via batch file & read music file name from Filename.txt
' *** add other music file types (aac, org etc) later ***
NameNoExt$ = left$(Filename$,len(Filename$)-4)
Open "FileName.bat" for Output as #2
Print #2, "If Exist "+chr$(34)+NameNoExt$+".mp3"+chr$(34)+" echo "+NameNoExt$+".mp3> Filename.txt"
Print #2, "If Exist "+chr$(34)+NameNoExt$+".m4a"+chr$(34)+" echo "+NameNoExt$+".m4a> Filename.txt"
Close #2
SYSTEM "FileName.bat > nul" 'Batch command file creates Filename.txt which
Open "FileName.txt" for Input as #2 'contains the music codec filename; if one exists.
Line Input #2, MusicFile$ 'Now can read music codec filename with extension.
Close #2
KILL "FileName.bat"
KILL "FileName.txt"
'Setup batch file to start iTunes playing
'OutputString$ command format: ...START "" "MusicFile$"...
'The "" is apparently necessary & normally encloses the window title.
Open "StartItunes.bat" for OUTPUT as #2
OutputString$ = "START "+chr$(34)+chr$(34)+" "+chr$(34)+MusicFile$+chr$(34)
Print #2, OutputString$
Print #2, "Exit"
Close #2
SYSTEM "StartItunes.bat > nul" 'Start the song playing
Kill "StartItunes.bat" 'Delete temporary file
'Note: We have to "mouse-click" back into the MMBasic DOS window after the song is started, before 'timestamping can commence.
Greg
Posted: 09:26pm 06 Sep 2015
Greg
Very useful - thanks.
Is there a way of getting MMBasic to accept parameters on the command line?
e.g.
MMBASIC cfgen.bas /f=test.elf /merge /o=myfile.basEdited by matherp 2015-09-08
Posted: 09:40pm 06 Sep 2015
I have optimized the increment4 subroutine a bit.
[code]
sub increment4(value$)
Local V$(7) LENGTH 1, i, NewValue$ LENGTH 8
for i= 0 to 7: V$(i) = mid$(value$, i+1, 1): next
V$(7) = Chr$(Asc(V$(7)) + 4)
for i = 7 to 1 step -1
v = Asc(V$(i))
if v > 70 then ' "F"
V$(i) = Chr$(v - 23): V$(i-1) = Chr$(Asc(V$(i-1)) + 1)
else
if v >57 and v < 65 then V$(i) = Chr$(v + 7) ' "9" "A"
endif
NewValue$ = V$(i)+ NewValue$
next
value$ = V$(0) + NewValue$
end sub
[/code]
Also you can use the VAL function to get the value of a HEX character
so instead of doing:
[code]
[/code]
you can do:
[code]
a = val("&H" + mid$(a$,5,1))
[/code]
Alternatieve for:
[code]
main$=s$
[/code]
is
[code]
main$= right$("00000000"+hex$(subtract(right$(main_offset$,5),right$(text_add$,5))),8) 'calculate the offset
[/code]
Still working on the decrement sub.:)
Posted: 09:51pm 06 Sep 2015
TZ
Great stuff
You will see the decrement routine is actually used in a loop to subtract two addresses so what is really needed is a routine that subtracts "12AB34CD" from "34CD12AB"
Thanks Peter
Posted: 10:03pm 06 Sep 2015
e.g.
Sort of...
MMBasic.ex will take a BAS file name on the commandline but that's all
I used this cludge to get a command line string to a BAS program
All it does is get your BAS program to read a known configuration/command line file.
Batch file:
echo. "more command line stuff" > temp.txt
"C:\Users\Jim\Documents\apps\maximite\DOS MMBasic\MMBasic.exe" test.bas
TEST.BAS
print "Welcome"
print mm.cmdline$
open "C:\Users\Jim\Documents\apps\maximite\DOS MMBasic\temp.txt" for input as #1
input #1, myfile$
close #1
print myfile$
print "Done"
You will need to edit the paths in both files.
Posted: 11:04pm 06 Sep 2015
Thanks to TZ I've improved all the calculation algorithms, unfortunately it doesn't make things much faster as most of the time is spent file positioning but it certainly looks cleaner.
' CFGEN.BAS V1.1
' V1.1 Improved algorithms thanks to TZ
' V1.11 Tidy Up
' Program to convert a .ELF file to Basic statements formated for use as CFunctions
' Load this program
' Type run
dim section_header, section_header_size, section_header_num
do
mode =0
PRINT #2,"'File "+cname$+".bas written "+DATE$+" "+Time$
SEEK #1, 0
dat$ = INPUT$(32, #1) ' Get the .elf identification and unused header
dat$=input$(4,#1)
dat$=input$(10,#1) 'step past the flags ,header size, and program header info
dat$=input$(2,#1)
dat$=input$(2,#1)
dat$=input$(2,#1)
seek #1,i
dat$=input$(4,#1)
k=getnum4(dat$)
s$=""
d$=input$(1,#1)
S$=S$+D$
d$=input$(1,#1)
loop
text_section=j
endif
symtab_section=j
endif
strtab_section=j
endif
next j
dat$=input$(12,#1)
dat$=input$(4,#1)
dat$=input$(4,#1)
dat$=input$(4,#1)
dat$=input$(4,#1)
seek #1,i 'point to the symbol table section header
dat$=input$(4,#1)
seek #1,i 'point to the string table section header
dat$=input$(4,#1)
k=getnum4(dat$)
dat$=input$(4,#1)
a$=getadd$(dat$)
dat$=input$(4,#1)
dat$=input$(1,#1)
l=asc(dat$)
s$=""
d$=input$(1,#1)
do while asc(d$)<>0
S$=S$+D$
d$=input$(1,#1)
loop
symbols$(m,1)=a$
symbols$(m,2)=s$
m=m+1
endif
next i
main$= right$("00000000" + hex$(subtract(right$(main_offset$,5), right$(text_add$,5))), 8) 'calculate the offset
k=0
currentfunction=0
s$=text_add$
for j=0 to m-1
currentfunction=j
k=0
endif
if not first then
print #2,"'"
endif
endif
first=0
endif
next j
branch$=subaddress$("0411FFFF",branchoffset)
else
endif
k=k+1
k=0
endif
next i
close #1
close #2
end
local f,g
f=val("&H"+b$)
g=VAL("&H"+c$)
subtract=(f-g)/4
end function
local f
f=VAL("&H"+a$)*4+1048576
end function
local a,b,c,d
getadd$=right$(hex$(d),2) +right$(hex$(c),2) +right$(hex$(b),2) +right$(hex$(a),2)
end function
local a,b,c,d
a=asc(left$(d$,1))
b=asc(mid$(d$,2,1))
c=asc(mid$(d$,3,1))
d=asc(right$(d$,1))
end function
local a,b
a=asc(left$(d$,1))
b=asc(right$(d$,1))
getnum2=b*256+a
end function
v = Asc(V$(i))
else
endif
next
end sub
function subaddress$(p$,b)
local a
a=val("&H"+RIGHT$(p$,4))+65536-b
subaddress$=left$(p$,4)+right$(hex$(a),4)
end function
disco4now
Posted: 02:05am 07 Sep 2015
Hi Peter,
Thanks for replacement CFunctGen. I have used your first posted version in anger and have successfully called DrawPixel using the MMBasic API.
I found it quite convenient to use via MMBasic, just run up a second copy of MMBasic and loaded CFunctGen.bas , remark out the prompts and hard code your file names etc and save a copy with the project name appended. This makes it easy to run multiple times as you do in development.
A good way to get long windows directory + file names into the clipboard is to open up the run dialogue and then drag the file to the input field. You can then get it from there into the clipboard and paste where you want.
So after being away for a couple of months away I am nearly caught up.
The C code below shows calling the DrawPixel routine in MMbasic from C via the MMbasic API.
* File: newmain.c
* Author: gallardice
* Created on 6 September 2015, 8:43 PM
#define _SUPPRESS_PLIB_WARNING
#include <plib.h>
#define FAM
#include "APIDefs.h"
#define DEVID (*(volatile unsigned int *)0xBF80F220)
#define PIC32MX170F256B_DEVID 0x06610053
#define PIC32MX270F256B_DEVID 0x06600053
#define PIC32MX170F256D_DEVID 0x0661A053
#define PIC32MX270F256D_DEVID 0x0660A053
#define HAS_28PINS ((DEVID & 0xfffffff) == PIC32MX170F256B_DEVID || (DEVID & 0xfffffff) == PIC32MX270F256B_DEVID)
long long drawPixel(long long *xp,long long *yp,long long *cp){
int x=*xp,y=*yp,c=*cp;
DrawPixel(x,y,c);
return(0);
//We need a main to keep the compiler happy
void main(){}
This is the CFunction generated by Peters program
CFunction drawPixel
00000000
27BDFFE0 AFBF001C 8C830000 8CA70000 3C029D00 8C420048 8CC40000 AFA40010
8C420000 00602021 00E02821 0040F809 00603021 00001021 00001821 8FBF001C
03E00008 27BD0020
End CFunction
Here is a snippet from MMBasic showing a loop writing two parrallel lines,
one via MMBasic command PIXEL and the other calling the CFunction drawPixel() which then calls the MMBasic binary via its API entry point DrawPixel.
dim result AS INTEGER
for I%=10 to 240 STEP 1
PIXEL I%-5,I%, RGB(green) 'MMBasic
result=drawPixel(I%,I%,RGB(red)) 'CFunction
NEXT I%
Thanks again Peter for all the good stuff.
Gerry
F4 H7FotSF4xGT
Posted: 03:26am 07 Sep 2015
Can someone send me an ELF file AND the created output file.
I want to test something and having a working example will greatly simply testing it.
Posted: 03:55am 07 Sep 2015
  Quote  Can someone send me an ELF file AND the created output file
Here you go:
2015-09-07_135511_ILI9325.zip
I use winmerge to check each modification doesn't compromise the outputEdited by matherp 2015-09-08
Posted: 03:59am 07 Sep 2015
does anybody know what happened to the support site for CFunctions? is it down temporarily?
rob :-)
paceman
Posted: 04:29am 07 Sep 2015
  matherp said   Greg
Very useful - thanks. Is there a way of getting MMBasic to accept parameters on the command line? e.g.
Not directly as I remember. Jim's method obviously works - the one in the middle box I posted above works well too but it's read from a batch file and called from the MMBasic program with SYSTEM.
For your development work, maybe a macro from MMEdit or TT could be used?
twofingers
Posted: 02:22am 08 Sep 2015
Thanks Peter!
Good job. I think I have never seen a (functional) program for MMBasic for DOS.
I assumed it was just for testing purposes ...
  matherp said   Unfortunately the support site for CFunctions is no longer online so I have programmed a clunky but workable replacement for CFuncGen
I hope Peter C. (G8JCF) is doing well!
Michael
Posted: 02:26pm 08 Sep 2015
Peter,
I have been playing with your cfungen program and converting it to a windows application.
So far I can agree with the example you provided. I do need to tidy up the user interface before I let you play with it.
I did find one bug.
I think
FOR i=1 TO symtab_num 'loop through all the symbols
should be
FOR i=0 TO symtab_num-1 'loop through all the symbols
As it stands your code ends up seeking beyond the end of the file.
I added a test
IF i >(symtab_num -2) THEN
PRINT "Woops! ",FORMAT$(k+symstr_offset, "%9.0f"),filesize
ENDIF
SEEK #1,k+symstr_offset 'point to the symbol name
and the resulting printout:
Woops! 184744 184755
Woops! 1651246464 184755
The first time the test is triggered, seek position is less than the file size but the second time, we are well over the file size.
MMBasic didn't throw an error but my PureBasic certainly did.
Posted: 10:33pm 08 Sep 2015
  Quote  I have been playing with your cfungen program and converting it to a windows application.
Excellent news. I've managed to spend an entire career in IT without ever having to do windows I/F work so your contribution will be greatly appreciated.
  Quote  I did find one bug.
Good catch, anyone using my code, please make the change.
Posted: 10:56pm 08 Sep 2015
  matherp said   I've managed to spend an entire career in IT without ever having to do windows I/F work so your contribution will be greatly appreciated.
Gui programming can be a pain, especially when Microsoft keep changing things.
I found a bug in MMEdit where it was not starting DOS basic in the correct folder.
It will be fixed in the next release.
Here is my attempt at CFUNCTION generator.
It has only been tested with the one ELF file so beware....
Usage:
select the ELF file
Select the destination file (if you cancel, you can do a dummy run)
Choose Merge or Join.
The result is printed to the text window and saved to your chosen destination.
I will add a few more sanity checks but I want to know that it works first.
2015-09-09_085634_cfgen.zip
Posted: 11:06pm 08 Sep 2015
First look, the live window looks OK but the file produced has the first value on the same line as the CFunction in join mode
e.g.
CFunction npins 00000000
3C02BF81 8C44F220 7C84D800 3C030661 3463A053 1083000B 2402002C 3C02BF81
8C43F220 7C63D800 3C020660 3442A053 00621026 2403001C 2404002C 0082180A
00601021 3C03BF81 8C64F220 7C84D800 3C030580 3463A053 00832026 24030040
0064100A 3C03BF81 8C64F220 7C84D800 3C030580 3463B053 00832026 24030064
0064100A 03E00008 00021FC3
End CFunction
Also, can you put a time and date in the file as a comment - I did this in my current version.
Finally, please could you arrange that pressing join or merge will cause the file to be regenerated each time they are pressed by re-reading the source. This will allow the program to be left open and just press the button each time you want to update after a new .ELF is producedEdited by matherp 2015-09-10
Posted: 02:21pm 09 Sep 2015
Fixed the layout problem with the file output - typo.
Added date as comment.
You can now rerun with the same file names as often as desired using 'Join' and 'Merge'
'New' lets you re-select the files.
As well as outputting to a file, the output is copied to the clipboard ready for pasting into a program.
Is there any call for the ability to read a commandline?
2015-09-10_002014_cfgen.zip
