Local Time 00:27 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PIC32MZ development board...
Posted: 04:22pm 28 Nov 2014
Element14 are selling this board with the MZ chip.
Not exactly cheap though. Does have USB, network and programmer/debugger on-board.
I have no idea if this is the correct MZ chip for the MZ Maximite though.
Come to think of it - is the MZ Maximite still on the development table, or has that been dropped in favour of further development of the Micromite?
hitsware
Posted: 07:31pm 28 Nov 2014
" MZ " ??
Posted: 09:58pm 28 Nov 2014
Put PIC32MZ into google
or go to link posted and use things there :)
Crazy price, should guarantee very slow take-up of the chips.
Probably (definitely?) still has the very bug-ridden silicon, too.
Equivalent chips from ST, Aw etc are cheap and their dev boards also cheap. E.g. ST board is about $25. Or A10 board is about $35
JohnEdited by JohnS 2014-11-30
Posted: 10:43pm 28 Nov 2014
I remember reading somewhere(here, I think it was) that the MZ chips had bugs, but I figured that if they are releasing evaluation boards now, that those bugs must have been fixed. The ones with the report of bugs were the pre-release samples, so I seem to remember.
Perhaps the juicy ARM CPU's might be the way to go with a new Maximite. A plethora of those chips available, with various number of cores and RAM configurations. And certainly much cheaper.
EDIT: ...like the A10 linked to above, or how about CuBox i2 with dual-core 1GHz, 1GB RAM, Network, HDMI, USB all in a tiny package for $80. Edited by Grogster 2014-11-30
JFlynn
Posted: 02:43pm 14 Dec 2014
If you are still interested, I just checked the U.S. site for Newark and they have Microchip dev boards. They have the same item you were asking about, but it appears to be much cheaper now, plus they have 15% off until 12/31. Here is the product link: http://www.newark.com/microchip/dm320006/dev-board-pic32mz20 48ec-mcu/dp/19X8473
Posted: 10:13pm 14 Dec 2014
Before buying it, might be worth checking if it has the CPU with all the horrid errata (I expect it does) and can you live with them.
It's still terribly expensive vs. other dev boards e.g. with ARM chips.
Posted: 10:50pm 14 Dec 2014
Just for this thread's information - no, I am not buying one of these. Too costly.
Gordz
Posted: 10:15am 17 Dec 2014
I have just made up a *small simple two layer board for evaluating this chip. If it tests out OK I am happy to release the gerber files for it.
Posted: 10:27am 17 Dec 2014
Hi Gordz,
It looks pretty compact..
Heaps of I/O Pins..
Good work,
Gordz
Posted: 12:37pm 17 Dec 2014
Cheers mate. It's bare bones really but I want to see how quick these chips really are, so there are a bunch of I/O that I could not route / was not worth the bother.
Posted: 12:41pm 17 Dec 2014
The pin-spacing on the QFP looks like fun.
What is that?
0.4mm?
Gordz
Posted: 12:52pm 17 Dec 2014
yes it's 0.4 mm. The pack is the 12x12mm 100 pin. The board you see has the 14mm chip but of course I have 12mm !! Are you the "Mite" man ?
Posted: 01:39pm 17 Dec 2014
If you are referring to the man who designed and made the MaxiMite computer and the MicroMite controller chip, then no - that is Geoff Graham.
I did make a few PCB's that I tacked "Mite" on to the end of - Expandamite and Videomite. Those were my designs, but the inspiration for which was totally because of Geoff Graham's creation.
0.4mm spacing would be fun to solder. Will you reflow that with a stencil and a SMD oven, or do you plan to hand-solder that beast?Edited by Grogster 2014-12-18
Gordz
Posted: 02:17pm 17 Dec 2014
Hand solder. I got some simple stuff from Jaycar and made up a cheap and cheerful SMD station. Should have done it years ago as it works surprisingly well.
Gordz
Posted: 02:19pm 17 Dec 2014
Here it is "laid" out. The fan and filter is also from them. Its way cheaper than a stereo microscope and a fume fan and light
Posted: 03:26pm 17 Dec 2014
That's clever, and less bulky then a lamp & fume extractor arrangement. Awesome. Where did you get the magnifying glass from? I can't find that one on Jaycar's site.
Gordz
Posted: 03:29pm 17 Dec 2014
Look here
http://www.jaycar.com.au/productView.asp?ID=QM3505&CATID=74& form=CAT2&SUBCATID=956#1
But watch out !! it'll set you back 9 bucks :)
Posted: 03:54pm 17 Dec 2014
Excellent - thanks for the link and idea - I think I am going to have to steal that one for my own workbench.
Gordz
Posted: 03:56pm 17 Dec 2014
No worries, let me know how you go once you've tried it
isochronic
Posted: 06:13pm 17 Dec 2014
There is a "PIM" with an mz ..I bought one but it is a uh next-year project for me,,it has all the capacitors installed but might only work with explorer16 I guess,
theoretically it should use icsp like anything else ?!
