Local Time 13:03 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Meter Clock
jman
Posted: 10:38pm 03 Jun 2014
Hi All
Thought I would post my meter clock in case anybody else wanted to make one
The images are a little fuzzy (TBS resize issue)
The PCB below is the version without the 5V regulator and PWM backlight
The PCB below is the version with the 5V regulator and PWM backlight
I have attached the circuit diagram, gerbers, meter scales and Micromite source should you wish to make your own.
I have a couple of both types of PCB should anybody want one unfortunately the both contain an error that requires a track to be cut a wire link to be added.
I will do this should anybody want one.
Meters were sourced on Ebay http://www.ebay.com/itm/271365409590?var=570246171842&ssPage Name=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
RTC Module also sourced on Ebay http://www.ebay.com/itm/ARM-RTC-I2C-DS1307-AT24C32-Real-Time -Clock-Module-2-8CM-x-2-7CM-/301141332978?pt=LH_DefaultDomai n_0&hash=item461d6c13f2
Basic operation as below
On first power up the meters will sweep from 0 to full twice
If the DS1307 has not had the time set before the seconds LED (D1) will be on.
To set the time press and hold the rotary decoder switch down for more than 3 seconds
This will allow the time to be set using the rotary encoder a second press of the rotary encoder button will set the minutes a third press
will save the time to the DS1307 and D1 will start to flash a 1 Hz
A short press of the rotary encoder button will allow the backlight brightness to be set using the rotary encoder in this mode a second press saves the brightness level to eeprom. If the power is lost the clock will get the time from the DS1307 and the brightness level from the eeprom.
The backlights are diffused LED’s of your colour choice these are fitted to the meters by drilling two appropriately sized holes (3mm or 5mm) at the bottom (two required) of the two meters.
The meter scales were done using MeterBasic from here http://www.tonnesoftware.com/meterbasicdownload2.html
The clock is powered by a DC source 7.5-12VDC 100ma is more than adequate
U3 is to set theDS1307 modules supply voltage Jumper on 1-2 is for 5V and 2-3 is for 3.3v Most will require 5v
Q1 is any general purpose PNP transistor
The rotary encoder connections are (1-2 switch) ( 3 common 4 is left and 5 is right)
Meter connections are 1-2 Minutes 3-4 Hours
The current PWM percentage and time is updated once minute and can be monitored via the serial port
If the brightness is adjusted this can also be monitored via the serial port.
Jman
2014-06-04_082300_MClock.zip
Frank N. Furter
Posted: 11:49pm 03 Jun 2014
Hi Jman,
very nice!!! COOL!!!
Thanks!
Frank
plasma
Posted: 07:31am 04 Jun 2014
this is sooo mad ! i like it!
Posted: 08:54am 04 Jun 2014
where's the seconds meter??
mindrobots
Posted: 09:33am 04 Jun 2014
Very clever! You see so many ways of displaying time, this could be a first for metered time!!
Thank you for such a complete project.
Rick
Posted: 11:15am 04 Jun 2014
Excellent Jman,
This is worthy of being published in a magazine.. Have you considered sending it to Silicon Chip or other Mag?
jman
Posted: 11:53am 04 Jun 2014
Hi
Thanks for the kind words
As luck would have it was published in Silicon Chip Circuit Notebook
this month
Jman
Posted: 12:20pm 04 Jun 2014
@John,
I have just read your article in June's SC magazine - NICE work. It is such a good use of the MicroMite utilising not only PWM, but also a rotary encoder.
But the thing that made me smile the most was that you were 'rewarded' a higher amount than the Arduino Alarm Clock on page 82 (and rightly so!!).
WW
PS: now I know why you didn't have a Second's meter (due to LED1
Posted: 12:24pm 04 Jun 2014
@John - I forgot to ask you in my previous post the following question; purely out of curiosity, what made you choose a DS1307 RTC over a PCF8563 for which the MicroMite has a built in function?
jman
Posted: 01:00pm 04 Jun 2014
@WhiteWizzard
1. I had one
2. really cheap small modules on Ebay
3. I like the free EEprom
4. Replaceable with a DS3231 module
Jman
vasi
Posted: 02:50pm 04 Jun 2014
Superb project!
Elvish name: Mablung Miriel
Beyound Arduino Lang
viscomjim
Posted: 04:49pm 04 Jun 2014
One day I hope to be able to bang out code as smooth as yours... Jyou'retheMAN!!!! Very nice project!
jman
Posted: 03:36pm 02 May 2015
So I finally put in a box that matches my Radio
Jman
viscomjim
Posted: 01:04am 03 May 2015
Nice work! This has been one of my favorite uMite "projects". The case looks great.
Edited by viscomjim 2015-05-14
viscomjim
Posted: 08:43am 13 May 2015
Jman, I used the link you provided for the meters from ebay. I checked them out and that listing has quite a few meter types to choose from using a drop down menu. Which ones did you wind up using for this project and why?
jman
Posted: 09:34am 13 May 2015
  viscomjim said   Jman, I used the link you provided for the meters from ebay. I checked them out and that listing has quite a few meter types to choose from using a drop down menu. Which ones did you wind up using for this project and why?
I used the 50UA meters as these only require 50UA for full scale deflection
Jman
viscomjim
Posted: 09:46am 13 May 2015
Got it! Thanks!
palcal
Posted: 12:20am 14 May 2015
A real cool project, I have ordered a couple of meters but larger than the ones you used. Would it be possible to make a 12 hour version, maybe with an indicator for PM.
Paul.
Justplayin
Posted: 07:37am 14 May 2015
  Quote  A real cool project, I have ordered a couple of meters but larger than the ones you used. Would it be possible to make a 12 hour version, maybe with an indicator for PM.
How about a meter that sweeps back and forth for the seconds? With the meter mounted upside down it would look sort of like a pendulum. It would give the clock some animation.
--Curtis
jman
Posted: 09:31am 14 May 2015
  palcal said   A real cool project, I have ordered a couple of meters but larger than the ones you used. Would it be possible to make a 12 hour version, maybe with an indicator for PM.
Paul.
Sure
Jman
