Forum Index : Microcontroller and PC projects : WeAct board with RP2350B won't boot
v.lenzer
Posted: 09:00pm 06 Aug 2026
I have a WeAct board with an RP2350B. I soldered a PSRAM chip onto the board, which is addressed via GP47. Previously, MMBasic V6.03.00 was installed, and I was able to run programs on it. Now I want to flash V6.03.01, but I haven't succeeded because the board won't boot. I’ve already tried all the tips found online (press and hold BOOT, connect USB-C, press RESET, release RESET, release BOOT). However, the board does not appear as a drive on my PC. I can rule out the cable as the source of the problem, as I successfully used it to flash other identical boards. The board that won't flash still connects to the terminal without issues, so it isn't defective. I can also rule out the PC, since I was able to flash all the other WeAct RP2350B boards using it. The only difference is that one board has PSRAM connected to GP0, while the others have no PSRAM.
Does anyone have any advice on how I can still flash this board?
Best wishes! Joachim
Posted: 09:41pm 06 Aug 2026
Either they have wired it wrong or you have soldered it wrong. The PSRAM chip shares the QMI bus with the main flash chip. If QMI is compromised then it won't boot
JanVolk
Posted: 10:03pm 06 Aug 2026
Joachim,
I have a board like that and have mounted PSRAM on it. It works fine with V6.03.00 and GP0 = PSRAM.
However, the CS operates via GP0, and I notice you’ve switched to GP47?
I don't have any experience with that yet, but I do plan to try it out using a separate wire connected to GP47.
The schematic shows the CS connected to GP0 via R14 (0Ω), so my plan was to locate and remove R14 and attach a separate wire instead.
The pull-up resistor R13 (10kΩ) is in the right place, and there is still room for a capacitor next to the PSRAM.
I imagine pin 1 (CS) of the PSRAM could be connected directly to GP47 using a short wire?
Jan.
v.lenzer
Posted: 10:31pm 06 Aug 2026
Hi Jan!
I simply bent Pin 1 of the PSRAM upwards and soldered a short wire to it. I connected the other end to GP47. I haven't soldered in the capacitor (yet).
Unfortunately, the resistor markings on the board are illegible even under a microscope, so I couldn't locate a jumper (0-ohm resistor).
However, I did measure a direct connection between GP0 and Pin 1 of the footprint. Since the pin on the PSRAM is bent up, though, it should work if you just connect Pin 1 to GP47.
I hope we're talking about the same board. Mine is this one:
JanVolk
Posted: 10:53pm 06 Aug 2026
Joachim,
That’s where the problem lies.
If you disconnect pin 1 from the board, the CS pin floats because the pull-up is no longer connected.
Leave pin 1 connected to the board, locate resistor R14 (0Ω), remove it, and install just the wire instead.
Jan.
v.lenzer
Posted: 10:56pm 06 Aug 2026
Peter, you're right. I removed the connection to GP47 and connected the PSRAM's CS to GP0. Now the RP2350B boots up again. Thanks for the tip.
@Jan: Thanks for your offer to test a change to the CS. That won't be necessary now.
PS: Hi Jan, our posts crossed.
Edited 2026-08-07 08:58 by v.lenzer
JanVolk
Posted: 11:11pm 06 Aug 2026
v.lenzer,
https://github.com/WeActStudio/WeActStudio.RP2350BCoreBoard/blob/main/HDK/RP2350B_SCH.pdf
Jan.
AlbertR
Posted: 08:18am 07 Aug 2026
v.lenzer
  Quote  Unfortunately, the resistor markings on the board are illegible even under a microscope, so I couldn't locate a jumper (0-ohm resistor).
I had identified it using the DMM
I wasn't sure if it would work because of the length of the wire.
But so far, everything seems to be working fine, even at 378 MHz.
Is there perhaps a program I can use to test it that puts a bit of a load on the memory?
Albert
Posted: 08:41am 07 Aug 2026
TBH I can't understand the thinking behind using GP47 for PSRAM CS. One of the big advantages of the RP2350 is having 8 ADC inputs accessible rather than 3/4 so it seems silly to throw one away. There are other choices for UART0 if that's the issue.
v.lenzer
Posted: 01:04pm 07 Aug 2026
Hi Albert!
Simply type "Memory" into the console. It will then show you 6 MB of RAM. You should also be able to flash MMBasic using this method.
I assume you removed R14, right?
Hi Mick!
You make a valid point. When I first started out here, I built a few circuits using the RP2040-Zero—some of them involving I2C. For those, I used GP0 and GP1 as the I2C interface. Recently, I put together another board and wanted to reuse my previous circuit designs. Since switching to GP47 for CS during the PSRAM installation looked easy, I gave it a try. Unfortunately, that led to the issues I already described ;). Also—silly as it sounds—GP47 was simply the pin left over in my layout.
Hi Peter!
Does the rule still stand that camera data pins above 32 cannot be used with V.6.03.01? If so, I’ll revise the layout for my motion detector. I’ve already ordered the OV5640 :)
Posted: 01:21pm 07 Aug 2026
For performance reasons the GPIO used for the camera data pins cannot straddle gp31/gp32 on the rp2350. You can use any set of 8 below or above the boundary
v.lenzer
Posted: 07:53am 08 Aug 2026
Hi Peter!
Thanks for the tip. I’ve already modified the PCB layout.
Please allow me one more question, even if it’s a bit off-topic: What clock rate did you specify?
javavi
Posted: 09:44am 08 Aug 2026
WeAct RP2350B PSRAM CS on GP47 MOD
WeAct_RP2350B_SCH.pdf
Edited 2026-08-08 19:49 by javavi
JanVolk
Posted: 03:29pm 08 Aug 2026
javavi,
Also a great solution for when the pins are already in place but there isn't much room for solder pads.
I used 0.32 mm enameled copper wire and secured it with superglue.
Now I just need to mount the assembly onto a perfboard and add a few other components for testing.
Jan.
Posted: 03:46pm 08 Aug 2026
For links like that I recommend 30 AWG silicone insulated wire. It's very flexible, very easy to strip and solder and, above all, the insulation doesn't melt and "run back". It's used a lot on drones.
Posted: 05:25pm 08 Aug 2026
  JanVolk said  Now I just need to mount the assembly onto a perfboard and add a few other components for testing.
Don't forget Mick's breakout board for the WeAct RP2350B.
(Though I didn't find this among the PCBs linked on his signature. I may be blind ;-} )
JanVolk
Posted: 05:51pm 08 Aug 2026
Lizby,
This board still has GP0 for PSRAM.
Jan.
Posted: 06:04pm 08 Aug 2026
The PSRAM isn't on Mick's PCB--it's on the WeAct board and you can do the same mod as shown above.
JanVolk
Posted: 06:05pm 08 Aug 2026
But after modifying the WeAct board, it works perfectly well.
Jan.
Posted: 06:17pm 08 Aug 2026
Nope, that board isn't on my list. I'm afraid the list is rather out of date. lol
I was never happy with the audio side of that. In fact, I've not really been happy with the I2S modules that I've tried. That may well be my fault.
