Local Time 20:09 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMEdit V5.4.2
Posted: 07:50am 05 Aug 2026
I have uploaded V5.4.2 to Geoff's website.
https://geoffg.net/mmedit.html
The Zoom feature seems to cause problems for some Windows users.
I have disabled it for Windows users and rely on the Windows built-in scale option as previously.
I am reasonable confident that the problems with the file manager have been fixed apart from the RPi version.
The RPi version has the file manager disabled due to problems I have yet to resolve.
There are a few places where I hope to speed up the response but that is for another time.
You can now "abort" a file transfer again. It may leave a bit of garbage on the terminal window but otherwise abort cleanly.
When transferring from the 'mite to the PC, the transfer is stored in a temporary file and only after a successful transfer is it renamed, overwriting any file of the same name. This prevents a failed transfer from deleting an otherwise good file.
Transferring to the 'mite will still overwrite any existing file of the same name. (I didn't want to run into any "out-of-memory" problems)
The Linux versions use the default browser for viewing the help files. This saves the problem with finding the correct support files for the internal browser.
There is a setting in the inf file if you want to change that.
I hope I have fixed or found a way around most of the outstanding bugs.
Posted: 08:07pm 05 Aug 2026
Sorry Jim,
Version 542:
When transferring  large files (10Mbyte) from PC to Pico (V60300) drive B to PC I get "no response found" error messages at irregular locations.
Some times at low block numbers (800 or 3500), sometimes at almost makes it to the end (89000 blocks). On the LCD display it reads "too many errors".
I also see dollar signs on the MMCC terminal.
MMCC 537 works fine.
This is linux Ubuntu 20.04 on a 2GHz I5 laptop. If you value, I can try to image the PC to Ubuntu 24.04, and see if that improves. I think MMCC uses Xmodem. On the A: drive of pico I get messages "Ymodem not supported". Is that correct ?
P.S. is it possible to use MMCC 537 in combination with MMEdit 542 ? To benefit from the new MMEdit, but keep the reliable MMCC.
Edited 2026-08-06 06:08 by Volhout
Posted: 09:34pm 05 Aug 2026
Sorry about the continuing problems.
First, yes you can use the later MMEdit with the older MMCC.
I don't want to go back to the earlier version if I can sort out where I have stuffed up.
I did a lot of testing with Linux Mint but all in a VM and files ~1.5MB. The VM will be different to a normal installation and I will have to work with a different setup in future.
In my RPi setup, I had problems with thread control and it is possible that you are seeing a similar issue.
For the RPi I am considering having the FileManager as a separate program to see if that will improve things.
MMCC first tries YMODEM and if that doesn't work, it reverts to XMODEM. Your failures are well past the area where it changes to XMODEM so that is not a problem.
The pico doesn't have enough ram? to do YMODEM to drive A:, only B:
Hence the error message while MMCC switch to XMODEM.
Posted: 10:30pm 05 Aug 2026
Jim,
I expected ram could be an issue, so I used a 2350 as well.
Posted: 12:51am 06 Aug 2026
There could be a few delays while saving to SD.
I can transfer 18MB files without any errors so far.
I will look at increasing the time MMCC waits for a response.
Current test setup:
Posted: 05:29am 06 Aug 2026
My test setup (target) is similar, only 4 MB flash. But A drive is not used.
In my case transfer speed is 50kB, not sure if that is important. The link opens at 115200 baud, but CDC USB should run much faster internally.
Edited 2026-08-06 15:32 by Volhout
Posted: 07:23am 06 Aug 2026
I find that the YMODEM transfer speed varies depending on content.
Text only files will reach 130kB/s while compressed binary files will run at 31kB/s
Could you try this MMCC. I have extended the time it waits for an <ACK>
MMCC.zip
I have been uploading files from 4MB to 80MB all day without any failures (before extending the wait time).
A very boring exercise!
Posted: 10:46am 06 Aug 2026
Hi Jim,
Tested on Ubuntu 20.04 this MMCC file manager works fine on 2040 and 2350.
Speeds on 2350 (mp3 file) was between 60 and 20 kB, on 2040 between 60 and 14 kB per second.
I tested large files, and multiple small files in batch copies back and forth.
Later today I will test the combination with MMEdit 542 (test if the complete IDE works).
P.S. there is one issue (that you may not be able to fix since it is probably in MMBasic): when a filename is legal in linux, but contains a comma "," it transfers correct from PC to pico. But the transfer back does not work. It starts erroring with a "short block" error message. When I change the file name on the pico to "test.mp3" the file transfers fine (back and forth). Again, this is something I noticed, and may not be worth fixing. Who in gods name would use a comma in a filename..???
Edited 2026-08-06 20:47 by Volhout
Posted: 11:26am 06 Aug 2026
Good to see it working at last.
I have a few concerns about file names, not just commas. I would like to have them changed by the program but it might cause more problems than it prevents.
I think that different mmbasic implementations have different requirements.
I will tidy up a few things and put the changes into the main download.
Thank for your perseverance.
Posted: 06:40pm 06 Aug 2026
Hi Jim,
Good news and bad news....
The good news is that MMCC 542 (new latest version) works correct.
The bad news is that I originally tested the wrong version. In the download was an MMCC executable I tested, but that was MMCC 535. Also in the zip was a tar.gz that contained MMCC 542.
This evening I tested MMCC 542, and it also works fine. But....
The reported transfer speeds of 50kB...14kB on 2040 are not achieved with 542.
On my laptop 17.4kB was the highest 542 manages on large files.
So 542 works correct, but is not as fast as 535 (and 537).
All 3 (535, 537 and 542 work from MMEDit 542).
P.S. the transfer speeds are important if you want to copy large files in the filemanager, but in typical development with MMEdit (programs smaller that 70kbyte) it is the difference between 2 or 4 seconds. Not a huge issue.
Edited 2026-08-07 04:42 by Volhout
Posted: 08:06am 07 Aug 2026
I have the speed back.
I need a bit of time to filter out some control codes that are getting in the way.
Things like <esc>[?7h
I should have something for you to test tomorrow.
Posted: 05:01am 08 Aug 2026
Does this speed look acceptable?
This is on Linux. Windows is slightly slower.
It does depend on the file type.
Tick the new option "Use temp file" and transfers to the 'mite will go to a temporary file then, when completed, rename to the target name.
Going to the PC will always use the temp file.
Linux version:
MMCC.zip
Windows version:
MMCC_windows.zip
Posted: 08:32am 08 Aug 2026
Hi Jim,
Tested the new MMCC and there are 2 remarks on Ubuntu 20.04.
1/ The speed I achieve (on RP2040 GEEK running 200MHz) is 52kbps towards the pico. But that is back to "normal" since that is also roughly what 535/537 achieves.
2/ One problem is that uploading back to the PC, there is in many cases no popup showing progress (see 4). I tried repowering GEEK, restarting MMCC, but there is no progress popup. In the end the file is transferred, but no progress.
3/ On large files, only part of the file is transferred. Exactly 10Mbyte is missing.
As you can see 11455360 bytes are transferred to B drive of pico. But trying to transfer this same file back to the PC indicates 1455360 bytes are transferred. And indeed, the file size on the PC is 1Mbyte (not 10Mbyte).
4/ maybe relates to issue 2. Above screenshot is taken on a transfer that disabled YMODEM (to force XMODEM). When you enable YMODEM, there is a double "reverting to XMODEM". The "long block" error messages are because I interrupted the transfer. They normally do not show. You simply get a message saying "finished".
So there is no progress popup on XMODEM when YMODEM is enabled, but XMODEM is selected anyway. But there is a progress popup when YMODEM is disabled.
P.S. speed from pico to PC is 25kbps.
Edited 2026-08-08 18:39 by Volhout
Posted: 07:09pm 08 Aug 2026
Jim,
After re-reading my message, it confuses even me. Must confuse you too.
2 issues with filemanager
1/ When a large file (10Mbyte) is written to pico B drive, copying it back to the PC only copies part of it. 1MB in stead of 10MB.
2/ When YMODEM is enabled, and MMCC decides to use XMODEM, there is no progress popup. When YMODEM is disabled, there is a progress indicator with XMODEM transfers.
Posted: 10:10pm 08 Aug 2026
Volhout,
Thank you for clarifying the problem.
As soon as I read that last post, I was certain that I know the reason for part file transfers.
There are a number of ways the files command lists the files. I have to work out which method is used for each version on MMBasic.
I had made an error in the retrieving the file size from the listing, chopping off the high digits.
Easy to fix.
The missing pop-up is more interesting. It is there when I am running a debug session but not in the final release.
It is there on Windows.
That might take a bit more fiddling to sort out but it is important to have.
I also have to filter out the VT commands so I can remove the double "revert to XMODEM"
Lucky it is  a wet day today.
Bryan1
Posted: 10:29pm 08 Aug 2026
Jim does MMEdit work with micro python mate and if so I can give it a good test as my club.py file is now over 5,000 lines long
It would be nice to see the code colour coded as it could give me a good idea of the program flow.
Now what I've been doing which has been rock solid but a pain is taking the SD cards out and put them on the computer, copy the code from Claude then with a notepad file go Cntrl-A, backspace then paste. Then saveas club.py on the SDCard, put the second one in then do the same.
Now I did find trying to use teraterm it would auto indent and make the code as wide as it was deep and not run as so many indent errors came up.
The code is now upto 0.50 which is 50 times I've done this method.
Regards Bryan
Posted: 12:53am 09 Aug 2026
  Quote  Jim does MMEdit work with micro python mate
No, I have enough trouble with MMBasic...
Bryan1
Posted: 04:49am 09 Aug 2026
Jim when I went with code and github now all I need to do is have the SDCard mounted and Claude will do all the work.
Now for reading the code the gihub site does a good listing the code so that will have to do for now
Posted: 07:23am 09 Aug 2026
Volhout,
Some progress today. I am not going to get too excited yet.
The progress indicator is now a standard progress bar.
Files larger than 10MB now transfer.
I have cleaned up some of the error messages.
Still a lot to do but I hope this is usable.
Windows:
MMCC_windows.zip
and Linux:
MMCC.zip
Edited 2026-08-09 17:24 by TassyJim
Posted: 01:14pm 09 Aug 2026
Hi Jim,
I am happy with this version for MMCC. Transfers between PC and pico work well, and the main interactions with MMEdit work great (listing->editor, and editor->pico and run, and run in MMB4L).
Needless to say I did not test all other MMEdit functions yet. But interaction MMCC-MMEdit works fine.
Thank you for your persistance in helping use. MMEdit is a great tool, could not live without it.
P.s. the progress indicator is nice!
Edited 2026-08-10 03:42 by Volhout
