Local Time 07:31 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : framebuffer lcd
     Page 1 of 3
Posted: 06:34pm 09 Aug 2025
Hi. please help, using
PicoMite MMBasic RP2350A Edition V6.00.02
ili9341 lcd and tried "lissajours" prog that works vga and hdmi but not lcd, just draws graticule.
I tried FRAMEBUFFER merge F,L,N no luck
'MODE 5
Option ANGLE DEGREES
FRAMEBUFFER CREATE
FRAMEBUFFER LAYER
RX=MM.HRes:RY=MM.VRes:CX=RX\2:CY=RY\2
Scale=0.95: AX=CY*Scale: AY=CY*Scale
a=1: b=0: p=0: f=0: c=0
CLS RGB(BLack)
RBox 0,0,RX,RY
For y=80 To RY Step 80
For x= 8 To RX Step  8
Pixel x,y
Next x:Next y
For x=80 To RX Step 80
For y= 8 To RY Step  8
Pixel x,y
Next y:Next x
For y=0 To RY Step 8
Line CX+1,y,CX-1,y
If Not (y Mod 40) Then Line CX+2,y,CX-2,y
If Not (y Mod 80) Then Line CX+3,y,CX-3,y
Next y
For x=0 To RX Step 8
Line x,CY+1,x,CY-1
If Not (x Mod 40) Then Line x,CY+2,x,CY-2
If Not (x Mod 80) Then Line x,CY+3,x,CY-3
Next x
Triangle CX,0,CX-3,8,CX+3,8,,1
Triangle RX,CY,RX-8,CY-3,RX-8,CY+3,,1
'Print @(CX-14,3) "Y"
'Print @(RX-12,CY-16) "X"
FRAMEBUFFER WRITE F
If p>360 Then p=0: EndIf
If b>6   Then a=a+1: b=0: c=0: EndIf
If a>5   Then a=1:   b=0: c=0: EndIf
If c=50  Then
  f=1
  If a=Fix(b) Then f=0: c=0: EndIf
If c=130 Then f=0: c=0: EndIf
CLS 0 : Colour RGB(WHITE),RGB(BLUE)
'Print : Print " A="a: Print " B="b: Print " P="p
    sx= AX * Sin(p) + CX
    sy= AY * Sin(p) + CY
For i= 0 To 360
    x = AX * Sin(a*i + p) + CX
    y = AY * Sin(b*i + p) + CY
    Line sx,sy,x,y
    sx=x: sy=y
Next i
FRAMEBUFFER copy F,L,B
'FRAMEBUFFER merge F,L,N,b
Inc p: Inc c
If  f=0 Then b=b+.02
Posted: 05:19am 10 Aug 2025
As your program is intended for a RP2350 with 320 x 240 panel and I am using a RP2040 with 480 x 320 panel there isn't enough memory for FRAMEBUFFER LAYER as well as framebuffer “F” so modified it a bit to get it to run. As expected on this setup it is a bit slow but runs ok.
Dim RX=MM.HRES, RY=MM.VRES, CX=RX\2, CY=RY\2
Dim Scale=0.95, AX=CY*Scale, AY=CY*Scale
Dim a=1, b=0, p=0, f=0, c=0
FRAMEBUFFER CREATE
 FRAMEBUFFER WRITE F
 CLS RGB(BLack)
 RBox 0,0,RX,RY
   Pixel x,y
  Next x
 Next y
   Pixel x,y
  Next y
 Next x
  Line CX+1,y,CX-1,y
 Next y
  Line x,CY+1,x,CY-1
 Next x
 If c=50  Then
  f=1
'   Print : Print " A=";a, " B=";b, " P=";p
 For i= 0 To 360
   Line sx,sy,x,y
   sx=x: sy=y
 Next i
 FRAMEBUFFER copy F, N
 Inc p: Inc c
 If  f=0 Then b=b+.02
If this code runs for you you can then try adding FRAMEBUFFER LAYER.
Edited 2025-08-10 17:49 by phil99
Posted: 04:21pm 10 Aug 2025
cheers phil99 for the reply.
point is why the code works hdmi and vga but not 320x240 ili9341, read the manual and seems ok.
I did oscilloscope on same lcd with graticule drawn once and scope display on top and then send to the screen, ok.
the idea is draw the graticule once on a layer. I can do without the graticule and just the Lissajous. stan
Posted: 03:33am 11 Aug 2025
Replaced the ILI9488 with a ILI9341, allowing smaller framebuffers so 2 will fit in memory.
Messed about with layers etc till it worked with the graticule. Could not get the [,B] parameter to work properly with most of the Lissajous missing. Maybe that is only for the RP2350?
Anyway this works smoothly without ,B on a RP2040 so may be even better on a RP2350.
FRAMEBUFFER CREATE
 FRAMEBUFFER LAYER
 CLS 0 'RGB(BLack)
 RBox 0,0,RX,RY
   Pixel x,y
  Next x
 Next y
   Pixel x,y
  Next y
 Next x
  Line CX+1,y,CX-1,y
 Next y
  Line x,CY+1,x,CY-1
 Next x
 FRAMEBUFFER copy N, F
 CLS 0 'RGB(BLack)
 FRAMEBUFFER copy F, L
 If c=50  Then
  f=1
 For i= 0 To 360
   Line sx,sy,x,y
   sx=x: sy=y
 Next i
 FRAMEBUFFER WRITE L
 FRAMEBUFFER copy L, N
 Inc p: Inc c
 If  f=0 Then Inc b,0.02
End
Edit.
I don't fully understand the manual description either, this was done by trial and error.
Your original program with comments to show what I changed to get it working.
FRAMEBUFFER CREATE
FRAMEBUFFER LAYER
RX=MM.HRES:RY=MM.VRES:CX=RX\2:CY=RY\2
CLS 'RGB(BLack)
RBox 0,0,RX,RY
For y=80 To RY Step 80 : For x= 8 To RX Step  8
  Pixel x,y
Next x:Next y
For x=80 To RX Step 80 : For y= 8 To RY Step  8
  Pixel x,y
Next y:Next x
 Line CX+1,y,CX-1,y
Next y
 Line x,CY+1,x,CY-1
Next x
'FRAMEBUFFER WRITE F  'changed this
FRAMEBUFFER copy N, F 'to this
 FRAMEBUFFER copy F, L  'added this
 If c=50  Then
   f=1
'CLS 0 :  'removed this
 For i= 0 To 360
  Line sx,sy,x,y
  sx=x: sy=y
 Next i
 FRAMEBUFFER WRITE L  'added this
 FRAMEBUFFER copy L, N  'changed this
 Inc p: Inc c
 If f=0 Then b=b+.02
End
Edited 2025-08-11 15:49 by phil99
Bleep
Posted: 03:58pm 11 Aug 2025
Remember that the B option is asynchronous, so if you trigger a background frame buffer copy and then immediately start redrawing the screen, you will get some combination of the original screen you had drawn before doing the copy and parts of any new screen updates you do after doing the background copy. To prove to yourself this is the case, simply do a pause 100 or whatever is necessary to give you the correct screen updates immediately after the background copy is requested, unfortunately this very approximately will use the same amount of time as if you had not used the B option.
The advantage of the B option is that you perform some other calculations immediately after issuing the background copy and save the writing to screen till later, when hopefully the background copy has completed.
Regards Kevin
Posted: 05:39pm 11 Aug 2025
well the ili9341 2350 is stuck
the screen says error unknown command
Frame write L
it should be framebuffer write L but the message appears on lcd on powerup.
it crashes mmcc.
FRAMEBUFFER CREATE
FRAMEBUFFER LAYER
framebuffer write L' added this
CLS RGB(BLack)
RBox 0,0,RX,RY
Pixel x,y
Next x:Next y
Pixel x,y
Next y:Next x
Line CX+1,y,CX-1,y
Next y
Line x,CY+1,x,CY-1
Next x
FRAMEBUFFER WRITE F
If c=50  Then
  f=1
For i= 0 To 360
    Line sx,sy,x,y
    sx=x: sy=y
Next i
FRAMEBUFFER copy F,L,N',b
'FRAMEBUFFER merge F,N
Inc p: Inc c
If  f=0 Then b=b+.02
Posted: 11:36pm 11 Aug 2025
Another working version with comments
FRAMEBUFFER CREATE
FRAMEBUFFER LAYER
FRAMEBUFFER write L '<===== Write the following to Layer L
CLS '<========= Black is the default transparent colour
Colour RGB(Blue),0 '<========== choose graticule colour
RBox 0,0,RX,RY
Pixel x,y
Next x:Next y
Pixel x,y
Next y:Next x
Line CX+1,y,CX-1,y
Next y
Line x,CY+1,x,CY-1
Next x
FRAMEBUFFER WRITE F '<===== Write the following to Layer F
If c=50  Then
 f=1
CLS RGB(Myrtle) '<= choose Background Colour from the RGB121 palette
For i= 0 To 360
   Line sx,sy,x,y,,RGB(Yellow) '<= choose Foreground Colour for plot
   sx=x: sy=y
Next i
FRAMEBUFFER MERGE '<======== copy both layers to the screen
Inc p: Inc c
If  f=0 Then b=b+.02
Edited 2025-08-12 12:00 by phil99
Posted: 10:40am 12 Aug 2025
Hi phill,
Thanks for the demo. This is in essence the basic under petscii robots on the game*mite, but neatly commented... Very nice..
Posted: 10:54am 12 Aug 2025
Don't you want the plot on top of the graticule?
Posted: 01:19pm 12 Aug 2025
Ok, reversed the layers.
FRAMEBUFFER CREATE
FRAMEBUFFER LAYER
CLS 0'<========= Black is the default transparent colour
Colour RGB(Blue),0 '<== choose graticule colour from the RGB121 palette
RBox 0,0,RX,RY,10,,RGB(Myrtle) '<=========== choose Background Colour
Pixel x,y
Next x:Next y
Pixel x,y
Next y:Next x
Line CX+1,y,CX-1,y
Next y
Line x,CY+1,x,CY-1
Next x
FRAMEBUFFER WRITE L '<===== Write the following to Layer L
If c=50  Then
 f=1
For i= 0 To 360
   sx=x: sy=y
Next i
Inc p: Inc c
If  f=0 Then b=b+.02
End
Posted: 01:47pm 12 Aug 2025
With no changes, on an RP2350A with ILI9488 LCD.
Posted: 03:39pm 12 Aug 2025
Peter,
A real oscilloscope (CRT) has the graticule in front of the phosfor.
Later models wrote the graticule onto the same phosfor, but die to both being the same color you could not tell the difference.
Posted: 05:33pm 12 Aug 2025
original listing looks like this mode 5 hdmi
Posted: 08:09pm 12 Aug 2025
I wrote a simple test prog that draws a box on layer L and circles on frame F and framebuffer merge and works but not framebuffer copy??
cls
FRAMEBUFFER CREATE
FRAMEBUFFER LAYER
framebuffer write L
box 50,50,150,50,4,rgb(blue)
framebuffer write F
do
for n=5 to 60
circle 125,75,n,,,rgb(gold)
'FRAMEBUFFER copy L,F',b
'FRAMEBUFFER copy F,N',b
FRAMEBUFFER merge
pause 20
next n
for n=5 to 60
circle 125,75,n,,,rgb(black)
FRAMEBUFFER merge
pause 20
next n
loop
> option list
PicoMite MMBasic RP2350A Edition V6.01.00b2
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION CPUSPEED (KHz) 378000
OPTION LCDPANEL ILI9341, LANDSCAPE,GP15,GP14,GP13
OPTION LCD BACKLIGHT 0
OPTION TOUCH GP12,GP11
GUI CALIBRATE 0, 3931, 3851, -872, -662
OPTION SDCARD GP22
Posted: 08:59pm 12 Aug 2025
Does this work? please see my test prog above
NOT HDMI AND VGA VERSIONS
FRAMEBUFFER COPY
from, to [,b]
Does a highly optimised full screen copy of one framebuffer to another.
"from" and "to" can be N, F, or L where N is the physical display.
You can only copy from N on displays that support BLIT and transparent text.
The firmware will automatically compress or expand the RGB resolution when
copying to and from unmatched framebuffers.
Of course copying from RGB565 to RGB121 loses information but for many
applications (eg, games) 16 colour levels is more than enough.
When copying to an LCD display the optional parameter “b” can be used
(FRAMEBUFFER COPY F/L, N, B). This instructs the firmware to action the
copy using the second CPU in the Raspberry Pi Pico and control returns
immediately to the Basic program
Posted: 03:44am 13 Aug 2025
In this version Copy is almost the same as Merge. However with Copy drawing the black circles overwrites the blue box but if you uncomment FRAMEBUFFER merge and comment the next line the blue box doesn't get overwritten.
It appears Merge writes F first then puts L on top so they have been swapped compared to your original.
CLS
FRAMEBUFFER CREATE
FRAMEBUFFER LAYER
FRAMEBUFFER write F
Box 50,50,150,50,4,RGB(blue),RGB(Black)
FRAMEBUFFER write L
 For n=5 To 60
  Circle 125,75,n,,,RGB(gold)
  Pause 20
 Next n
 For n=5 To 60
  Circle 125,75,n,,,RGB(black)
'   FRAMEBUFFER merge
  Pause 20
 Next n
Edited 2025-08-13 13:52 by phil99
mozzie
Posted: 05:02am 13 Aug 2025
G'day,
I think what Stan has encountered is the same problem seen here, I assumed it was my own stupidity so left it go
Tested on ILI9341 and ILI9488:
FRAMEBUFFER MERGE 0: locks up PicoMite - ctrl c does nothing
FRAMEBUFFER MERGE 0,B: Does not lock up PicoMite - NO output to display
Also tried other combinations, same outcome.
ILI9488 has MISO disconnected.
Option default integer
FRAMEBUFFER create
FRAMEBUFFER layer
FRAMEBUFFER write l
Box 100,50,200,100,4,RGB(blue)
FRAMEBUFFER write f
Box 125,75,150,50,4,RGB(blue)-1
'FRAMEBUFFER copy l,f
'FRAMEBUFFER copy f,l
'FRAMEBUFFER copy l,n
'FRAMEBUFFER copy f,n
FRAMEBUFFER merge 0
'FRAMEBUFFER merge 0,b
Print "Done"
End
> option list
PicoMite MMBasic RP2350A Edition V6.00.03
OPTION CPUSPEED (KHz) 150000
OPTION LCDPANEL ILI9488, LANDSCAPE,GP14,GP13,GP12
OPTION TOUCH GP15,GP17
GUI CALIBRATE 0, 4200, 3986, -1202, -827
> option list
OPTION LCDPANEL ILI9341, LANDSCAPE,GP14,GP13,GP12
Lyle.
Posted: 06:15am 13 Aug 2025
FRAMEBUFFER merge 0 works fine on this:-
> option list
PicoMite MMBasic RP2040 Edition V6.00.03
OPTION SYSTEM SPI GP18,GP19,GP20
OPTION FLASH SIZE 16777216
OPTION CPUSPEED (KHz) 200000
OPTION DISPLAY 55, 133
OPTION LCDPANEL ILI9341, LANDSCAPE,GP15,GP14,GP13,GP16
As do colours 1 to 15.
mozzie
Posted: 06:30am 13 Aug 2025
G'day Phil,
Hopefully that means its confined to my / Stans setup or only RP2350 versions.
I don't have a RP2040 with enough memory connected to an LCD to test.
Can anyone else please try on RP2530 and confirm?
Lyle.
Posted: 06:33am 13 Aug 2025
mozzie
The "FRAMEBUFFER merge 0" problem with 2350 platforms must be brought to Peter's attention. Maybe make a bug report in the 6.01.00 thread.
I have not run into it yet, but would otherwise very soon (trying to make a game for game*mite).
     Page 1 of 3
