Forum Index : Microcontroller and PC projects : PicoMite V6.00.02
| Page 1 of 3 |
PicoMite V6.00.02 is now available from Geoff's site https://geoffg.net/picomite.html Source code and binaries on Github The manual has been updated but please leave comments on this thread for anything we have left out or any errors Installing this will re-initialise all flash and options etc. Release Notes Changes from 6.00.01 Bugs fixed Various fixes to OPTION LIST Fixes bug in forward references in PIO assembler when the starting line number is > 1 Fixes bug in PRINT @(x,y) when outputting to a computer console By default disables heartbeat and enables access to all pins on RP2350B Allows selection of GP19 for PSRAM PIN Fixes bug in TILE HEIGHT 12 command in PicoMiteVGA Fixes bug in TILE HEIGHT command in PicoMiteHDMI[USB] setting the screen to white Fixes bug in LINSTR changing the regular expression if a variable Fixes various bugs in PIO assembler Fixes bug in DMA to/from PIO2 on the RP2350 Fixes memory leak in PLAY MP3 when using SPI audio Fixes bug causing crash when trying to play all audio files in a directory if the number exceeds 20 Fixes bug in LINE PLOT Fixes bug with ADC when system clock is above about 252MHz Fixes onewire/tempr functionality when using parasitic connection Changes initialisation of HDMI pins to increase drive needed for some monitors Fixes bug in EDIT "b:/filename" giving heap memory error New Commands and Functions (see manual for full details Command BIT(var%,bitno)=0 or 1 'sets a specific bit (0-63) in an integer variable Function BIT(var%,bitno) 'returns the value of a specific bit (0-63) in a integer variable (0 or 1) These make it very easy to use flags in a program with minimum memory usage Command BYTE(var$,byteno)=0 to 255 ' sets a specific byte in a string to an integer value function byte(var$,byteno) 'returns the integer value of a specific byte in a string (0-255) Command FLAG(bitno)=0 or 1 ' 'sets a specific bit (0-63) in the system flag register function FLAG(bitno) 'returns the value of a specific bit (0-63) in the system flag register Functions MM.HRES, MM.VRES, MM.VER, M.I2C, MM.FONTHEIGHT, MM.FONTWIDTH, MM.PS2, MM.HPOS, MM.VPOS, MM.ONEWIRE, MM.Errno, MM.ErrMsg$, MM.WATCHDOG, MM.DEVICE$ are now all implemented as written and none of them are converted to MM.INFO calls by the pre-processor function TEMPR(Pinno [,timeout]) 'new optional parameter timeout to override the default (200mSec) to allow for slow devices command TEMPR START GPno [,resolution(0-3)] [,timeout] 'new optional parameter timeout to override the default (100, 200, 400, or 800mSec) to allow for slow devices CHAIN fname$ [,cmdline$] ' Allows the program to run another program with the variable space preserved - command is recommended to be used in top level program and not from within a subroutine (may work OK but not tested for side-effects) AVE CONTEXT [CLEAR]' saves the variable space and optionally clears it - command should be used in top level program and not from within a subroutine (may work OK but not tested for side-effects). If used in a subroutine a subsequent LOAD CONTEXT must DEFINITELY be in the same subroutine or a crash/corruption will DEFINITELY happen. LOAD CONTEXT [KEEP]' restores the variable space to the previously saved state and optionally preserves the stored variables to allow a second LOAD if required. RAM command (RP2350 with PSRAM only) functions like the FLASH command with 5 program slots available in PSRAM. All commands except RAM LOAD (copies a RAM slot to the main flash program space) can be used in a program. RAM FILE LOAD n,fname$ [,O[VERWRITE]] can be used to load a RAM slot from a standard disk .BAS file SAVE PERSISTENT n% 'saves the value n% in memory that will survive a watchdog reset (RP2040 and RP2350) or a physical reset (RP2040 only) MM.INFO(PERSISTENT) ' recovers any value saved as above PIO CONFIGURE OPTION CONTINUATION LINES ON/OFF HELP command ARRAY command Changes and enhancements the default CPU speed for the standard RP2040 PicoMite is now 200MHz. Raspberry Pi have now officially approved the RP2040 for that speed with a voltage of 1.15V which is what is set Changing MODE to be the same now clears all framebuffers etc. Layer buffer now available in VGA mode 1 (252MHz and above) and all HDMI mode 1 resolutions Supports ; at the end of LONGSTRING PRINT to suppress the CR/LF I2C(2) OPEN now supports 1000 as a speed FILE command can now be used in a program EDIT FILE command used in a program will now only be memory limited the same as EDIT SHIFT-F3 to F10 now work for computer console. NB: Shift-F1, F2, F11, and F12 don't appear to send codes so can't work PLAY MODFILE will preferentially use space in PSRAM if enabled for the file buffer (RP2350 only). In this case a modbuffer does not need to be enabled with the OPTION command OPTION AUDIO I2S BCLKpin, DATApin This allows a I2S DAC to be used to provide high quality Audio. The firmware transmits the data in 32-bit mode and FLAC, MP3 (RP2350 only), and WAV data is output with no loss of information. This command reserves BCLKpin and BCLKpin+1 for the bit clock and word clock and Datapin for the I2S data. It requires an I2S DAC that can PLL the bitclock to create its own master clock. Tested on PCM5102A and TDA1387T . For example: OPTION AUDIO I2S GP1,GP5 GP1 is the bit clock GP2 is the word clock GP5 is the data pin All normal audio should work TONE, MP3 (RP2350 only), FLAC, WAV, MOD, SOUND PIO INIT MACHINE pio%, statemachine%, clockspeed [,pinctrl] [,execctrl] [,shiftctrl] [,startinstruction] [,sideout [,setout] [,outout] sideout, setout, and outout can be set to 0 (default) or 1 to specify if pins defined in pinctrl should be initialised as inputs (0) or outputs (1) MM.INFO(BOOT) Tells you the reason for the last restart of the Pico Returns: Restart - the device has been restarted with CPU RESTART or an OPTION command S/W Watchdog - the device has been restarted by a software watchdog timeout H/W Watchdog - the device has been restarted by a hardware watchdog timeout Firmware update - the device has been restarted following a firmware update Power On - the device has been powered up Reset Switch - the device has been restarted using the reset switch Unknown code &Hn - unknown reason - please report the code and version RP2040/2350 LIST PINS - lists the current status of all pins on the processor PIO code can now be inserted directly into Basic between a call to PIO ASSEMBLE and .end program. All PIO instructions are included as MMBasic commands including the 6 directives Includes support for FT6336 capacitive touch chip OPTION TOUCH FT6336 IRQpin, RESETpin [,BEEPpin] [,sensitivity] sensitivity is a number between 0 and 255 - defaults to 50, lower is more sensitive. SDA and SCK should be connected to valid I2C pins and set up with OPTION SYSTEM I2C TOUCH function works as before + TOUCH(X2) and TOUCH(Y2) returns the position of a second touch location or -1 if no second location is touched. LIST SYSTEM I2C Produces a display showing the addresses of all I2C device connected to the SYSTEM I2C pins New PIO functionality for RP2350A and RP2350B Adds MOV PINDIRS,src as valid instruction Adds support for 'prev' and 'next' for the IRQ command New PIO functionality for RP2350B PIO SET BASE pionum, n 'sets the base of logical PIO pins to 0 or 16 to allow pins GP30-47 to be used for PIO Use GAMEPAD MONITOR before plugging in a gamepad and when plugged in it will show the before and after report with each change of buttons Use GAMEPAD CONFIGURE vid,pid,i0,c0,i1,c1,i2,c2,i3,c3,i4,c4,i5,c5,i6,c6,i7,c7,i8,c8,i9,c9,i10,c10,i11,c11,i12,c12,i13,c13,i14,c14,i15,c15 to set up a gamepad that isn't supported before plugging it in. All 34 parameters are mandatory. New functionality from Geoff - with thanks Now supporting BYVAL & BYREF. BYVAL & BYREF are prefixes that can be applied to parameters in the definition of a sub or function. BYVAL will force the interpreter to use the value of the supplied argument even if a variable is supplied. BYREF informs the interpreter that a variable is expected and if that is not supplied it will throw an error. Additional parameter for OPTION LCDPANEL paralleldisplaytype (e.g. SSD1963_7[_16]) OPTION LCDPANEL display, orientation [,backlightpin] [,DCpin] [,NORESET] [,DB0pin] The new parameter only applies to the RP2350B and allows the starting pin for the 8 or 16 data pins to be specified (defaults to GP0) e.g. OPTION LCDPANEL SSD1963_4_16, LANDSCAPE,,,GP36,,GP2 This allows SSD and other parallel displays to be used on the new 64-pin DIL development board New LCDs supported ST7796S 480x320 ST7796SP 320x320 ILI9488P 320x320 For all SPI displays in portrait mode, H/W vertical scrolling is now enabled Allows seek to increase file size on the A: drive Adds support for additional gamepads 126MHz operation no longer supported for VGA versions - now defaults to 252MHz Changes are to the VGA variants and the default frequency for HDMI 640x480 OPTION CPUSPEED is removed from VGA variants OPTION WIDESCREEN is removed from VGA variants HDMI and VGA now both use OPTION RESOLUTION and the 640x480 CPU speeds are now set the same by default. All variants OPTION RESOLUTION 640 [,252000] 'sets the firmware to run at 252MHz - 640x480 refresh rate 60Hz OPTION RESOLUTION 640, 315000 'sets the firmware to run at 315MHz - 640x480 refresh rate 75Hz OPTION RESOLUTION 720 'sets the firmware to run at 283.2MHz - 720x400 refresh rate 60Hz VGA only OPTION RESOLUTION 640, 378000 'sets the firmware to run at 378MHz - 640x480 refresh rate 60Hz RP2350 only OPTION RESOLUTION 848 'sets the firmware to run at 336MHz - 848x480 refresh rate 60Hz OPTION RESOLUTION 800 'sets the firmware to run at 360MHz - 800x600 refresh rate 56Hz HDMI only OPTION RESOLUTION 1024 'sets the firmware to run at 324MHz - 1024x768 refresh rate 60Hz OPTION RESOLUTION 1280 'sets the firmware to run at 372MHz - 1280x720 refresh rate 60Hz These commands between then allow 640x480 @ 75HZ - all versions 640x480 @ 60HZ - all versions 720x400 @ 60HZ - all versions (widescreen) 800x600 @ 56Hz - all RP2350 versions 848x480 @ 60Hz - all RP2350 versions (widescreen) 1024x768 @ 60HZ - HDMI versions 1280x720 @ 60Hz - HDMI versions (widescreen) The actual CPU speeds used are: 372MHz 1280x720 315MHz 640x480 @ 75Hz 252MHz or 378MHz 640x480 @ 60Hz 324MHz 1024x768 360MHz 800x600 336MHz 848x480 283.2MHz 720x400 OPTION DEFAULT COLOURS Edited 2025-06-13 17:17 by matherp |
| circuit Guru Joined: 10/01/2016 Location: United KingdomPosts: 309 |
Peter, Many congratulations and thanks for this spectacular firmware. You have been most patient in managing all the responses on the board and singularly effective and speedy in addressing issues that arose. My gratitude and appreciation is more than I can express, and I am sure that is reflected in all others who adopt this system. I live in admiration of your talent and determination. Best regards always, Circuit. |
@Peter, Geoff, Congratulations with this release milestone. I will proudly use, and promote, it in the years to come. Volhout PicomiteVGA PETSCII ROBOTS |
| Teo1 Regular Member Joined: 06/05/2023 Location: RomaniaPosts: 42 |
Thank you for the hard work !!! With friendship, Teo |
| javavi Guru Joined: 01/10/2023 Location: UkrainePosts: 622 |
| Canada_Cold Regular Member Joined: 11/01/2020 Location: CanadaPosts: 57 |
@Peter, Geoff and all that have contributed to creating this awesome programming tool, Thank You for all your work and making this available to us. |
Also many thanks Peter and Geoff, a major effort! Gave the patched I2C a workout on an EEPROM. > dim integer a(4096) All bytes returned. > I2C WRITE I2C.addr, 0, 2, 0, 0 :t=timer : I2C read I2C.addr, 0, 4096, a():?timer-t; " mS" 100.107 mS > for n=4000 to 4096:? chr$(a(n)); :next <-ptr A=4000, Page 125, A=4031-><-ptr A=4032, Page 126, A=4063-><-ptr A=4064, Page 127, A=4095-> > |
I've activated the PSRAM but I can't seem to use the OPTION PSRAM DISABLE command. I get Error : Invalid Option |
Manual error: should be OPTION PSRAM PIN DISABLE We will probably do a manual update in about 3 weeks as both Geoff and I are travelling before then Edited 2025-06-14 02:25 by matherp |
Peter and Geoff, This is amazing - thank you for all the work you put into this firmware!! Best Thomas |
OK. I found the problem. The manual is wrong. The syntax is actually: OPTION PSRAM PIN DISABLE |
| AlbertR Senior Member Joined: 29/05/2025 Location: GermanyPosts: 111 |
@Peter, Geoff, Congratulations on this amazing firmware and thank you for your hard, hard work and passion with it. Albert |
> option list PicoMiteHDMI MMBasic USB RP2350A Edition V6.00.02 OPTION SERIAL CONSOLE COM2,GP8,GP9 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION KEYBOARD UK OPTION RESOLUTION 640x480 @ 252000KHz OPTION SDCARD GP22, GP6, GP7, GP4 > thanks. it did this itself? |
Source code and binaries on Github The manual has been updated but please leave comments on this thread for anything we have left out or any errors On page 184, what's the difference between SPRITE(V,spriteno1,spriteno2) Returns the vector from 'spriteno1' to 'spriteno2' in radians and SPRITE(V,[#]s1, [#]s2) Returns the vector from sprite 's1' to 's2' in radians. |
I was wondering if the CMM2 Firmware could be updated to reflect the newest developments in MMBasic? For example, I really like the Library feature as it elegantly allows the inclusion of directly callable extentions of the lanuage that remain static. Are there any other features that CMM2 users would like ported back to the older device? Just wondering, no stress. They call me Shai-Hulud (The maker) |
The CMM2 has #INCLUDE file$ so the Library isn't anywhere near as important. It's a better, more flexible system that is only possible because of the way that the CMM2 editor works. Unfortunately the PicoMite doesn't have the same resources so the Library (as originally used on the Micromite, I think) was used. Edited 2025-06-14 21:04 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
| homa Guru Joined: 05/11/2021 Location: GermanyPosts: 724 |
Many thanks to Peter and also Geoff! Have a good trip and enjoy the journey! Matthias |
Hi, I updated my solar panel display from 2023 to the newest WebMite firmware and it ran almost w/o a change! And from observing it the past 24 hours, more stably than with earlier WebMite versions. This is great!!! Best Thomas P.S. The only change I had to do was using in a format string "%02.0f" instead of "%02.0g". The behaviour of the "g" option seems to have changed: > ?Format$(5, "%02.0f") 05 > ?Format$(22, "%02.0f") 22 > ?Format$(5, "%02.0g") 05 > ?Format$(22, "%02.0g") 2e+01 Before, the latter also produced "22", but "2e+01" makes more sense considering that "g" is supposed to choose the optimal format. Edited 2025-06-15 16:11 by karlelch |
Manual page 101 - ADC OPEN command Refers to RP2940 and some very odd pins for the RP2350B! Shouldn't it be GP40 to GP47 for the RP2350B? It could be that the pins are re-mapped for the RP2350B to make GP40-43 into GP26-29 and GP44-47 into GP55-58, but this isn't clear in the manual. Mick Zilog Inside! nascom.info for Nascom & Gemini |
delete Edited 2025-06-16 05:54 by homa |
| Page 1 of 3 |
