Local Time 08:39 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Quadrature multichannel decoder for PicoMite using PIO
     Page 1 of 7
allie
Posted: 10:16pm 21 May 2025
allie
Posted: 10:27pm 21 May 2025
HI I've been away for long while on this topic of trying to use the RP2040 PicoMite for Quadrature multichannel decoding using PIO. I'll try to upload a post from this BackShed Forum I got last year to try to get started.
Regards Allie
allie
Posted: 10:38pm 21 May 2025
https://www.thebackshed.com/forum/ViewTopic.php?PID=225098#225098#225063
I don't think this worked the way I expected. I assumed you could click on it and it would open. I'll try something else. I'll go back to the other post from last year and Hi lite and try to save it.
regards allie
dddns
Posted: 10:56pm 21 May 2025
You could try this
Edited 2025-05-22 08:56 by dddns
allie
Posted: 10:57pm 21 May 2025
PhenixRising
Posted: 04:13am 19 Aug 2024
This code will handle 4 encoders on the RP2040 Picomite
'Quadrature multichannel decoder for PicoMite using PIO
'this is a 4 channel quadrature decoder for MMBasic V5.08.00 or newer
'running on a PicoMite or PicoMiteVGA usinf PIO 1
'Original PIO source: https://github.com/p-o-l-e/quadrature-decoder
'30-4-2024  Volhout
'system initialisation ---------------------------------------------------------
'program PIO 1
program_PIO 'program the code in PIO 1
'quadrature decoders generic settings
PIO_f%=63e6                            'frequency = 63MHz
PIO_s%=0                               'shift register (shift in left)
PIO_e%=PIO(execctrl gp0,wrp_tgt,wrap)  'start and stop of the loop
'start quadrature decoders (uncomment the needed decoders)
start_sm0 : sm0=1       'start decoder on GP0 and GP1
'start_sm1 : sm1=1       'start decoder on GP2 and GP3
'start_sm2 : sm2=1       'start decoder on GP4 and GP5
'start_sm3 : sm3=1       'start decoder on GP26 and GP27
'main MMBasic code -------------------------------------------------------------
'this code is just a demo that shows the position of the quadrature decoders
'the selected decoder positions are printed on the console
'type "r" to reset the decoders to 0
'main loop
do
 a$=inkey$                                     'just for control
 'get the data from the fifo and print
 if sm0 then print str$(read_fifo(0),12,0);    'get data from decoder
 if sm1 then print str$(read_fifo(1),12,0);    'get data from decoder
 if sm2 then print str$(read_fifo(2),12,0);    'get data from decoder
 if sm3 then print str$(read_fifo(3),12,0);    'get data from decoder
 print
 'just some pause
 pause 100                                     'any delay needed
 'reset position (PIO X register) under control of keyboard
 if a$="r" then                                'press r to zero position
   if sm0 then pio execute 1,0,&hA023 '= assembly "mov X, null" (zero X reg)
   if sm1 then pio execute 1,1,&hA023 '= assembly "mov X, null" (zero X reg)
   if sm2 then pio execute 1,2,&hA023 '= assembly "mov X, null" (zero X reg)
   if sm3 then pio execute 1,3,&hA023 '= assembly "mov X, null" (zero X reg)
   a$=""
 end if
loop while a$=""  'exit when any key not r
end
' subroutines -------------------------------------------------------------------
'this function returns the actual count of decoder n
function read_fifo(n) as integer
local dat%(3)
pio read 1,n,4,dat%()                                   'read whole fifo
read_fifo = dat%(3)                                    'last data in fifo
if read_fifo>2147483647 then inc read_fifo,-4294967296 '2'th complement
end function
'this subroutine programs the quadrature decoder program for PIO1 into
'PIO program memory
sub program_PIO
'this is the PIO program in machine code
dim p%(7)=(&h001A00170015001A,&h0015001A001A0017,&h0017001A001A0015, &h001A00150017001A,&h4042A0404042A0C3,&hA029001A005AA0A6,&h8000A0C1A0290059,0)
'here the program is programmed in memory
pio program 1,p%()
wrap=27           'end of the program
wrp_tgt=16        'start of the program loop
end sub
'this subroutine starts state machine 0 quadrature decoder on gp0 and gp1
sub start_sm0
'uses GP0,GP1, assign pins in MMBasic
setpin gp0,pio1
setpin gp1,pio1
'assign pins in PIO
pin_sm0%=PIO(pinctrl 0,0,0,gp0)
'configure and start PIO
pio init machine 1,0,PIO_f%,pin_sm0%,PIO_e%,PIO_s%,wrp_tgt
pio start 1,0
end sub
'this subroutine starts state machine 1 quadrature decoder on gp2 and gp3
sub start_sm1
'uses GP2,GP3, assign pins in MMBasic
setpin gp2,pio1
setpin gp3,pio1
'assign pins in PIO
pin_sm1%=PIO(pinctrl 0,0,0,gp2)
pio init machine 1,1,PIO_f%,pin_sm1%,PIO_e%,PIO_s%,wrp_tgt
pio start 1,1
end sub
'this subroutine starts state machine 2 quadrature decoder on gp4 and gp5
sub start_sm2
'uses GP4,GP5, assign pins in MMBasic
setpin gp4,pio1
setpin gp5,pio1
'assign pins in PIO
pin_sm2%=PIO(pinctrl 0,0,0,gp4)
pio init machine 1,2,PIO_f%,pin_sm2%,PIO_e%,PIO_s%,wrp_tgt
pio start 1,2
end sub
'this subroutine starts state machine 3 quadrature decoder on gp26 and gp27
sub start_sm3
'uses GP26,GP27, assign pins in MMBasic
setpin gp26,pio1
setpin gp27,pio1
'assign pins in PIO
pin_sm3%=PIO(pinctrl 0,0,0,gp26)
pio init machine 1,3,PIO_f%,pin_sm3%,PIO_e%,PIO_s%,wrp_tgt
pio start 1,3
end sub
When I tried to get this working I got Errors stopping it. I'll try it again to find the Errors
Regards Allie
allie
Posted: 11:39pm 21 May 2025
I found one Error that stops it now.
It stopped on this line ***
It stopped here***
It stopped there with the *** Error : Expected closing bracket
 I tried for 3 days to find out why it stopped with this Error. I checked all the code with no luck of getting it to work. I checked mmbasic manual.
Regards Allie
Posted: 11:49pm 21 May 2025
  Quote  dim p%(7)=(&h001A00170015001A,&h0015001A001A0017,&h0017001A001A0015,
The line suffered from wordwrap.
You need to put it back into one line.
Posted: 01:07am 22 May 2025
The new Line Continuation feature in recent firmware is one way to put it back into one line.
Add <space><underscore> at the break and the interpreter or editor will put it back together.
dim p%(7)=(&h001A00170015001A,&h0015001A001A0017,&h0017001A001A0015, _
Saved 1527 bytes
> LIST
'... other code
Dim p%(7)=(&h001A00170015001A,&h0015001A001A0017,&h0017001A001A0015,&h001A00150017001A,&h4042A0404042A0C3,&hA029001A005AA0A6,&h8000A0C1A0290059,0)
Edited 2025-05-22 11:20 by phil99
PhenixRising
Posted: 05:26am 22 May 2025
Great to see that someone else is using quad-decode
PhenixRising
Posted: 05:32am 22 May 2025
  allie said  https://www.thebackshed.com/forum/ViewTopic.php?PID=225098#225098#225063
regards allie
You need to use the link button for links to be clickable and you can apply your own description.
dddns
Posted: 07:15am 22 May 2025
Can this be used for the cheap 1€ decoders as well?
PhenixRising
Posted: 07:46am 22 May 2025
  dddns said  Can this be used for the cheap 1€ decoders as well?
Should work for any 2-channel encoder with a 90° phase offset. The problem with many of the panel-type encoders is the mechanical indenting which has a kind-of contact bounce effect. Not a problem here because it's not a hokey interrupt-driven solution. It's fast
dddns
Posted: 07:51am 22 May 2025
The (china) ones that are soldered on a PCB, typically have some sort of hardware denouncing already
Posted: 08:10am 22 May 2025
A couple of other encoder decoding options from Peter and TassyJim & Volhout.
'Here is MatherP's patented switch-bounce immune rotary encoder I/F code
option default integer
const false=0
const true=1
const in0=3 'encoder pins pulled high so should be reading high in detent positions, centre pin connected to ground
const in1=2 'swap the pin definitions as required to get the correct sense of rotation
init:
setpin in0,intB,rint 'enable interrupts on both edges of both pins
setpin in1,intB,rint
rotatedright=false
rotatedleft=false
resetenc=true
value=0
lastvalue=0
print value
MAIN:
if value <> lastvalue then
print value
lastvalue=value
endif
end
sub rint:
pin0=NOT pin(in0) 'reverse sense to get positive logic
pin1=NOT pin(in1)
if pin0 then
if pin1 and not resetenc then 'in0 and in1 both active
if rotatedleft and not rotatedright then
value=value-1
rotatedleft=false
endif
if rotatedright and not rotatedleft then
value=value+1
rotatedright=false
endif
else 'only in0 active
if resetenc and not rotatedleft then
rotatedright=true
resetenc=false
endif
endif
else
if pin1 then 'only in1 active
if resetenc and not rotatedright then
rotatedleft=true
resetenc=false
endif
else 'both off so reset
rotatedleft=false
rotatedright=false
resetenc=true
endif
endif
if pin(in0)=pin0 or pin(in1)=pin1 then goto rint 're-enter if another change has happened almost immediately
ireturn
' simple encoder reading TassyJim Nov 2022, updated Volhout
SetPin 2, DIN, PULLUP' setup RB as an input
SetPin 1, INTB, RInt, PULLUP' setup an interrupt when RA goes high
 ' < main body of the program >
Sub RInt ' Interrupt to decode the encoder output
' If Pin(2) = 1 Then
If Pin(2) = Pin(1) Then
 Value = Value + 1 ' clockwise rotation
Else
 Value = Value - 1 ' anti clockwise rotation
Print Value
Posted: 08:27am 22 May 2025
@phill,
The Quadrature decoder code you posted only decodes a single encoder, and is suitable for up to 1000 counts per second on a pico. These code snippets are very nice for a rotary encoder knob on a apparatus. Simple, and MMBasic.
For decoding multiple encoders, like in a CNC machine (where counting could be faster), the PIO version is preferable, since it works independent of the ARM (and is 1000x faster).
Edited 2025-05-22 18:29 by Volhout
PhenixRising
Posted: 08:33am 22 May 2025
  Volhout said  @phill,
Hi Harm,
Would be be able to read 12 encoders on the RP2350?
Posted: 08:58am 22 May 2025
Hi Phenix,
I see no reason why it could not. For 12 encoders you need 24 GPIO pins. To do anything useful with the pico besides decoding you would definitely need a RP2350B.
allie
Posted: 10:14am 22 May 2025
Thanks for the reply I tried with no luck on MMBasic V5.08.00 but I didn't use the
<space><underscore> at the break as phil99 posted on his next post. I'll try it when I  come home from work today.
I tried to open the UF2 file on the new Version of MMBasic V6.00.xx. I can't find a program to open it. I downloaded a few programs with no luck.
Regards Allie
Posted: 10:43am 22 May 2025
Hi Allie,
You may have been confused with the different versions.
The " _ " underscore to make the lines longer only works in 6.00.02rc24 (the latest rc). If you are using 5.08.00 then do following:
Run the program
You will get an error
Press F4 (that will open the editor)
Move the cursor to the first character on the "&h001A0015....." line
Press <backspace> on the keyboard
The editor will glue the 2 lines together, but the end of the line is invisible.
You will have a working program now.
You can run it (F2).
I would suggest you save the program
Press F1
Save "quadrature.bas"
You will have saved the program with the glued line, and next time you load it, the problem will not occur.
PhenixRising
Posted: 02:09pm 22 May 2025
  Volhout said  Hi Phenix,
Oh sure. I just wasn't sure if there was some other caveat
     Page 1 of 7
