Local Time 08:28 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Line Editor question (obsolete statement, workaround?)
Amnesie
Posted: 01:05pm 01 Apr 2025
Hello,
I found a really good program / function that fits my needs, but it uses an obsolete font statement:
Example1()
' Edit a string until ENTER with LineEdit:
Sub Example1
 a$ = "text to edit"
 Do: k = LineEdit(a$): Loop Until k = 13 ' until ENTER
' LineEdit(a$, [cur [, key [, max [, win ]]]]) edit string a$ at position cur,
' use key parameter (when provided) to make the next edit of a$ and update cur, and
' return new key press, or if key press not provided (zero) keep editing until
' ESC, ENTER or special key such as F1, UP/DOWN etc. where max is the maximum
' string length and win is the "window" size. Use LEFT/RIGHT/HOME/END to
' navigate the line, BACKSPACE/DEL to delete a character.
' Supports three editing modes: key=0 (default) edit until ENTER or other
' special key, key=-1 wait for key and make one edit, returning the key value,
' key=X to pass a key press to LineEdit to make one edit, returning the key
' value.
' Curser position cur parameter is passed in and updated by LineEdit
' Use the max parameter when the string has a maximum length smaller than 255
' To edit within a smaller window, use the win parameter
Function LineEdit(a$, cur, key, max, win)
 Local x, y, size, from, done
 x = MM.HPos: y = MM.VPos
 If max <= 0 Then max = 255
 If win <= 0 Then win = 255
 size = Len(a$)
 If cur < 0 Then
   cur = 0
 ElseIf cur > size Then
   cur = size
 done = key
   If key >= 32 And key < 127 Then
     If size < max Then
       a$ = Left$(a$, cur) + Chr$(key) + Mid$(a$, cur + 1)
       cur = cur + 1
       size = size + 1
   ElseIf key = 8 Then
     If cur > 0 Then
       cur = cur - 1
       a$ = Left$(a$, cur) + Mid$(a$, cur + 2)
       size = size - 1
   ElseIf key = 127 Then
     If cur < size Then
       size = size - 1
   ElseIf key = 130 Then
     If cur > 0 Then cur = cur - 1
   ElseIf key = 131 Then
     If cur < size Then cur = cur + 1
   ElseIf key = 134 Then
     cur = 0
   ElseIf key = 135 Then
     cur = size
   ElseIf key > 0 Then
     ' done editing, so print a clean line
     Print @(x,y) Left$(a$, win);
     ' remove the cursor from the end of the line
     If cur = size And size < win Then Print " ";
     Exit
   ' cursor cannot move beyond string max length
   If cur >= max Then cur = max - 1
   ' cursor is offset from window start
   If cur >= win Then from = cur - win + 2 Else from = 1
   If cur = size Then
     ' print the line constrained to the window size
     Print @(x,y) Mid$(a$, from);
     ' put the cursor at the end
     Font 1,,1: Print " ";: Font 1,,0
     ' BACKSPACE may require removing the cursor from the end of the line
     If key = 8 Then
       If cur + 1 < win And size < win Then Print " ";
   Else
     ' print the line constrained to window size
     Print @(x,y) Mid$(a$, from, cur - from + 1);
     ' invert character at the cursor
     Font 1,,1: Print Mid$(a$, cur + 1, 1);: Font 1,,0
     ' print the rest of the line
     Print Mid$(a$, cur + 2, win - cur + from - 2);
     If cur < win And size < win Then Print " ";
   ' if this is a non-blocking call then exit
   If done > 0 Then Exit
   ' wait on key press
   Do: key = Asc(Inkey$): Loop Until key
   done = -done
 ' move cursor back to the start of the line before returning
 Print @(x,y);
 LineEdit = key
End Function
It is a program to edit lines found on the FOTS. I managed to get it working with replacing all
font 1,,1
and
font 1,,0
with (both)
font 1,1
Problem now is, of course, it doesn't invert the character anymore. I took a look at the manual and searched for "cursor" and "invert" also for the font statement - no luck to find what the previous (obsolete code) really did.
Maybe this is a quick one for you, but I have no idea how to do this.
Greetings
Daniel
twofingers
Posted: 01:15pm 01 Apr 2025
Hi Daniel,
I can only recommend you try the "InputE" routine from the Javavi File Manager (my version).
Kind regards
Michael
Features:
- You can use it to process a predefined string, or no string at all.
- You can specify the maximum length.
- You can abort with ESC.
- You can switch to overwrite mode.
- For example, you can only allow numbers as input.
The default program is for HDMI in Mode 1. I haven't tested any others yet. There's a VT100 version in the FMVT100 thread.
My old LineEdit looked like this, based on my version for Maximites.
BTW: Check out the Print @() function for inverting characters!
The @(x,y) function will automatically suppress the automatic line wrap
normally performed when the cursor goes beyond the right screen margin.
If 'm' is specified the mode of the video operation will be as follows:
m = 0 Normal text (white letters, black background)
m = 1 The background will not be drawn (ie, transparent)
m = 2 The video will be inverted (black letters, white background)
m = 5 Current pixels will be inverted (transparent background)
Edited 2025-04-01 23:31 by twofingers
Amnesie
Posted: 01:42pm 01 Apr 2025
Hello Michael,
I took a look at your suggested version of the File Manager, but I am completely lost to reverse engineer this code at my level of experience to just take out the snippet I need.
But thank you for the hint with the Print @() function ! I will take a look at this :)
Greetings
Daniel
twofingers
Posted: 01:48pm 01 Apr 2025
  Amnesie said   to just take out the snippet I need.
Would that help?
On error skip'
If Bound(C(),1)<>15 Then
 Dim integer c(15)=(0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15)
 Colour Map c(),c()
Print inputE$("Test",10)
End
'INPUT+ESCape-------- NEW --------------
Function InputE$(inString$,maxLen,ovrOn,N_only)
Local s$=inString$,k$ length 1
Local gk,delflg,tLen=Len(s$),x=MM.Info(hPos),y=MM.Info(vPos)
Local cPos=tLen,bc=MM.Info(BCOLOUR)
Local cSet(1,1)=(32,127,48,58)
 Print @(x,y);Left$(s$,cPos);
 Color c(0),c(15-ovrOn*5)
 Print Mid$(s$,cPos+1,1);
 Color c(15),bc
 Print Mid$(s$,cPos+2);
 If cpos>=tLen Then Color c(0),c(15-ovrOn*5)
 Print " ";
 Color c(15),bc
 If delflg Then Print " ";:delflg=0
 gk=getkey()
 k$=Chr$(gk)
 If gk=13  Then Exit Do
 If gk=27  Then InputE$=inString$:maxLen=-1:Exit Function
 If gk=130 And  cPos >0 Then Inc cPos,-1
 If gk=131 And  cPos <tLen Then Inc cPos
 If gk=132 Then ovrOn=ovrOn=0
 If gk=134 Then cPos =0 'HOME
 If gk=135 Then cPos =tLen 'END
 If gk=127 And cPos<tLen Then
   s$=Left$(s$,cPos) +Mid$(s$,cPos+2)
   Inc tLen,-1:delflg=1
 If gk=8 And tLen>0 And cPos>0 Then
   s$=Left$(s$,cPos -1) +Mid$(s$,cPos+1)
   Inc cPos,-1:Inc tLen,-1:delflg=1
 If gk>=cSet(0,N_only) And gk<cSet(1,N_only) Then
   If cPos<tLen And ovrOn Then
     s$=Left$(s$,cPos) +k$ +Mid$(s$,cPos+2)
     Inc cPos
   ElseIf tLen<maxLen Then
     s$=Left$(s$,cPos) +k$ +Mid$(s$,cPos+1)
     Inc cPos:Inc tLen
InputE$=s$
Color c(15),bc
Print @(x,y);
End Function
I should probably mention that there are two versions of the InputE routine. My version of the FM contains a completely new development, and I've only kept the function name to make it easier to integrate into the FM.
Only the first parameter is not optional.
A simple call could therefore look like this:
Print inputE$("Test")
or something like this
Print inputE$("",10)
Edited 2025-04-02 00:07 by twofingers
Amnesie
Posted: 02:04pm 01 Apr 2025
Would that help?
Sadly not, it don't know how to use this function. in the "LineEdit" example it is easy, just go to the example sub and it works. Do I need to define some global variables first and create some Do Until Loop?
Argh..
Ah I see you updated the code, I try it again.
Greetings
Daniel
Edited 2025-04-02 00:06 by Amnesie
twofingers
Posted: 02:11pm 01 Apr 2025
The code is actually designed for use in the FM. But it can easily be adapted to run autonomously.
Perhaps a candidate for FOTs?
Amnesie
Posted: 02:14pm 01 Apr 2025
If I run the above code there is an error:
[18] gk=getkey()
Error: Dimensions
Yes I think it would be very usefull, since the normal Input is really limited...
Greetings
Daniel
twofingers
Posted: 02:18pm 01 Apr 2025
  Amnesie said  If I run the above code there is an error:
[18] gk=getkey()
Error: Dimensions
This should be enough for your purposes:
Function getKey(msg$) As integer
 Do :getKey=Asc(Inkey$):Loop While getKey=0
End Function
twofingers
Posted: 02:21pm 01 Apr 2025
I will probably make a zip package with this function once everything is clarified.
Amnesie
Posted: 02:22pm 01 Apr 2025
HA!!!
Now it works! This is exactly what I was looking for! Isn't this a good idea to hardcode into MMBASIC, I mean it handles extensive string modification, but is lacking Input processing. Just a thought. I know I know.. where is the fun, if everything is there by "default". Peter & Geoff did such an amazing job, don't get me wrong - was just a thought. I think there is a good reason why MMBASIC can't do such things by default. Whatever, thank you Michael! Now I can analyze your code to get an deeper understanding.
Greetings
Daniel
Edited 2025-04-02 00:31 by Amnesie
twofingers
Posted: 02:46pm 01 Apr 2025
  Amnesie said  ... Just a thought. I know I know.. where is the fun, if everything is there by "default". ...
That's my opinion too. It's already too much...
One more tip: if you want to determine whether the test was aborted with ESC, you should enter the maximum length (ml) as a variable:
ml = 10
? InputE("Test",ml)
if ml=-1 then ? "Abort with ESC!"
If InputE is aborted with ESC, ml is set to -1.
Edited 2025-04-02 00:48 by twofingers
twofingers
Posted: 09:59am 08 Apr 2025
Hi Daniel,
as promised, here are three more versions in a package.
INPUT_A.BAS is a revised version of the one described above for VGA/HDMI.
INPUT_B.BAS is an enhanced version for VGA/HDMI. The blinking cursor is new.
I haven't decided yet which is better.
INPUT_VT.BAS is for VT100 terminals.
I haven't yet integrated the option to enter only numbers here. This version is intended for programs in bare Pico moduls.
It was tested with PicoMites 2350 (Pico 2). Timing adjustments may be necessary for Pico 1 (blinking frequency). A small demo program is included.
Inpute.zip
The routine is actually a contribution to the File Manager (Javavis FM).
You are welcome to upload the package to FOTS.
Michael
Amnesie
Posted: 11:02am 08 Apr 2025
Michael,
thank you a lot. I will have a look when I am home.
Greetings
Daniel
Edited 2025-04-15 07:13 by Amnesie
Amnesie
Posted: 09:31am 16 Jul 2025
Hi Michael,
I am using your InputE function extensively for my GUI editor, It would be interesting if I could implement things like input textboxes for more than just one line of editing. I tried to implement more editing lines by myself but I failed miserably      ...
My attempt was to add "lines" to s$
like:
s$(lines)
and incrementing lines as well as the Y-position, when pressing the down-arrow-key (& vice versa) so it would be possible to edit more than just one line. But somehow this doesn't work out well. I am not even sure if this is the best solution to store each new line in an extra string?!
Have you a version of "inputE" that allows multi-line-editing?
Greetings
Daniel
Edited 2025-07-16 19:32 by Amnesie
toml_12953
Posted: 11:23am 16 Jul 2025
[18] gk=getkey()
Error: Dimensions
End Function
It's usually better to only set the function return value once, and minimize number of function calls in the loop if possible.
You're setting it every time you test for a key. You're also doing the conversion of string to ASCII numeric value in the loop. This would be more efficient:
 Local a$
 Do :a$=Inkey$:Loop While a$=""
 getKey = Asc(a$)
End Function
Edited 2025-07-16 21:26 by toml_12953
Posted: 11:33am 16 Jul 2025
The best place to keep an input line editor is probably in your Library. That way it takes up no user memory unless you want it. The worst place to keep one is to make it part of MMBasic as it takes up valuable flash memory and RAM, even when it's not wanted. When it's in the Library you also have the option to have your own specialised version(s).
Peter63
Posted: 01:55pm 16 Jul 2025
Daniel,
I have made a Subroutine I call edbox (BoxEditor), which I think you can try. It may contain some errors, but as far as I have tested it seems to work. Please come back if you find any strange things.
edbox.zip
/Peter63
twofingers
Posted: 02:47pm 16 Jul 2025
Hi Daniel,
unfortunately, I won't be online for a while. In principle, I think it's possible to adapt LineEdit. I've already thought about it myself.
But I'll wait and see how you like the "edbox."
Michael
Amnesie
Posted: 08:49am 17 Jul 2025
  Peter63 said  Daniel,
edbox.zip
/Peter63
Hi,
I've tested your BoxEditor and I am really happy with it. Can't find any problems yet! Exactly what I searched for. Now I only have to shrink / optimize the code from my GUI Editor   ...
Do you plan to make something out of your small programs? I am just curious and was amazed by your Paint program, which I am using quite often just for fun   Good work!
Greetings
Daniel
Edited 2025-07-17 18:49 by Amnesie
Amnesie
Posted: 08:55am 17 Jul 2025
  twofingers said  Hi Daniel,
Michael
Hi Michael,
thanks for responding that fast! One can't have enough code examples / snippets / programs. Sooner or later someone needs it for sure. I am searching the fruit of the shed all the time, before I ask here. But sadly a lot of the example programs there (FOTS) are outdated since some commands are obsolete. So New fresh ideas are always welcome, especially because everyone solves problems differently or has different approaches.
Greetings
Daniel
