Local Time 21:24 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : File Manager for PicoMite
     Page 1 of 21
javavi
Posted: 04:47pm 23 Sep 2024
I propose here for discussion the topic of creating a File Manager program for PicoMite.
I would like such a File Manager to be built into the system and called by a command or a functional button, to work both in the terminal and on displays in different resolutions.
I think that such a software shell would be useful in the development and use of PicoMite.
As an example, I give here my attempt to create such a program for PicoMiteVGA (MODE 1), it is not quite finished, but you can already use it.
FM - File Manager.zip
Best regards, javavi.
Edited 2024-09-24 02:50 by javavi
twofingers
Posted: 05:10pm 23 Sep 2024
@javavi
I think your program is great! Congratulations!
In my copy I have
Option default integer
Mode 1
Option F9 "RUN"+Chr$(34)+"B:FM"+Chr$(34)+Chr$(13)+Chr$(10)
Const FW=MM.Info(FONTWIDTH): FH=MM.Info(FONTHEIGHT)
added.
Similar to this:
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=17173&LastEntry=Y#227156#227154
Kind regards
Michael
PS: In your program you are probably not using this
On ERROR ignore
quite correctly. Maybe you mean
On ERROR skip
Posted: 06:33am 24 Sep 2024
Hi twofingers,
When you do following:
LOAD "FM.bas"
FLASH SAVE 2
OPTION F5 "flash run 2"+chr$(13)
Or -in your case- define F9, you have the file manager always available.
Javavi: very good file manager. The only thing I am missing is (as you mentioned) a way to start the editor, and a way to RUN a program.
If you could add these features, I personally would be very gratefull.
Edited 2024-09-24 16:36 by Volhout
twofingers
Posted: 07:20am 24 Sep 2024
Hi Volhout,
thanks for the tip, but that was what I meant with the link to the Electricats post:
  Quote  Similar to this:
  Electricat said  ... I saved small navigator to ->> FLASH 1 slot, then added ->> OPTION F5 FLASH RUN 1
Now, anytime I want run load program for run/editing I press F5, browse for file I need run/edit >> select&run
After Ctrl+C it can be edited, only changes must be saved using SAVE "****.bas" (F2 will not save)
Unfortunately the link (Copy link to clipboard) doesn't point to the individual post and I haven't checked it.
I don't like the solution with the flash because it costs a slot that is permanently occupied. But to each his own. b
  Quote  ... and a way to RUN a program.
It works for me (I replaced "Edit" with "Run" @Ln: 355). I think that project is very promising. I'm very excited for the next versions.
Best regards
Michael
Posted: 08:25am 24 Sep 2024
Could a way be found to run this from the Library? It might save a flash slot.
Posted: 08:38am 24 Sep 2024
  p108 said  The library is stored in program memory Flash Slot 3 which will then not be
available for saving a program (slots 1 to 2 will still be available).
Posted: 09:05am 24 Sep 2024
Yes? You aren't going to save to that slot are you? Isn't it just a case of running the file manager from there - after loading it into the library (flash slot 3) using LIBRARY SAVE, that is? Unless the file manager writes to the memory that it's running from, of course. I've not checked.
javavi
Posted: 04:03pm 24 Sep 2024
Hi Volhout,
Your request is easy to fulfill.
Now File Manager launches execution of a file with the .bas extension by pressing the Enter key.
In the same way, actions on different files can be organized by file extension.
FM_v11.zip
Also, thank you all for your feedback!
twofingers
Posted: 04:41pm 24 Sep 2024
Thank you! Much appreciated!
I foun a typo @LN:447
Local ineger x,l=Len(MM.ErrMsg$)
javavi
Posted: 05:03pm 24 Sep 2024
  twofingers said   I foun a typo @LN:447
Thank you very much!
Apparently I haven't caught any errors for a long time. :)
If you want, you can modify the code and post it here.
FM_12.zip
twofingers
Posted: 05:28pm 24 Sep 2024
  javavi said  ...
This could mean that you are a very good programmer. This shows your good programming style or ...
... that you have disabled all error detection by using "On ERROR ignore" instead of "On ERROR skip".
Edited 2024-09-25 03:31 by twofingers
javavi
Posted: 05:49pm 24 Sep 2024
I'm not much of a programmer - I'm a self-taught amateur.
I tried to figure out these constructions by trial and error, and somehow applied them... it was a long time ago, I've forgotten now. :)
electricat
Posted: 07:16pm 24 Sep 2024
There is one quite unpleasant moment I noticed.
I am still on 5.08 ver
Program loaded using command RUN $fname and later edited and saved using F1, will display msg "Saved nnn Kb" but in fact it will not be saved.
I must use SAVE "" to save for really.
My MMBasic 'sand box'
Posted: 09:31pm 24 Sep 2024
  electricat said  I must use SAVE "" to save for really.
F1 and F2 save to flash the edits you have made to your program--as you found, you must uses SAVE "fn.bas" to save the file to either an SD card or to the tiny file system in flash.
F1 and F2 assure that if you power cycle the picomite, your program will be available to RUN or EDIT or LIST with any changes you have made.
It is confusing until you understand where your changes are being saved.
electricat
Posted: 03:08am 25 Sep 2024
Posted: 07:48am 25 Sep 2024
Hi javavi,
I made minor changes.
- fix the RUN command when file names are shorter than 4 characters
- change the tile height back to 12 (some programs change the tile height) so the focus bar is correct height again.
When you flash save the file manager, there is one advantage: it is stored "tokenized" in flash slot. This means it will start much faster (instantly) than when loaded from file system (i.e. B:/fm/fm.bas).
fm12_bf.zip
Edited 2024-09-25 17:49 by Volhout
Posted: 08:00am 25 Sep 2024
Could it be called if it was stored in the library (flash slot 3)? You can have other stuff in there so it might save a flash slot. The whole program may have to be a SUB (with local variables?).
Alternatively, running it from A: would be faster than running it from B:.
Edited 2024-09-25 18:03 by Mixtel90
Posted: 08:13am 25 Sep 2024
Javavi,
There is one thing that you could improve. Currently copying of a file works from A:/ to B:/ and reverse.
But you cannot copy a file that is inside a folder (i.e. B:/test/test.bas to A:/)
There is a red popup "file not found".
Somthing with the path name is not right.
Edited 2024-09-25 18:14 by Volhout
Posted: 08:17am 25 Sep 2024
  Mixtel90 said  Could it be called if it was stored in the library (flash slot 3)? You can have other stuff in there so it might save a flash slot. The whole program may have to be a SUB (with local variables?).
Library is not usefull. Then all file manager subs and code becomes part of your main program. And how do you envision running the file manager. You will run your program in memory also. Remember library is simply a part of your main program.
electricat
Posted: 08:26am 25 Sep 2024
@Volhout,
I am still on 5.08 firmware (completely lost track on latest stable enough firmware and changes) so I downgraded JAVAVI FM with your latest modifications te be compatible with 5.08
fm12_bf-pm5.08.zip
Edited 2024-09-25 18:28 by electricat
     Page 1 of 21
