Local Time 11:15 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V5.09.00 release candidates
     Page 1 of 13
Posted: 10:26am 24 Mar 2024
Firmware V5.09.00 release candidate RC1 is now available for download from
This release includes some major internal changes including the move to 16-bit command tokens. The source has been updated on GitHub.
There are 5 firmware variants:
PicoMite - base version
PicoMiteVGA - base VGA version
WebMite - base version for Pico-W
PicoMiteUSB - Version with serial console support on GP8/GP9 and HID device support
PicoMiteVGAUSB VGA version with serial console support on GP8/GP9 and HID device support
HID device support includes up to 4 of USB keyboard, USB mouse, PS3 controller, PS4 controller and SNES gamepad directly connected for one device and via a 4-port hub for more than one device.
In addition this release includes LCD console support for any connected TFT display. Various optimisations have been included to overcome the speed constraints of SPI displays.
The release also includes support for 16-bit parallel connected displays for the ultimate in display speed.
A number of bugs have been corrected
In addition the release includes support for fast configuration of a number of boards using the OPTION RESET board command. More will be added during the release candidate process. No longer will you have to keep visiting the various sources to work out how to configure a board. Where applicable the configuration will include touch calibration but as this may vary between displays you may need to re-calibrate once the firmware is configured.
Please read the development threads here and here for mere details on the contents of the release
This release will delete all current options and in some cases the A: drive
OPTION RESET CMM1.5
OPTION RESET Game*Mite
OPTION RESET PicoMiteVGA V1.0
OPTION RESET PicoMiteVGA V1.1
OPTION RESET VGA Design 1
OPTION RESET VGA Design 2
OPTION RESET PICO BACKPACK
OPTION RESET RP2040-GEEK
OPTION RESET RP2040-LCD-0.96
OPTION RESET RP2040-LCD-1.28
OPTION RESET Pico-ResTouch-LCD-3.5
OPTION RESET Pico-ResTouch-LCD-2.8
Edited 2024-03-24 20:37 by matherp
Posted: 11:17am 24 Mar 2024
Hi Peter,
Can I suggest adding OPTION RESET LIST command (or similar) to list all the available board configurations.
Nice red Game*Mite, yours?
Posted: 11:41am 24 Mar 2024
Couple of other changes I should mention
VGA version now allow up to 378MHz CPU speed again. Use at your own risk.
Standard PicoMite now allows up to 420MHz. Likewise.
For all versions the CPUspeed is now checked as to whether the H/W can be configured to deliver it and an error is given before it is set if it can't.
Also, Even with a valid CPU speed, the firmware now sets the H/W watchdog before the CPU is configured. If this fails then the watchdog is triggered and the CPU speed is set back to default with an appropriate error message.
Posted: 11:56am 24 Mar 2024
Those are excellent features, along with all the other new capabilities.
Posted: 01:35pm 24 Mar 2024
OPTION RESET PICOGAME 4
OPTION RESET VGA BASIC
twofingers
Posted: 02:42pm 24 Mar 2024
  matherp said  VGA version now allow up to 378MHz CPU speed again. Use at your own risk.
Thanks, I was going to ask you to allow this as an option for cases where the user knows it works.
Michael
homa
Posted: 03:00pm 24 Mar 2024
Thank you so much for your amazing efforts, Peter, and to all of the wonderful people here!
1.
This variety is impressive!
If I had one wish, I would wish for support for Ethernet LAN/RJ45, WLAN is great, but sometimes I miss the more stable cable.
Either for everyone to retrofit with something like this ... https://www.berrybase.de/w5500-spi-ethernet-modul
or
this board here: https://www.waveshare.com/rp2040-eth.htm
2.
Can you explain this sentence in more detail?
"... including the move to 16-bit command tokens."
3.
And one more question about the supported displays. Will this type work? Labelling: "www.sainsmart.com tft_320qvt"
Chip on the board page for touch: XPT2046 and with research found this type chip for the graphic display: SSD1289 ???
I can't find anything about this in the manual.
Have a nice Sunday!
Matthias
Posted: 10:38pm 24 Mar 2024
OPTION RESET SWEETIE-PI
PhenixRising
Posted: 06:18am 25 Mar 2024
Holy cr@p. This dog's gotten some kick-butt steroids.
Opinions, please: Would it be temperature rise that would cause mischief with over-clocking?
I have seen others who have achieved this kind of Pico overclocking (YT) and they measured only a modest temperature-rise which surprised them.
Posted: 09:49am 25 Mar 2024
No. Not in this case, I don't think, unless it's very localised on the die. The chip appears to stay reasonably cool no matter what you throw at it (apart from loading the outputs).
However, there seems to be quite a bit of variation in chip speed capability and I suspect that's because the select on test process allows anything through that will run reliably at over 133MHz. They may test at something like 150MHz to get a high chip / board yield. Anything over 133MHz (the maximum specified speed) is overclocking and isn't guaranteed for all RP2040 chips, irrespective on what causes the limit.
My own guess is that the limit is caused by internal capacitance limiting the speed of some signals and causing internal bus collisions. It's only a guess though.
By the way, because the specified speed is 133MHz Raspberry Pi accept all chips that meet this. That means that all batches have this limitation and you should never expect any particular RP2040 to run any faster. The fact that we are finding them to be pretty reliable at higher speeds means nothing.
Edited 2024-03-25 19:54 by Mixtel90
PhenixRising
Posted: 10:46am 25 Mar 2024
133Mhz is also the limit of the flash (I think). So maybe this dictated the Pico's specified speed(?). Dunno, just seems a bit of a low spec' for a modern MCU.
Posted: 11:55am 25 Mar 2024
I think the 133MHz comes from the reference design. That uses a 12MHz xtal to give a 48MHz clock for USB. A PLL then gets it up to 133MHz for the system clock. Some clock combinations won't work with USB. Some won't work for VGA and some flash chips are too slow for the clocks available! :) The RP2040 can run fast, but it may not be usable at some speeds.
Posted: 12:45pm 25 Mar 2024
  homa said  Can you explain this sentence in more detail?
MMBasic internally stores a program's keywords (IF, FOR, CASE, etc) as tokens. They used to be 8-bit but they ran out so now 16-bit ones are used.
I think Peter mentioned this in case the change has introduced any as yet undiscovered errors.
Bleep
Posted: 01:29pm 25 Mar 2024
Hi Peter,
Have installed PicoMite USB and everything appears to be working great, I've tested on a ILI9481 and console, colour editor, listing all look good. Just for the hell of it I've overclocked to 420MHz still working, I've attempted to stress it as much as I can by using a background copy of a framebuffer, with screen updates running flat out, has been running for over an hour now. :-) The only very minor problem I found, which I wouldn't normally do anyway, is when I plug in a USB keyboard with a running program I get "UK" in the top left corner of the screen, so all of the rest of the USB Keyboard Connected... is suppressed, but not the UK, or US or whatever.
Then loaded your PicoMiteVGA board with the VGAUSB did a Option Reset CMM1.5 all seems to be working fine also, again, I've overclocked to 378MHz and had that running for half an hour without problems, using a USB keyboard to edit and run programs all fine, files on SD fine, RTC...
Thank you for a great update, especially the LCD Console stuff, I'm now in the middle of hacking one of Micks Pico Backpacks to take a Chinese Pico, because of the extra flash, with the 4" screen, RTC, sound, and TTL to USB, to make a portable Pico I can take anywhere, but it might take a while. :-)
Regards, Kevin.
Posted: 02:29pm 25 Mar 2024
Hi Peter, nice work leading up to this rc release.
trying vga usb at cpuspeed 378000, which I always used with no noticeable problems, until it was reduced in the later betas. seems fine as usual.luck?old picomites boards?
I will try the picomite usb version next at cpuspeed 420000 with ili lcds.
regards, stan
Bleep
Posted: 07:25pm 25 Mar 2024
Hi Peter,
I think I may have found a problem, I was using the VGA USB initially & found that doing a ?pin(temp) gave very high temperature values, so I also tested a PicoMite USB LCD & found the same, I wondered if it was because I was overclocking, so tried 48MHz now I got a way too low temperature. These are the values I am getting, all done in quick succession, so should roughly be the same, room temperature is 17C, the RP2040 is open to free air.
48MHz =12C
126MHz=14C
252MHz=19C 'could be approx correct?
378MHz=25C
420MHz=28C
Regards Kevin.
Posted: 07:28pm 25 Mar 2024
picomite ili lcd ok at cpu 420000
PicoMite MMBasic Version 5.09.00RC1
OPTION AUTORUN  ON
OPTION KEYBOARD UK
OPTION CPUSPEED  420000 'KHz
OPTION LCDPANEL ILI9488, LANDSCAPE,GP15,GP14,GP13
OPTION TOUCH GP12,GP11
GUI CALIBRATE 0, 3883, 3906, -1298, -858
OPTION SDCARD GP22
> drive "b:"
> files
B:/
22:39 29-03-2023   55342378  t1.wav
21:11 02-04-2023   65642368  t2.wav
0 directories, 2 files
Posted: 07:36pm 25 Mar 2024
  Quote  4.9.5. Temperature Sensor
The temperature sensor measures the Vbe voltage of a biased bipolar diode, connected to the fifth ADC channel
(AINSEL=4). Typically, Vbe = 0.706V at 27 degrees C, with a slope of -1.721mV per degree. Therefore the temperature
can be approximated as follows:
T = 27 - (ADC_voltage - 0.706)/0.001721
As the Vbe and the Vbe slope can vary over the temperature range, and from device to device, some user calibration
may be required if accurate measurements are required.
The temperature sensor’s bias source must be enabled before use, via CS.TS_EN. This increases current consumption
on ADC_AVDD by approximately 40μA.
 NOTE
The on board temperature sensor is very sensitive to errors in the reference voltage. If the ADC returns a value of
891 this would correspond to a temperature of 20.1°C. However if the reference voltage is 1% lower than 3.3V then
the same reading of 891 would correspond to 24.3°C. You would see a change in temperature of over 4°C for a small
1% change in reference voltage. Therefore if you want to improve the accuracy of the internal temperature sensor it
is worth considering adding an external reference voltage.
RP2040 Datasheet
4.9.
Posted: 08:12pm 25 Mar 2024
picomite usb seems ok at cpu 420000.
PicoMite MMBasic USB Edition  5.09.00RC1
OPTION COLOURCODE ON
OPTION KEYBOARD UK
OPTION LCDPANEL ILI9341, LANDSCAPE,GP15,GP14,GP13
GUI CALIBRATE 0, 3847, 3910, -891, -653
OPTION SDCARD GP22
> drive "b:"
files
B:/
18:06 26-10-2023     153654  ball.bmp
0 directories, 1 file
contactless laser thermometer says r2040 chip 27.8 deg C
Hans
Posted: 12:22am 26 Mar 2024
Hi All;
I have a waveshare-geek and loaded 5.9 RC1 to try the OPTION RESET RP2040-GEEK command.
The 1st thing was the lack of OPTION SDCARD and a difference in the display GPIOs causing the display to flash on and off. The GUI TEST LCDPANEL did not show anything and gave no errors.
Then comes the weird part after I did an OPTION RESET and tried to configure the SDCARD, so I could do a OPTION DISK LOAD, after hitting enter it gave me a message that pin 41/23 was all ready in use. Of course it did that was used up in the display configuration of OPTION RESET RP2040-GEEK, but why was it still there? (Sorry forgot the screen shot).
I had this thing working completely under 5.8 ;
My thinking was to go back to 5.8 and thats when I had a real problem!
I first used Clear_flash.uf2 then loaded 5.8.00. I went to configure the sdcard and up came the same message as in 5.9;
I hope this does not mean my Geek is now pooched.
If you need more information please ask.
Hans ...
     Page 1 of 13
