Local Time 01:12 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoRocks - A Teaser
     Page 1 of 7
vegipete
Posted: 04:08am 09 Jan 2024
To test some things, I bashed this together for the PicoMiteVGA. It shows some potential.
(Delete the first 2 lines if you are not transferring via AUTOSAVE.)
I am puzzled by something, though. When you pilot the ship slowly off the top or left edges, the intensity drops. It appears normal everywhere else. Hmmm. (It might be related to framebuffer copying. If you hit ctrl-C while the ship is in the dim zone, it goes back to full intensity.)
(PicoMiteVGA MMBasic Version 5.07.08RC21)
Edited 2024-01-09 14:15 by vegipete
Posted: 02:41pm 09 Jan 2024
Hi Vegipete,
I see no "rocks" yet...only the spaceship.
But when I accelerate it gets warp speed 10.... Wauw.
You are busy with a zillion projects at the same time. Need any help to finish one of them ? LR, RIS, Qbert ... ?
P.S. I wonder if the "vector graphics" resolution of the arcade game could be implemented in mode 1 (640x480) using a "tile" to color the plane if you like. But the original game was B/W only.
Edited 2024-01-10 01:16 by Volhout
Posted: 05:26pm 09 Jan 2024
I looked at the code cos asteroids was a favourite and not tried but looks interesting.
I was thinking of polygons not sprites and no trig.
the original arcade used phosphor fade and the rocks were drawn not erased
vegipete
Posted: 06:57pm 09 Jan 2024
As I said, this was to test some things. The little demo uses 144 sprites. I wasn't about to draw them by hand. Instead, the ship was defined by 4 points, rotated to each angle and drawn. The images were then read and converted to CSub data.
Stan has pointed out something else to test - how long does it take to draw the ship as a polygon instead of as a CSub sprite, and can rotation be calculated on the fly or must it be precalculated?
Do CSub sprites work in mode 1 (640x480)? I haven't tried...
Posted: 07:04pm 09 Jan 2024
tried the code and got rotating ship and thrust. nice.
I'll try polygons and frames for fps, see fastest way. stan
Posted: 12:04am 10 Jan 2024
Polygons need all the elements in the x,y arrays changed to move them.
using joined lines relative to x,y may be faster. testing
Posted: 06:32pm 10 Jan 2024
rotating ship?
xcentre=63
ycentre=58
radius=8
do
for d=0 to 359 step 10
cls
xp = xcentre + radius  * sin (rad(d))
yp = ycentre - radius  * cos (rad(d))
e=d+140:if e>359 then e=e-359
f=d+220:if f>359 then f=f-359
xe1 = xcentre + radius  * sin (rad(e))
ye1 = ycentre - radius  * cos (rad(e))
xe2 = xcentre + radius  * sin (rad(f))
ye2 = ycentre - radius  * cos (rad(f))
line xe1,ye1,xp,yp,,1
line xp,yp,xe2,ye2,,1
pause 50
next d
loop
Posted: 06:57pm 10 Jan 2024
The firing shots at different degrees will be fun to implement.
the rotating ship seems low memory and drawing the rocks could be fast enough. use frames no erase . a smaller display area to get wrap around and frames.
I'll try to chip in for the picomite asteroids if I can help. stan
Posted: 08:11pm 10 Jan 2024
bit more efficient rotating ship
xcentre=63
ycentre=58
radius=8
do
cls
rd=rad(d)
xp = xcentre + radius  * sin (rd)
yp = ycentre - radius  * cos (rd)
rd=rad(e)
xe1 = xcentre + radius  * sin (rd)
ye1 = ycentre - radius  * cos (rd)
e=d+220:if e>359 then e=e-359
rd=rad(e)
xe2 = xcentre + radius  * sin (rd)
ye2 = ycentre - radius  * cos (rd)
pause 50
next d
loop
Footnote added 2024-01-11 07:32 by stanleyella
add
line xe2,ye2,xcentre,ycentre,,1
line xcentre,ycentre,xe1,ye1,,1
for a proper ship :)
Posted: 08:31pm 10 Jan 2024
how many angles for the ship? 16 with no trig except the ship rotate, so many x,y pixels for missiles and ship forward.? stan
vegipete
Posted: 09:42pm 10 Jan 2024
Ship rotation thoughts:
I started with my Rocks in Space for the CMM2. It used 96 steps for the full rotation of a 32ish pixel square ship canvas on an 800x600 screen. Scaling that ship size to the PicoMite resolution gave me a 13 pixel square canvas - convenient because that results in an actual center point. Sketched a 4-point ship, put the coordinates into a little program, plotted it, fettled a bit, sorted. Then I started rotating the resulting ship to see what number of steps looked good. 96 was unnecessarily many, 72 was aesthetically pleasing.
Here's the code I used to generate the ships:
Option DEFAULT INTEGER
option angle degrees
MODE 2
cls 0
' ship data: 4 points for ship, 5 points for flame
dim float body(8,1):for i=0 to 8:read body(i,0):read body(i,1):next
data 0,-6,-3,4,0,2,3,4,0,4,0,5,-1,5,0,6,1,5
dim float rc(8,1)  ' work copy of ship
dim float sa,ca
mx = 6 : my = 56
for a = 0 to 359 step 5
 ' rotate a copy of the ship
 sa = sin(a) : ca = cos(a)  ' only do this once!
 for i = 0 to 8
   rc(i,0) = body(i,0) * ca - body(i,1) * sa
   rc(i,1) = body(i,0) * sa + body(i,1) * ca
 next
 ' ship body
 line mx+rc(0,0),my+rc(0,1),mx+rc(1,0),my+rc(1,1),,rgb(green)
 line mx+rc(1,0),my+rc(1,1),mx+rc(2,0),my+rc(2,1),,rgb(green)
 line mx+rc(2,0),my+rc(2,1),mx+rc(3,0),my+rc(3,1),,rgb(green)
 line mx+rc(3,0),my+rc(3,1),mx+rc(0,0),my+rc(0,1),,rgb(green)
 ' rocket flames
 pixel mx+rc(4,0),my+rc(4,1),rgb(yellow)
 pixel mx+rc(5,0),my+rc(5,1),rgb(brown)
 pixel mx+rc(6,0),my+rc(6,1),rgb(rust)
 pixel mx+rc(7,0),my+rc(7,1),rgb(rust)
 pixel mx+rc(8,0),my+rc(8,1),rgb(rust)
 ' advance to next image location
 mx = mx + 13
 if mx >= 239 then
   mx = 6
   my = my + 13
 endif
next a
Posted: 09:54pm 10 Jan 2024
radius=16 is nice
mode 1
xcentre=100
ycentre=100
radius=16
do
for d=0 to 359 step 16
cls
rd=rad(d)
xp = xcentre + radius  * sin (rd)'ship
yp = ycentre - radius  * cos (rd)'direction
rd=rad(e)
xe1 = xcentre + radius  * sin (rd)'ship
ye1 = ycentre - radius  * cos (rd)'tail left
rd=rad(e)
xe2 = xcentre + radius  * sin (rd)'ship
ye2 = ycentre - radius  * cos (rd)'tail right
line xe1,ye1,xp,yp,,1'           :
line xp,yp,xe2,ye2,,1'           :draw
line xe2,ye2,xcentre,ycentre,,1' :ship
line xcentre,ycentre,xe1,ye1,,1' :
pause 100
next d
loop
Posted: 10:19pm 10 Jan 2024
  vegipete said  Ship rotation thoughts:
In MMB4W:
Posted: 12:11am 11 Jan 2024
if drawn then 360 but how many in atari original game?
I was thinking of x,y centre to ship point ratio to get increments for movement and missile vector.
reminds me of startrek https://www.youtube.com/watch?v=CBj6AUrMVls
pwillard
Posted: 12:28am 11 Jan 2024
The original atari game had one "shape" and used vector math to rotate... no sprites at all.
Posted: 08:21am 11 Jan 2024
I'd suggest keeping the number of rotation steps as small as possible. The rotation won't actually be as smooth, but it will be faster - and you'll need CPU capacity to handle the drawing and movement of rocks. This is one of those cases where using a lookup table for the vertices of objects could be faster and easier than calculating them, but in order to keep the lookup table reasonable you have to keep the steps down.
Note that you can use just one or two lookup tables for rocks and simply scale them as needed.
Edited 2024-01-11 18:22 by Mixtel90
Posted: 05:23pm 11 Jan 2024
For the classic atari asteroids look vga mode 1.
should it use sprites, line, or polygon?
I thought the sprite or blit on lcd had changed to not record black, dunno , which mmbasic version.
joined lines with 1 x,y start and the other points x,y with offset.
polygons, all points in the x,y arrays needing offset.
I got 16 16x16 sprites bouncing around very fast. a few rocks should be ok.
For the rock and ship and missile wrap around I thought copy a smaller frame than the drawing frame to the screen. just thoughts. stan
Posted: 05:49pm 13 Jan 2024
I'm trying lines for rocksfrom x,y corner as sprite to move
change rx1,ry1 and draws rock there. sprite alternative?
sub rock1
line rx1+6,ry1,rx1+14,ry1+6
line rx1+14,ry1+6,rx1+22,ry1
line rx1+22,ry1,rx1+30,ry1+6
line rx1+30,ry1+6,rx1+22,ry1+14
line rx1+22,ry1+14,rx1+30,ry1+22
line rx1+30,ry1+22,rx1+18,ry1+30
line rx1+18,ry1+30,rx1+8,ry1+30
line rx1+8,ry1+30,rx1,ry1+26
line rx1,ry1+26,rx1,ry1+6
line rx1,ry1+6,rx1+6,ry1
end sub
sub rock2
line rx1+12,ry1,rx1+28,ry1+12
line rx1+28,ry1+12,rx1+44,ry1
line rx1+44,ry1,rx1+60,ry1+12
line rx1+60,ry1+12,rx1+44,ry1+28
line rx1+44,ry1+28,rx1+60,ry1+44
line rx1+60,ry1+44,rx1+36,ry1+60
line rx1+36,ry1+60,rx1+16,ry1+60
line rx1+16,ry1+60,rx1,ry1+44
line rx1,ry1+44,rx1,ry1+16
line rx1,ry1+16,rx1+12,ry1
end sub
sub rock3
line rx1+9,ry1,rx1+21,ry1+9
line rx1+21,ry1+9,rx1+33,ry1
line rx1+33,ry1,rx1+40,ry1+9
line rx1+40,ry1+9,rx1+33,ry1+21
line rx1+33,ry1+21,rx1+40,ry1+33
line rx1+40,ry1+33,rx1+24,ry1+40
line rx1+24,ry1+40,rx1+12,ry1+40
line rx1+12,ry1+40,rx1,ry1+36
line rx1,ry1+36,rx1,ry1+12
line rx1,ry1+12,rx1+9,ry1
end sub
Posted: 06:24pm 13 Jan 2024
  pwillard said  The original atari game had one "shape" and used vector math to rotate... no sprites at all.
A 6502 board with dacs connected to x,y b/w vector monitor.
if you turned the brightness control up you saw the the lines between the graphics as it drew a rock then moved to draw the next and all graphics.
In the original asteroids only the ship rotated.
I would make the saucer a sprite.. lot to draw.
Edited 2024-01-14 04:46 by stanleyella
Posted: 07:04pm 13 Jan 2024
yes,thinking that.  please see rocks are multiples.
Edited 2024-01-14 05:20 by stanleyella
     Page 1 of 7
