Local Time 01:24 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : play simple midi notes
crazycloud
Posted: 04:34pm 28 Dec 2023
WebMite MMBasic Version 5.08.00b5
OPTION WIFI NETGEAR57, **************, PICOE6616408438
OPTION TELNET CONSOLE ON
OPTION AUDIO VS1053 GP2,GP3,GP4,GP9,GP8,GP7,GP6', ON PWM CHANNEL 1
I have gotten my VS1053 board working.  It is connected to my hi fi amplifier
via an audio transformer.  I can get sounds by using play midi test.  It sounds great.
I can't seem to make it work further.
I've tried this simple program
Play MIDI 'enable real time MIDI
Play MIDI cmd &B11000001,10 'set the instrument for channel 1
Play MIDI cmd &B11000010,1 'set the instrument for channel 2
Play note on 1,127,126
Play note on 2,11,12
I get nothing.  I've tried many different combinations of numbers for the play not parameters with no success. can anyone advise?
Posted: 06:25pm 28 Dec 2023
Your note parameters are a bit extreme
Try "play note on 1,80,127"
Try the attached as a working example
' Plays "The Entertainer" by Scott Joplin
'  - also encodes it as DATA statements for playing outside of this program.
' Code Copyright (c) 2022 Thomas Hugo Williams
' License MIT <https://opensource.org/licenses/MIT>
' For MMBasic 5.07.03
Option Base 0
Option Default None
Option Explicit On
Play midi 'enable real time midi
Play midi cmd &B11000001,4 'set the instrument for channel 1
Option Break 4
On Key 3, on_break
Const FILE$ = "entertainer"
Const SZ% = 256
' Const NUM_CHANNELS% = music.prompt_for_num_channels%()
Const NUM_CHANNELS% = 3
Dim channel1%(SZ%), channel2%(SZ%), channel3%(SZ%), channel4%(SZ%)
Dim err$
If Instr(MM.Device$, "PicoMite") Then Save FILE$ + ".bas"
music.compose()
music.process()
music.write_data()
music.play()
End
' Interrupt routine to stop music and restore default Break Key.
Sub on_break
Play Stop
Option Break 3
End
' Prompts user for number of channels to encode / play.
Function music.prompt_for_num_channels%()
Local s$
Line Input "How many channels (1-4)? ", s$
Print
Select Case Val(s$)
 Case 1 To 4 : Exit
End Select
music.prompt_for_num_channels% = Val(s$)
End Function
' Fills channels{1-3}% with musical notes for "The Entertainer".
Sub music.compose()
' ---------- Line 0 ----------
music.parse(channel1%(), "qD4,qD#4")
music.parse(channel2%(), "1-")
music.parse(channel3%(), "1-")
' ---------- Line 1 ----------
music.parse(channel1%(), "qE4,1C5,qE4,1C5,qE4,qC5")
music.parse(channel1%(), "2C5,q-,qC5,qD5,qD#5")
music.parse(channel1%(), "qE5,qC5,qD5,qE5,qE5,qB5,1D5")
music.parse(channel1%(), "3C5,qD4,qD#4")
music.parse(channel2%(), "1C4,1C3,1D#3,1E3")
music.parse(channel2%(), "1F3,1G3,1A4,1B4")
music.parse(channel2%(), "1C4,1E3,1F3,1G3")
music.parse(channel2%(), "1C3,1G3,1C4,qC4,q-")
music.parse(channel3%(), "4-")
' ---------- Line 2 ----------
music.parse(channel1%(), "3C5,qA5,qG4")
music.parse(channel1%(), "qF#4,qA5,qC5,qE5,qE5,qD5,qC5,qA5")
music.parse(channel1%(), "3D5,qD4,qD#4")
music.parse(channel2%(), "1F3,1G3,1A4,1C#3")
music.parse(channel2%(), "1D3,1F#3,1A4,1D3")
music.parse(channel2%(), "1G3,1F3,1E3,1D3")
' ---------- Line 3 ----------
music.parse(channel1%(), "2C5,qC5,q-,qC5,qD5")
music.parse(channel2%(), "1C3,1C4,1D#3,1E3")
music.parse(channel2%(), "1C4,1G3,2C3")
' ---------- Line 4 ----------
music.parse(channel1%(), "qE5,qC5,qD5,qE5,qE5,qC5,qD5,qC5")
music.parse(channel1%(), "2C5,qC5,qE4,qF4,qF#4")
music.parse(channel2%(), "qC5,q-,qC5,q-,qBb5,q-,qBb5,q-")
music.parse(channel2%(), "qA5,q-,qA5,q-,qAb5,q-,qAb5,q-")
music.parse(channel2%(), "qG4,q-,qG4,q-,1G4,1-")
music.parse(channel2%(), "1-,1G3,qC4,q-,1-")
music.parse(channel3%(), "qC4,q-,qC4,q-,qBb4,q-,qBb4,q-")
music.parse(channel3%(), "qA4,q-,qA4,q-,qAb4,q-,qAb4,q-")
music.parse(channel3%(), "qG3,q-,qG3,q-,1G3,1-")
music.parse(channel3%(), "1-,1G2,qC3,q-,1-")
' ---------- Line 5 ----------
music.parse(channel1%(), "1G4,qA5,qG4,qG4,qE4,qF4,qF#4")
music.parse(channel1%(), "1G4,qA5,qG4,qG4,qE5,qC5,qG4")
music.parse(channel1%(), "qA5,qB5,qC5,qD5,qE5,qD5,qC5,qD5")
music.parse(channel1%(), "2G4,qG4,qE4,qF4,qF#4")
music.parse(channel2%(), "1E4,qF4,qE4,qE4,q-,1-")
music.parse(channel2%(), "4-")
music.parse(channel3%(), "1C4,1-,1G3,1-")
music.parse(channel3%(), "2F3,2G3")
music.parse(channel3%(), "1C3,1G3,1C4,1-")
' ---------- Line 6 ----------
music.parse(channel1%(), "1G4,qA5,qG4,qG4,qG4,qA5,qA#5")
music.parse(channel1%(), "1B5,q-,1B5,qA5,qF#4,qD4")
music.parse(channel3%(), "1C4,1-,1G3,1C#4")
music.parse(channel3%(), "2D4,2D3")
music.parse(channel3%(), "qG3,q-,qG3,q-,1A4,1B4")
' ---------- Line 7 ----------
music.parse(channel1%(), "2C5,qC5,qG4,qF#4,qG4")
' ---------- Line 8 ----------
music.parse(channel1%(), "1C5,qA5,qC5,qC5,qA5,qC5,qA5")
music.parse(channel1%(), "qG4,qC5,qE5,qG5,qG5,qE5,qC5,qG4")
music.parse(channel1%(), "1A5,1C5,qE5,1D5,qD5")
music.parse(channel1%(), "3C5,1-")
music.parse(channel2%(), "qF4,q-,qF4,q-,qF#4,q-,qF#4,q-")
music.parse(channel2%(), "qG4,q-,qG4,q-,qE4,q-,qE4,q-")
music.parse(channel2%(), "qF4,q-,qF4,q-,qG4,q-,qG4,q-")
music.parse(channel2%(), "1C5,1G4,1C4,1-")
music.parse(channel3%(), "qF3,q-,qF3,q-,qF#3,q-,qF#3,q-")
music.parse(channel3%(), "qG3,q-,qG3,q-,qE3,q-,qE3,q-")
music.parse(channel3%(), "qF3,q-,qF3,q-,qG3,q-,qG3,q-")
music.parse(channel3%(), "1C4,1G3,1C3,1-")
' Parses comma separated list of notes.
' @param channel%() parsed notes are appended to this array.
' @param s$     comma separated list.
Sub music.parse(channel%(), s$)
Local s_idx% = 1
Local ch$ = ","
Do While ch$ = ","
If music.parse_note%(channel%(), s$, s_idx%) <> 0 Then
 Error err$ + " : s_idx = " + Str$(s_idx%)
Inc s_idx%
ch$ = Mid$(s$, s_idx%, 1)
Inc s_idx%
' Parses single note.
' @param channel%() parsed note is appended to this array.
' @param s$     note is parsed from this string ...
' @param s_idx%   ... starting at this index. On exit this will
'           contain the index of the last character parsed.
' @return       0 on success, -1 on error. Error message will
'           be in the global err$ variable.
Function music.parse_note%(channel%(), s$, s_idx%)
music.parse_note% = -1
Local i%
Local ch$ = Mid$(s$, s_idx%, 1)
' Parse duration.
Local duration%
Select Case ch$
Case "q": duration% = 1
Case "1", "2", "3", "4": duration% = 2 * Val(ch$)
Case Else
 err$ = "Syntax error: expected duration"
 Exit Function
End Select
Inc s_idx%
' Parse note.
Local n% = 0 ' 0 = Rest, 1 = A0
Select Case ch$
Case "A" : n% = 1
Case "B" : n% = 3
Case "C" : n% = 4
Case "D" : n% = 6
Case "E" : n% = 8
Case "F" : n% = 9
Case "G" : n% = 11
Case "-" : ' Do nothing
Case Else
 err$ = "Syntax error: expected note"
 Exit Function
End Select
If n% = 0 Then
For i% = 1 To duration%
 LongString Append channel%(), Chr$(0)
Next
music.parse_note% = 0
Exit Function
Inc s_idx%
' Parse b or #.
Local off% = 0
Select Case ch$
Case "b" : off% = -1
Case "#" : off% = 1
End Select
If off% <> 0 Then
Inc n%, off%
Inc s_idx%
' Parse octave.
If Not Instr("012345678", ch$) Then
err$ = "Syntax error: expected octave"
Exit Function
Inc n%, 12 * Val(ch$)
' Write note into buffer.
LongString Append channel%(), Chr$(n%)
Next
End Function
' Combines the individual channels into a single global music%() array.
Sub music.process()
' Terminate each channel with 255 and determine the maximum length.
Local max_len% = 0, i%, j%
For i% = 1 To NUM_CHANNELS%
Execute "LongString Append channel" + Str$(i%) + "%(), Chr$(&hFF)"
max_len% = Max(max_len%, Eval("LLen(channel" + Str$(i%) + "%())"))
Next
' Pad max_len% to be a multiple of 8.
Do While max_len% Mod 8 > 0 : Inc max_len% : Loop
' Pad each channel with 255 until all the same length.
Do While Eval("LLen(channel" + Str$(i%) + "%())") < max_len%
Next
' Combine the channels into a single music buffer.
Dim music%(1 + (NUM_CHANNELS% * max_len% / 8))
For i% = 0 To max_len% - 1
For j% = 1 To NUM_CHANNELS%
 Execute "LongString Append music%(), Chr$(LGetByte(channel" + Str$(j%) + "%()
, i%))"
Next
Next
' Writes music%() array into a file as DATA statements.
Sub music.write_data()
Local count% = 0, i%, p% = Peek(VarAddr music%()) + 8
Open "entertainer.inc" For Output As #1
Print #1, "Data " Format$(LLen(music%()), "%-6g") "' Number of bytes of music d
ata."
Print #1, "Data " Format$(NUM_CHANNELS%,"%-6g") "' Number of channels."
For i% = 0 To LLen(music%()) - 1 Step 8
Print #1, Choice(count% = 0, "Data ", ", ");
Print #1, "&h" Hex$(Peek(Integer p%), 16);
Inc p%, 8
Inc count%
If count% = 4 Then Print #1 : count% = 0
Next
Close #1
' Plays the contents of the music%() array using interrupts.
Sub music.play()
Dim music_ptr% = Peek(VarAddr music%()) + 8
'Play SOUND 1,B,s,155.5634919
SetTick 200, music.play_interrupt, 1
Do While music_ptr% <> 0 : Loop
' Interrupt routine playing a single half-beat (per channel) from the music%()
array.
Sub music.play_interrupt()
Local i%, n%, halted% = 0
Static nlast%(NUM_CHANNELS%)
Local f!
n% = Peek(bp music_ptr%)
Select Case n%
 Case 0
'   Play Sound i%, B, O
  Play note off 1,nlast%(i%)
  nlast%(i%)=0
  Print Str$(i%) ": Rest"
 Case 1 To 254
  f!=440 * 2^((n% - 49) / 12.0)
  Print Str$(i%) ":" f! " hz",n%, nlast%(i%)
  If n%<>nlast%(i%) Then Play note on 1,n%,127
  nlast%(i%)=n%
'   Play Sound i%, B, T, f!, 15
 Case 255
  Print Str$(i%) ": Halted"
  Inc halted%
End Select
' Inc music_ptr%
Next
If halted% = NUM_CHANNELS% Then music_ptr% = 0 ' Halt
Edited 2023-12-29 04:26 by matherp
crazycloud
Posted: 06:35pm 28 Dec 2023
thank you
I tried 1,80,127.  Just got a click sound. I tried running the program, still just a click. I immediately tried play midi test 2, and got all the different sounds.
Posted: 06:42pm 28 Dec 2023
Just tried it on a WebMite and works fine
Attached is the firmware I'm using just in case
If you use PLAY MIDI TEST then make sure you set it back to normal afterwards
PLAY MIDI TEST 0
PicoMiteWeb.zip
Edited 2023-12-29 04:45 by matherp
crazycloud
Posted: 07:15pm 28 Dec 2023
I just loaded your .UF2 file.  same result. just a "click".  But the play midi test works fine.
crazycloud
Posted: 07:17pm 28 Dec 2023
N:72
N:73
N:74
N:75
N:76
N:77
N:78
N:79
N:80
N:81
N:82
N:83
N:84
N:85
N:86
> play midi test 0
Error : 0 is invalid (valid is 1 to 3)
> play midi test 0
Error : Midi output not enabled
> play midi
Real Time MIDI mode enabled
> play midi test 0
>if I try to turn off midi test with a "0" it tells me its invalid
crazycloud
Posted: 07:25pm 28 Dec 2023
I interupted the midi test with crtl brk
typed in play midi test 0
I got midi not enabled as a result
Posted: 07:32pm 28 Dec 2023
Power the Pico and VS1053 off completely. Then DON'T use test. Just play the file I attached. If that doesn't work I don't know what to suggest as I've tested thoroughly. The VS1053 can be forced into different modes depending on the wiring but I can't see how the test would work but not the real-time as they use the same code.
crazycloud
Posted: 07:37pm 28 Dec 2023
[324] Execute "LongString Append music%(), Chr$(LGetByte(channel" + Str$(j%) + "%()"
Error : Expected closing bracket
ran program but got this error on line 324
Posted: 07:51pm 28 Dec 2023
  crazycloud said  ran program but got this error on line 324
Note that that line is broken in two. Delete the carriage return at the end to combine back to one line.
crazycloud
Posted: 08:28pm 28 Dec 2023
error is now corrected.  Still just a "click" I have 2 other VS1053 boards. I also have a VS1053 shield that I got from ADAFRUIT. Its meant to be used with an Aurdino.
I will try the other hardware tonight. Thank you for all the work you do here. Its very awesome hardware and software.
crazycloud
Posted: 08:49pm 28 Dec 2023
It's working. Your entertainer program is playing.  I have no idea what I did to make it work.  The last thing I did was remove 2 carriage returns from the listing.  I also had it powered off for about 5 minutes.   GREAT SOUND!!!!!
Posted: 08:12pm 29 Dec 2023
Hi @crazycloud,
Thanks for the coffees .
"The Entertainer" program of mine that Peter posted seems to be of fairly early vintage, and note he has "hacked" it somewhat (to use the Midi support) most significantly replacing PLAY SOUND with PLAY NOTE.
There is a more elaborate version of the original program with 5 tunes here: https://github.com/thwill1000/mmbasic-sptools/blob/master/src/spmusic/spmusic.bas
But it would need equivalent "hacking" for Midi, and I don't have the board to troubleshoot that for you. Could someone point me at a link to a known working board and perhaps I'll get one.
Edited 2023-12-30 06:19 by thwill
Posted: 08:25pm 29 Dec 2023
PicoGAME 4 will be out soon in a CMM2-size format. This is the type that it will use:
The red one
Note: male pins should be fitted from the Top of the board so it can be plugged in upside down. It came with no pins fitted.
At the moment I can't confirm that it works. :)
Edited 2023-12-30 06:26 by Mixtel90
crazycloud
Posted: 08:42pm 29 Dec 2023
the exact midi board I used is this one
https://www.amazon.com/HiLetgo-Recording-Microphone-Interface-12-288Mhz/dp/B07XCN3C7B/ref=sr_1_1_sspa?crid=P0892AAMM16X&keywords=vs1053+mp3+module&qid=1703882019&sprefix=vs1053%2Caps%2C288&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
don't connect the output to anything with a ground. I blew up my first board!
I have the out put connected to a cheap audio transformer
this one
https://www.amazon.com/dp/B09KGXSJ12?psc=1&ref=ppx_yo2ov_dt_b_product_details
I'll try the other program now.  The input is much appreciated.
Posted: 12:02am 30 Dec 2023
Does Peter's Midi version of "The Entertainer" sound "off" ? It *looks* like he is treating my note encoding as if it were the Midi note encoding, but I don't believe it is, it is offset (and it appears that the original and newer versions of my code used different offsets - scratches head) .
crazycloud
Posted: 12:57pm 30 Dec 2023
Good Morning.  When you say "off" do you mean the notes are off frequency?  It sounds
accurate but I don't have anything to compare it to.
I'm studying the snippets of code like this one
"Play note off 1,nlast%(i%)
 nlast%(i%)=0
Case 1 To 254
 nlast%(i%)=n%
'   Play Sound i%, B, T, f!, 15"
to see how the notes are translated into midi notes.
I see where regular play is commented out.
I just started using a program called "noteworthy composer".  You can import a .mid file. As it plays a staff is displayed on top with the notes.  On the bottom is an 88
key keyboard that indicates what notes are being played.  It looks like this.
I have a image that shows what keys are the equivalent midi note.  But this is kind of convoluted.  The equation method is much better. I'm having a lot of fun  playing the entertainer with many different instruments.  I have an extremely large collection of .mid files that could be used in games.
Posted: 02:06pm 30 Dec 2023
Tom's code was just a very simple way of my testing real-time midi. I have no idea if the note mapping is correct but if it isn't then I think it just plays in a different key i.e. it transposes the music
Posted: 02:25pm 30 Dec 2023
The "octave" rather than the "key" is different.
In the "MIDI note encoding" Middle-C (C4, 261.63Hz) is note 60.
In the version of "The Entertainer" code in this thread, C4 is encoded as note 52 (C3, 263.74Hz in MIDI), so as luck would have it, it is exactly one octave lower, hence it still sounds OK.
However in the later version I linked to on github, C4 is encoded as note 49 ... so it will sound rather funky when played via MIDI without being transposed.
Now that I've become aware of the MIDI standard I will look at changing my code to adhere to it when I find the opportunity ... I'll be spending some of my coffee money on one of those boards.
Edited 2023-12-31 00:39 by thwill
Posted: 02:53pm 30 Dec 2023
  Quote  In the "MIDI note encoding" Middle-C (C4, 261.63Hz) is note 60.
How many tones in an octave?
