Local Time 09:52 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : VGA & HDMI 7" display
     Page 1 of 3
Posted: 09:30am 02 Nov 2023
Just received this display and tested rather briefly.
Power via USB C connector, draws about 360mA.
Seems to auto-select VGA or HDMI (tried with a Picomite & RPI3).
Posted: 12:20pm 02 Nov 2023
Just ordered one too. With the build in speakers and VGA a nice companion for the VGA picomite...
Posted: 12:31pm 02 Nov 2023
Looks nice. Would have been even better if the touch worked, but it looks like it doesn't. Still good for a little monitor though.
Pluto
Posted: 12:58pm 02 Nov 2023
Ordered.
Is it also possible to power by the DC connector? 12V in?
If powered by DC connector, will it then be possible to get 5V out from the USB connector (to power PicoMiteVGA)?
Fred
Martin H.
Posted: 05:19pm 02 Nov 2023
  Volhout said  Just ordered one too. With the build in speakers and VGA a nice companion for the VGA picomite...
I can't
  Quote  This product can't be shipped to your address.
Select another product or address.
'no comment
pwillard
Posted: 05:25pm 02 Nov 2023
so why advertize touch screen if it doesn't work?
Martin H.
Posted: 05:36pm 02 Nov 2023
  pwillard said  so why advertize touch screen if it doesn't work?
I think it acts like a USB Mouse, so we have no way to read it out on the Pico
'no comment
Posted: 06:44pm 02 Nov 2023
I haven't tried touch (not needed where I have it).
I doubt you'd get 5V out of the USB but don't know.
Unless the web page shows the voltage for the other power socket I don't know what is appropriate (I just used the USB).
Posted: 06:46pm 02 Nov 2023
From the comments buyers aren't seeing a USB device when they take power from USB. Whether it needs a special driver (not supplied and no link to one) who knows? It may just be advertising "poetic licence", being China.
pwillard
Posted: 07:03pm 02 Nov 2023
Ah,. not like thats never happened.  Some of the word salad I've seen for keyword matching is way out of control.
Plasmamac
Posted: 10:37pm 02 Nov 2023
Butchered an old ipad 3 for the screen .
Got an Ali Adapter for.
Now i got a 2k Monitor for the Picomite which works on Mode 1 and Mode 2 on the Picomite 🥳
Adapter has VGA and HDMI so its usefull for Pc also.
Powered with 12v and 1A source .
No chassis atm because my cnc needs a update to Estlcam.
One pic Picomite, the other is 2k playing Sauerbraten 🥳.
Mit freundlichen Grüßen
Plasma
Turbo46
Posted: 12:39am 03 Nov 2023
  Quote  Just received this display and tested rather briefly.
Looks interesting but how do you use sound if not via HDMI?
Posted: 01:04am 03 Nov 2023
It appears to have an audio jack (blue) between the DC in and VGA in sockets.
Turbo46
Posted: 01:15am 03 Nov 2023
Sorry, I don't see that. Are we looking at the same thing?
Posted: 01:21am 03 Nov 2023
No, sorry I was looking at the photo above your previous post.
Edit
It might be possible to open it up to find the audio amp and add an input jack.
Edited 2023-11-03 11:23 by phil99
Posted: 06:22am 03 Nov 2023
Oops,
I thought the AV was a 3 pin jack. But it is RCA…
Posted: 06:54am 03 Nov 2023
I recently purchased this 10 inch monitor.
https://www.ebay.com.au/itm/166304135676
The mount supplied is useless but it does have vesa mounting capability.
The IO is out the bottom which is not ideal but it has everything you need.
Supplied with many cables and a 12V plugpack.
There are plenty similar units available.
Turbo46
Posted: 07:04am 03 Nov 2023
That looks good thanks Jim. Can you use the audio input in conjunction with VGA?
Posted: 07:37am 03 Nov 2023
@ Plasmamac - Danke.
Ich lerne immer noch Deutsch, aber ich bin immer noch beschissen...
(I'm still learning German, but I still suck...)
But I might have to get one of those little monitors!
The price is sweet for the inputs it supports.
Pluto
Posted: 08:25am 03 Nov 2023
Plasma,
I have also recycled 2 old Laptop displays by using similar AliExpress LCD adapters/drivers.
https://www.thebackshed.com/forum/ViewTopic.php?TID=14650&PID=183631#183631#183631
One of the displays has been powered continously for about 1.5 years. Most of the time in stand-by mode. Not seen any problems sofar.
12V power to the LCD adapter and 5V out that directly powers the PicoMiteVGA.
The adapters were supplied with small remote controls. When the display is swithed on, the Pico starts with the same keypress.
     Page 1 of 3
