Local Time 02:26 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBsic 2023 programming challenge
Posted: 02:43pm 15 May 2023
Previous years (2021 and 2022) there was a programming challenge for MMBasic microcontrollers and microprocessors.
In general the rule where that you had to write a small program (maximum 5 kbyte) to compete, and a team of judges would determine ranking.
I found these challenges very exciting, and look forward to this years challenge. We could use the same set of rules used last year, but maybe there are proposals for adaptations of these rules... (i.e. program size (*), use of peripherals (RTC module, game paddle), supporting documentation etc...).
To kick off the discussion I start this thread.
(*) since many contestants will do this in spare evening hours, promoting large programs may hold some contestants off. Since we want many to compete... make things simple.
Edited 2023-05-16 00:44 by Volhout
Posted: 03:00pm 15 May 2023
I guess somebody had to bring this up .
I'm happy to help organise and make a results video, but would be even happier if someone else wants those responsibilities.
Let's start with a show of hands/interest.
Assuming (and it is an assumption) we used the same rules as last time and set a deadline for the end of August (is that too far away?) then who is likely to submit an entry ?
   https://github.com/thwill1000/mmbasic-challenge/blob/main/2022/challenge-2022.pdf
lew247
Posted: 04:33pm 15 May 2023
Why not make it different this year and limit it to the Pico?
That would make it a lot harder but also more interesting because it wouldn't have to be just mostly games, but the possibilities using the pio could make it pretty interesting
Posted: 04:46pm 15 May 2023
I will compete, put me on the list.
In case there are plenty candidates, I could withdraw an be one of the judges.
This is one of the best things for this forum. Bundle good ideas and energy into a common goal.
I still cherish the feedback I got from others (i.e. vegipete) to improve my own program.
Lets make this a success...
Posted: 04:51pm 15 May 2023
  lew247 said  Why not make it different this year and limit it to the Pico?
Good idea. But PIO most likely means connecting something to the IO pins. Last year that was not allowed. So we would need to change that rule, and agree that contestants provide support to make it do-able for the judges. I.e. provide HW.
Posted: 05:08pm 15 May 2023
Maybe there could be a restriction on what the GP pins could be used for. e.g.
Acceptable:
Digital / switch inputs
Analogue / resistance / voltage inputs
Digital outputs
Not acceptable:
Communication (I2C, SPI, COM)
PWM
IO expansion
Something like this would be needed so that no specialist IO stuff is needed for the judges. I left out PWM to prevent things like servos. Not sure whether PIO routines would be ok.
And just to rub it in, programs must be able to run on VGA systems. LCD programs are acceptable, but must not require Touch and a VGA-compatible version must also be submitted if the same program cannot work on both.  :)
PeteCotton
Posted: 05:27pm 15 May 2023
The hardware side might become a significant hurdle for the judges (having to wire up multiple projects). A possible way around it might be to have people make a video of their project working. I think we all trust each other enough that there wouldn't be any "cheating/fakery". Of course, then it ceases to be a programming challenge and becomes more of a control system challenge - but there's nothing wrong with that IMHO. Then it could be opened to all variations of of "mites" even the original ones.
Martin H.
Posted: 05:45pm 15 May 2023
  Volhout said  I will compete, put me on the list.
 me to
Edited 2023-05-16 03:46 by Martin H.
'no comment
TimD
Posted: 05:58pm 15 May 2023
I may be interested - I think it depends on the parameters of the challenge, and whether I can come up with any new ideas this time.  Although I'm reasonably capable of hooking up some hardware, I'd probably attempt a software-only entry.
I'll lurk and see how the discussion unfolds...
Kind regards,
Tim.
LucV
Posted: 06:24pm 15 May 2023
Sounds interesting.
But we have a really wide spectrum of units.
What do the members want.
Only a uniform programming chalenge or something more wide like splitting the challenge up for the different versions.
Would be difficult to judge a WebMite program that does something complicated on the web against a PicoMiteVGA program.
Judging would be difficult but a no limits challenge should be interesting.......
Well only limit is Pico (standard version so no second source manufacturers) and Basic of course.
So PicoMiteVGA, PicoMite standard and Webmite allowed and anything you can attach to them.
Edited 2023-05-16 04:25 by LucV
Luc's tech Blog
Posted: 06:35pm 15 May 2023
There's no point in having a competition where entries can't be judged by several judges. That will mean having a lowest common denominator that all judges can use. The Webmite is still too new and specialised IMHO. The cheapest, most accessible option for all entrants is a PicoMite VGA. Even those who don't have one wouldn't be much out of pocket to rig up a Pico, four resistors and a VGA socket on a breadboard.
Posted: 09:17pm 15 May 2023
Webmite would be great in this challenge...
Something all judges can judge.
Edited 2023-05-16 07:25 by Volhout
Quazee137
Posted: 09:22pm 15 May 2023
I'll be on the side lines as I don't use the VGA and games are not my forte
unless it is minecraft.
I do love seeing all the games MSBasic had been used for.
Have FUN I'll be watching in on it.
Quazee37
  Quote  Webmite would be great in this challenge...
Andrew_G
Posted: 09:52pm 15 May 2023
WebMite for me   too.
It makes IoT a very real possibility. I would suggest this as a theme?
Contestants would have to monitor and control multiple devices/sensors and use some sort of display to monitor and control them and show the results.
Instead of having to provide the physical devices to monitor and control, a contestant could specify them and their interface(s). A video (or stills??) would help.
I would also be happy to volunteer to fund, or contribute to, a prize although I see this as 'recognition' rather then 'incentive'. It might take the form of a 'plaque' or 'medal' or 'whatever' to display in the winner(s) messy workshop.
Something somewhat short of the Nobel bequest (and I'm still alive) and consistent with previous years.
I am NOT competent to be a judge but as I have benefited so much from MMBasic and TBS I would be very happy to put a little back.
Cheers,
Andrew
Edited 2023-05-16 07:53 by Andrew_G
Posted: 10:14pm 15 May 2023
I have limitted experience, but feel that the html file size easily surpasses the 5 kbyte. And then you aad the bas file.
Webmite could violate many rule when using online content.
So some changes would be needed.
Posted: 10:16pm 15 May 2023
  Andrew_G said  WebMite for me ... and use some sort of display to monitor and control them and show the results
Browser?
Turbo46
Posted: 12:05am 16 May 2023
Having a competition for software and keyboard only entries does mean that most of us can run and test the entries. Not just the judges and I think that is importand. That pretty much limits the entries to games and utility programs though.
The only way I see to make it a more 'open slather' competition is to do as Pete said, a video must be made, the software must be published along with any schematics and a 'user manual'. Program size and the hardware used would not then be an issue.
Judging could be done by the whole community where each member could rate each (and every) entry on a 'voting form' which then could be tallied up by single judge or a team of judges.
There are many members who seem very knowledgeable but have never submitted any code for other people's benefit or use. This may encourage them to do so.
Having said that the previous competitions were called 'software challenges' and they have served us well and as they say: 'it ain't broke...'
That's my tuppence worth.
Posted: 12:15pm 16 May 2023
There are many interesting topics, and apparently there is interest in each of them. So it is either choose, or allow all....
- Webmite: New to this forum, but might need adapted rules to be viable (program size / web content)
- Picomite PIO: Rather new, but might need adapted rules (peripherals)
- Classic 5k: proven last 2 challenges
Since forum members would like to play with the new features (Web / PIO) I suggest we adapt the rules.
I for myself would love to see what others can do with the Webmite, for me this is new territory (started following LucV's training). I am also looking forward to Geoff's presentation of his garden watering system, just to see how it is done....
My HTML knowledge is sub zero. And in combination with your own server in MMBasic...wauw...
Eager to learn...
Edited 2023-05-16 22:17 by Volhout
PeteCotton
Posted: 08:43pm 16 May 2023
My tuppence: Once again, I don't know if I will have time to provide anything meaningful to this competition, but having a web-based or hardware aspect to the competition is certainly an exciting change. While the 5K limit made sense for the programming only challenges, I think it might be wise to discard it if we are using anything external to the processor (such as web or hardware). It becomes far too hard to define matching limits on these external factors. I get that the original reasoning for the 5K limit was to make the project more accessible, but once there are external factors, that kind of goes out of the window. What if your hardware is extremely impressive but your program isn't? How much can be downloaded off the web?
Given that it is a fun challenge, maybe it's better to leave the rules open and just give people a remit such as "make something really cool", and then leave it up to the group to judge what impresses them most. This isn't high stakes, the reward isn't the end goal for most people - it's the fun of participating with your friends. [Yes - I do consider you to be friends - if you're ever in Alberta I'll happily buy you a beer.]
