Local Time 10:44 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic for Windows - alphas
     Page 1 of 12
Posted: 03:50pm 16 Feb 2022
MMBasic for Windows V5.07.03a0
MMBasic.zip
The MMBasic for Windows code is now officially past the pre-alpha phase and enters alpha. i.e. most of the functionality is now there and there are not too many reports of issues but there is still work to do.
The big change in V5.07.03a0 is support for proper transparency as per the CMM2
The mode command is changed as follows to follow the CMM2 as closely as possible:
MODE modeno [,alphaenabled] [,background colour]
By default alphaenabled is 0 and the background colour is BLACK
To use the second layer set alphaenabled to 1 and optionally choose a background colour
Unlike the CMM2 MMbasic for windows uses full ARGB8888 colour in all modes and has a transparency value (A) of 0-255
When you change the mode to alpha by default you are still writing to page 0 and it is cleared to RGB(BLACK)which is opaque. If you want to see the background colour pixels on page 0 must be written with a transparency of less than 255. Use CLS RGB(BLANK) to clear a page to completely transparent.
If you set to write to page 1 this will overlay page 0 and the background to the extent that the alpha value of the pixels on PAGE 1 are set (between 0=transparent and 255=opaque).
Note when playing with this at the command line you can get very confused so it is easier to understand what is happening with a very simple program.
mode 14,1,rgb(magenta) 'set into 2 layer mode with the background set to magenta
font 3
print "Click to get focus"
mouseclick
print "now we will clear page 0 to blank"
print "click to continue"
mouseclick
cls rgb(blank)
colour rgb(black),rgb(blank)
print "This text is written on page 0 with transparent backgound"
mouseclick
print "Now we will write to the top page"
mouseclick
page write 1
cls rgb(blank)
sprite loadpng 1,"apple"
sprite write 1,50,10,1
sprite transparency 1,128 'change the transparency of the sprite
sprite write 1,200,10,1
page write 0
print @(0,mm.info(fontheight)*4)"You can see the page 0 text through the right hand apple"
print
print "Click to exit and remember to click again to get focus"
mouseclick
sprite close all
mode 14
colour rgb(white),rgb(black)
end
sub mouseclick
do
loop until mouse(l)
do
loop until not mouse(l)
end sub
apple.zip
Finally a note on the RGB function.
RGB(COLOURNAME) will return a fully opaque representation of that colour
RGB(red, green, blue) will return a fully opaque representation of that colour
use RGB(red, green, blue, trans) to set a partially transparent colour
If you must, you can use numerical values directly as colours e.g CLS &H80607080
This will set the transparency to &H80, the blue level to &H60, the green level to &H70 and the red level to &H80. Note that red and blue are reversed compared to the CMM2 if a direct numerical value is used in this way i.e ABRG8888
Posted: 06:34pm 16 Feb 2022
V5.07.03a1
MMBasic.zip
Forgot to mention above right clicking in the editor on the first character in the line is the same as HOME. Right clicking after the last character in a line on on the last character if the line exceeds the screen width is the same as the END key
This version includes the ability to send a BREAK "character" on the serial port.
e.g.
OPEN "COM1:9600" as #1
PRINT #1,BREAK
This will send a break which is set to be 20 bit lengths of the port held in the zero state. I've even tested it on the scope and it works
Romeo
Posted: 07:00pm 16 Feb 2022
Great work!
But you have too much creativity, we cannot follow your rythme to test all these new stuffs. I just tested the transparency and it works like a charm, it will be usefull for my need (a moving map using scroll, with sprites scrolling with it or standing still on the screen, and with text showing the Points of Interest: the text transparent background will sure look more 'professionnal' )
Beside that, things seems to slowly forking away from the CMM2 features, I was expecting MMBasic-4-Windows to mimic the CMM2, in a attempt to keep the code portable. Or maybe the MMBasic-4-CMM2 would benefit from your actual work, and both will join together? Only time will tell! Keep the good work! Thanks!
Michal
Posted: 07:22pm 16 Feb 2022
Hi matherp,
Version a1 behaves more unstable than a0.
Sometimes it doesn't start from BAS. It closes unexpectedly.
Michal
Posted: 07:30pm 16 Feb 2022
  Quote  Version a1 behaves more unstable than a0.
Bizarre the change is trivial just the BREAK feature
Try the attached I've done a clean build
MMBasic.zip
Pluto
Posted: 08:09pm 16 Feb 2022
Serial communication works well up to 230400 Baud (with a Microbridge). For higher speed, do you think an other type of USB-TTL like CP2102 would help? Any ideas where the bottleneck could be?
Tested with an old DIY ECG. Faster datastream would be needed for diagnosis; but at least i can see that the patient is alive.
Regards Fred
Michal
Posted: 08:13pm 16 Feb 2022
MMBasic.zip
Unfortunately, no changes.
a0 definitely more stable. It always starts. It never closes unexpectedly.
ADD: Tests on your apple.bas
Michal
Edited 2022-02-17 06:23 by Michal
Plasmamac
Posted: 10:34pm 16 Feb 2022
can confirm :
first apple.bas start works a while when crush.
new starts : fps drops to 1 fps when crush.
restarting pc now and test again.
cu
after restating win all the same
apple.bas crushs .
btw ; why not adding a textfield to
 "MMBasic - Shortcut" and create a debuglog with.
it will not crushing and we can see the problems if we make debuglog " here iam"
Edited 2022-02-17 08:45 by Plasmamac
Plasma
Posted: 10:45pm 16 Feb 2022
Try again
MMBasic.zip
Michal
Posted: 10:51pm 16 Feb 2022
  matherp said  Try again
MMBasic.zip
It looks like this build is stable.
(What was that?)
Michal
Edited 2022-02-17 08:55 by Michal
Plasmamac
Posted: 11:14pm 16 Feb 2022
works
Plasma
Posted: 07:52am 17 Feb 2022
  Quote  I was expecting MMBasic-4-Windows to mimic the CMM2
Not aware of any significant differences. The mode command is slightly different because there is only one colour depth in windows. On the CMM2 the different colour depths are there because of display performance issues and not because they are a preferred approach.
Question to all: what areas am I still missing and have forgotten? #INCLUDE is the obvious omission.
Plasmamac
Posted: 08:01am 17 Feb 2022
Play ( sound overall)
Option Angle
Execute
Edited 2022-02-17 18:02 by Plasmamac
Plasma
Posted: 08:03am 17 Feb 2022
  Quote  Option Angle
Really? That was only included for educational uses and shouldn't be needed for "real" users
Plasmamac
Posted: 08:19am 17 Feb 2022
Why not , maybe implement later
Plasma
Plasmamac
Posted: 08:28am 17 Feb 2022
Forget - load data
Plasma
Posted: 09:30am 17 Feb 2022
  Quote  Forget - load data
Already there
Romeo
Posted: 09:33am 17 Feb 2022
Concerning the differences between CMM2/Windows coding approach, I mean, for example: as I am very interrested in the scrollable feature of the Framebuffer (using the FB WINDOW command), I'm concerned by the size it takes in memory; a 24bits colors MODE in Windows gives a bigger FB size in memory than a 8bits, just... the triple. On Windows it does'nt matter, but on CMM2 it is crucial, as memory is very scarce. If the MODE command in Windows works differently as in CMM2, the code is just, as you say rigthly, slightly different; I need to dig a bit more what I wanna do, and how to do it, to keep the code portable between Win/CMM2.
Goksteroo
Posted: 09:49am 17 Feb 2022
  matherp said  Question to all: what areas am I still missing and have forgotten?
GUI Cursor commands?
The way F1 works on CMM2 - select a folder and load a program from within it.
Michal
Posted: 08:35pm 17 Feb 2022
Hi matherp,
I get such an error
[831] Arc x%,y%,x1%,y1%,els,ela,c%
Error : Radials
in the course of the execution of the following
 For i%=1 To 100
   x%=Rnd()*maxx
   y%=Rnd()*maxy
   x1%=Rnd()*maxx
   y1%=x1%+(Rnd()*30)
   if y1%=x1% then y1%=x1%+1
   c%=Rnd()*&hffffff
   els=rnd()*360 'random size
   ela=rnd()* 360 'random angle
 Next i%
Michal
     Page 1 of 12
