Local Time 15:39 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Laguage keyboards for MMBasic for Windows. Help needed
Posted: 11:58am 29 Jan 2022
If you have a non-UK keyboard and would like it to work properly I need your help.
Attached is a diagnostic version of the software. When you press any key you will see a number appear in angle brackets together with the character that number translates to on a UK keyboard.
MMBasic.zip
Mu understanding is that everything works properly except the special characters so what I need from you is a report as follows:
Specify the language keyboard tested
For each ascii character that doesn't work as you want
The ascii code you want
The number the firmware reports
VERY IMPORTANTLY The state of the shift and alt keys that you would normally use to get that ascii character
NB: the firmware will only ever support ascii so any character that doesn't have an ascii code won't be supported.
If someone gets in ahead of you with a specific language then please check their results and only post if there is an error.
I will need a US keyboard report where there should be only a few incorrect keys
The reason that this is necessary is that the firmware is operating at a very low level (key presses and releases). This has the disadvantage that I need to manage the mapping but has the advantage that I will be able to support the KEYDOWN function as per the CMM2
Tinine
Posted: 12:30pm 29 Jan 2022
Never tried this but if you select a particular keyboard language as the default, can the on-screen keyboard emulator provide the required info?
Craig
Posted: 12:37pm 29 Jan 2022
  Quote  Never tried this but if you select a particular keyboard language as the default, can the on-screen keyboard emulator provide the required info?
Possibly but I'm not prepared to install multiple languages on my PC and do all the slog work
andreas
Posted: 02:25pm 29 Jan 2022
  matherp said  If you have a non-UK keyboard and would like it to work properly I need your help.
MMBasic.zip
Hello Peter,
for the german keyboard, I found these keys (may be not complete, but the most importand)
-andreas
twofingers
Posted: 02:38pm 29 Jan 2022
@Andreas: A friendly, respectful note: It is not always necessary to post a full citation. I hope you get this the way it's meant ...
Michael
andreas
Posted: 02:45pm 29 Jan 2022
  Quote  I hope you get this the way it's meant ...
Thank you, but what is then the meaning of the "Quote" top right link?
-andreas
twofingers
Posted: 02:55pm 29 Jan 2022
  andreas said  ...
-andreas
This is not a prompt, just optional... and you can (reasonably) shorten/edit it.
... ist von mir aber nur als Hilfe gemeint! Ich moechte aber auch nicht als Oberlehrer wahrgenommen werden ...
Edited 2022-01-30 01:00 by twofingers
Posted: 02:57pm 29 Jan 2022
I use "Quote" and then delete all except what is needed to provide context.
twofingers
Posted: 04:08pm 29 Jan 2022
I found a useful tool: "Keycode.com". It displays the ASCII, ANSI, Hex, and Key code of each key pressed.
https://www.heise.de/download/product/keycode-12221
I hope it helps.
I just don't know how to present the results... an Excel spreadsheet? A picture of the keyboard? We had a similar mapping problem for the CMM2 before.
Posted: 05:36pm 29 Jan 2022
Peter doesn't want a full list for your keyboard. Only where it differs from the UK codes shown in the diagnostic version of MMBasic. It's no use sending him codes that are non-ASCII, like the UK ponds sign or the euro symbol, as they haven't got an ASCII code and won't be supported.
twofingers
Posted: 06:12pm 29 Jan 2022
  Mixtel90 said  Peter doesn't want a full list for your keyboard. ...
Thanks, but I understood that already correctly. But I think it would be about 20 or more cases for a German keyboard. Some keys ("<>") produce no response.
Plasmamac
Posted: 06:43pm 29 Jan 2022
anyone works for the german keyboard?
Plasma
twofingers
Posted: 06:51pm 29 Jan 2022
Finding out the codes its not the problem. I just don't know how best to present it so that Peter can use it.
andreas
Posted: 07:00pm 29 Jan 2022
if there would be an external "settings" file outside MMBasic.exe then everybody could configure her/his own keyboard layout.
-andreas
Edited 2022-01-30 05:01 by andreas
Plasmamac
Posted: 07:16pm 29 Jan 2022
@Andreas    no cmm2-style
Plasma
andreas
Posted: 07:24pm 29 Jan 2022
@[Plasmamac
  Quote  no cmm2-style
- you mean OPTION AUTORUN ON and a autorun.bas? - nice idea! I like the CMM2 and how it works!
Pluto
Posted: 07:47pm 29 Jan 2022
These are the keys that need some fixing.
As you can see there are several differences between what MMBasic displays and what is shown on the keyboard keys. I do not think that all need to be "translated". Indicated the necessary ones in the table.
The "<, >, |" key has no action at all in MMBasic.
Hopefully you can interpret my table. If not please advice me how to present.
/Fred
twofingers
Posted: 08:29pm 29 Jan 2022
Correction table for my German keyboard (MMBasic V5.07.03pa3)
"^" = Shift
"^^"= AltGr
MMBasic V5.07.03pa3
Ascii(MMBasic)
92  should be 94  = ^
^86  should be ^59 = ;
^84  should be ^58 = :
89  should be 35  = #
^89  should be ^39 = '
85  should be 43  = +
^85  should be ^42 = *
^^85 should be ^^126 = ~
93  should be 180 =  (suggestion: ^39 = ')
^93  should be ^96 = `
91  should be 223 =  (suggestion: 92 = \)
^91  should be ^63 = ?
^27  should be ^61 = =
^^27 should be 125 = }
^36  should be ^41 = )
^^36 should be  93 = ]
^35  should be ^40 = (
^^35 should be  91 = [
^34  should be ^47 = /
^^34 should be 123 = {
^33  should be  38 = &
^30  should be 167 =  (suggestion: ???)
^^64 should be  64 = @
90,94,88 (are german Umlauts)
The key ("\"+"|") below the "A" and to the right of the left shift key gives no answer.
Should give:
60,^62,^^124
Work in progress. I must have missed something ...
@Admin the board software multiplies the backslash \ if I edit my post.
Edited 2022-01-30 07:47 by twofingers
On my US keyboard (logitech)
94       # should be ' (single tick)
94 shift ~           "
90       '           ` (backtick)
90 shift @           ~
29 shift "           @
I have a different layout US keyboard that we had 'fun' with for the CMM2.
It is HP small form-factor US keyboard.
It has a second key for pipe-backslash |\ located to the left of Z. There is no response in the test program. The key to the right of keyboard is correct giving |\
In the CMM2 software there is a line at the end of the keyboard maps:
92,124    //USB_HID_KEYBOARD_KEYPAD_KEYBOARD_NON_US_FORWARD_SLASH_AND_PIPE           = 0x64,
I think this was the culprit.
Edited 2022-01-30 07:15 by TassyJim
goc30
Posted: 02:26am 30 Jan 2022
my config : French keyboard AZERTY
keyboard.zip
Edited 2022-01-30 12:31 by goc30
