Local Time 08:01 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: bug in 5.07 - I'm not deliberately looking, honest
Posted: 10:12am 02 Jul 2021
I truly wish I hadn't found this, at least Peter can take solace in that it is probably one for Geoff:
> 480MHz Colour Maximite 2 G2
MMBasic Version 5.07.00RC4
Copyright 2011-2021 Geoff Graham
Copyright 2016-2021 Peter Mather
> list "do_loop_bug.bas"
Option Base 0
Option Default None
Option Explicit On
foo(1)
Sub foo(i%)
 Do While i% < 2
   foo(i% + 1)
> run "do_loop_bug.bas"
Error in line 10: LOOP without a matching DO
Posted: 10:21am 02 Jul 2021
I think this is a known issue where you can't use do loops in recursion in this way - certainly the MM2 displays the same symptoms
Edited 2021-07-02 20:33 by matherp
Posted: 10:34am 02 Jul 2021
  matherp said  I think this is a known issue where you can't use do loops in recursion
Thanks Peter, I thought it looked familiar.
Note that to avoid infinite looping foo() should be written:
Sub foo(i%)
 Do While i% < 2
   foo(i% + 1)
   Inc i%
... which still shows the same problem.
Posted: 10:52am 02 Jul 2021
As Peter said, it is a known issue.
BASIC is not really suited to recursion.  To allow recursion the current state of the program needs to be pushed onto a stack and, given the way BASIC works, that is a lot of data.  I used some tricks to allow limited recursion but there are problems.
In the Micromite manual I warn against recursing within loops and I should have copied that text across to the CMM2 version.
BTW, I know that "recursing" is not a proper word
Edited 2021-07-02 21:03 by Geoffg
Posted: 10:57am 02 Jul 2021
Thanks Geoff,
  Geoffg said  BTW, I know that "recursing" is not a proper word
Of course it is, every time I ask Peter for a feature and he says "No" I am "re-cursing" him .
Just kidding,
Edited 2021-07-02 20:57 by thwill
Lodovik
Posted: 05:11pm 03 Jul 2021
Hi,
I have one to report too, discovered by mistake. When I type MODE and press ENTER, my CMM2 freezes up to the point I must do a power cycle. I'm on official 5.07.00 with a 480 MHz unit with no extensions, a pre-assembled Gen1 CMM2 I bought on Micromite.org a month ago.
Thanks.
Posted: 05:23pm 03 Jul 2021
I've added it to the known bug list https://geoffg.net/Downloads/Maximite/CMM2_Current_Bug_List.txt
Will fix in the next release but the workaround is obvious
William Leue
Posted: 01:22am 04 Jul 2021
When I want to implement an algorithm that is fundamentally recursive, and where changing it to purely iterative would substantially "uglify" a nice clean recursion, I just use an explicit stack and push/pop the variables that would change in a real recursion. It's easy, reasonably efficient, and avoids the tight recursion limit.
-Bill
Posted: 04:53am 04 Jul 2021
Push/Pop is worth thinking about.  There would still be limitations but with the great amount of memory on the CMM2 it might work (but probably not on the Micromites).
I will look into it.
Posted: 08:34am 04 Jul 2021
  Quote  Push/Pop is worth thinking about. I will look into it.
Sounds interesting. For the CMM2 I would recommend using VAR PUSH and VAR POP as the commands as I don't have two command slots free (or even one!)
Posted: 09:16am 04 Jul 2021
Recursion: "If we had an index file, we could look it up in the index file under index file!"
MauroXavier
Posted: 05:38pm 05 Jul 2021
The MEMORY command freeze my CMM2 G2 in any option configuration, even after reflashing the firmware with the option to clear all flash memory.
Posted: 05:46pm 05 Jul 2021
  MauroXavier said  The MEMORY command freeze my CMM2 G2 in any option configuration, even after reflashing the firmware with the option to clear all flash memory.
Just vanilla "MEMORY" ? Works on my G2 (prototype):
> option list
CURRENT VGA mode 800x600 RGB332
CURRENT DISPLAY 50,100
OPTION USBKEYBOARD UK, 1
OPTION RAM ON
OPTION KEYBOARD REPEAT 200,50
OPTION SEARCH PATH /bin/
OPTION F11 chdir "/zmim/src"<crlf>
OPTION F12 chdir "/sptools/src"<crlf>
> memory
Program:
  0K ( 0%) Program (0 lines)
516K (100%) Free
Data:
  0K ( 0%) 0 Variables
  0K ( 0%) General
24800K (100%) Free
Edited 2021-07-06 03:47 by thwill
Posted: 06:12pm 05 Jul 2021
Just downloaded the binary from Geoff's site and programmed over UART on identical H/W and it works fine.
Try OPTION RESET, if that doesn't work then I suggest you re-program with flash erase all first. Then option reset, then try again
UPDATE: if the problem persists then please type VAR CLEAR and then MEMORY - what happens?
Tom: please try var save/restore on your G2 with and without power cycling
Edited 2021-07-06 04:56 by matherp
Posted: 07:11pm 05 Jul 2021
  matherp said  Tom: please try var save/restore on your G2 with and without power cycling
I don't know what I'm looking for, and I didn't find it. All looks good to me.
MauroXavier
Posted: 11:55pm 06 Jul 2021
  matherp said  Just downloaded the binary from Geoff's site and programmed over UART on identical H/W and it works fine.
After a VAR CLEAR the MEMORY commands works ok, but after a reset I need to use always VAR CLEAR otherwise the system hangs again after the MEMORY command.
Edited 2021-07-07 09:56 by MauroXavier
Arno
Posted: 08:50pm 12 Jul 2021
I have the same problem as MauroXavier on one of two G2 systems.
Both systems run the same MMBasic Version 5.07.00.
Arno
Posted: 11:09am 13 Jul 2021
Mauro and Arno
Please could you try the attached experimental version. You won't get the lockup with the memory command. This is easy to fix but the question is does VAR SAVE and VAR RESTORE work?
So please:
A=10
VAR SAVE A
CPU RESTART
VAR RESTORE
? A
You should get 10 on any H/W
Now repeat but power off and on before the VAR RESTORE. Please report both success and any problems
Peter
CMM2V5.07.01b1.zip
Arno
Posted: 12:00pm 13 Jul 2021
Hello Peter,
with power on and CPU RESTART everything worked.
With power off before VAR RESTORE I get the error message,
SAVED VARS CORRUPT - MEMORY CLEARED.
Arno
EDIT:
Direct after power on:
> a=10
> var save a
This freezes the Maximite G2.
Edited 2021-07-13 22:15 by Arno
Posted: 12:21pm 13 Jul 2021
Arno
Thanks for the info. I can fix the lockup but this still leaves us with the issue of why VAR SAVE doesn't work on a very small number of machines. I've posted on the STM forum to see if anyone has any ideas
