Local Time 23:46 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ArmmiteF4 firmware: V5.06.00
     Page 1 of 3
Posted: 06:51pm 09 Feb 2021
Please find attached new firmware for the ArmmiteF4. This includes various bug fixes that Geoff has included in recent MMBasic releases, some minor optimisations from the CMM2 and a bug fix for a memory corruption using sprite close.
ArmmiteF407.zip
Like all STM32 you can program the firmware directly over the USB connection see here and here for lots more information about programming and the ArmmiteF4 in general
For those that don't know about the ArmmiteF4, it is my favourite MMbasic port. A single board that has everything you need - USB serial port, RTC with battery, SDcard slot, TFT header. It runs faster than the MM+ and is much cheaper as a complete system. Lots of projects like Geoff's Super Clock, DDS signal generator, and boat computer are easy to port to the ArmmiteF4 with display and run superbly.
The matching display is 16-bit parallel and very fast
Buy the pair from here and many other vendors
Note there are lots of variants of STM32F407 development boards. You must buy the one pictured for the firmware to work.
The only downside is that there isn't currently a dedicated manual for the ArmmiteF4. To create one is just a cut and paste exercise so if anyone wants to volunteer I would be happy to provide word files and guidance.
Edited 2021-02-10 04:58 by matherp
Posted: 09:25pm 09 Feb 2021
Thanks for the update. That works. After programming firmware on F4 with 4.3" 480x272 LCD:
OPTION LCDPANEL DISABLE
OPTION LCDPANEL SSD1963_4_16,L   [Power cycle]
OPTION TOUCH PB12, PC5
gui calibrate
F10 [AUTOSAVE] (after selecting my code on the PC)
Ctrl-Z [save program]
F2 [run]
Ctrl-C [quit]
F2 [run again]
(As ever, the LCD is crisp, though photo from my phone is mangled.)
Perhaps it is greedy to look for a path forward after this very welcome update, but here goes. (First, this is also my favorite micromite--great price, great functionality.)
The Armmite F4 is a good candidate for a standalone "MMBasic computer" with a keyboard added and an LCD. Unfortunately, the 320x240 LCD which is readily available to order with the STM32F407VET6 allows lines only 53 characters wide with OPTION KEYBOARD and OPTION LCDPANEL CONSOLE 7 (the smallest available font, 6x8). The 4.3-inch SSD1963 (which requires an adapter board), is fine, with 480x272 pixels, which works out to an edit screen of 80x25 characters.
But that LCD and the even better 5" & 7" 800x600 are quite expensive for the 20-pin versions--$34 U.S. with shipping at a minimum (and require an adaptor).
To me, a much better fit would be the 480x320 SPI ILI9488, which would give an 80x40ish edit screen with font 7. Of course, it would also require a backpack to bring out the interface pins.  I would propose to design one which would also include a PS/2 keyboard connector, socket for RTC & ESP-01, mini-stereo socket, IR capability, and a 20x2 pi-type connector like that on the CMM2. The 3.5" ILI9488 can be had for $10US including shipping. There is apparently a 'loadable' driver for this LCDI think for the MM+ (and perhaps MMX). This would make a very capable "MMBasic computer").
On the firmware side, if space is available, JSON$ and FIELD$ would be helpful. Perhaps BLIT WRITE could be modified so that it could be used either without height and width specified (CMM2 style), or with those (for compatibility). If SPRITE could be accepted as an alias for BLIT, that would help in porting certain programs from and to the CMM2.
With regard to hardware, support for the STM32 "black pill" (which  almost works ) would be valuable. If the "blue pill" is an example, the black pill will be around for a long time. With an appropriate backpack PCB, that could provide much of what the STM32F407VET6 PCB does except for the high-speed LCD.
I understand that the CMM2 is a much hotter game if there is more on the burner there.
As always, thanks very much for your great work on MMBasic.
Edited 2021-02-10 07:28 by lizby
hitsware2
Posted: 09:35pm 09 Feb 2021
Does that display plug directly onto the board ?
my site
Quazee137
Posted: 09:58pm 09 Feb 2021
Yes
hitsware2
Posted: 11:26pm 09 Feb 2021
Neato .... Thank You ....
Is that a certain ' brand ' or ?
Edited 2021-02-10 09:29 by hitsware2
my site
Posted: 12:06am 10 Feb 2021
  hitsware2 said  Neato .... Thank You ....
Not the "black pill", not other STM32F4 varieties. Search aliexpress for "STM32F407VET6". If you want the LCD, pick, a site which shows it in addition to the F4 board.
Like this. Matherp's site has a better price.
Edited 2021-02-10 10:08 by lizby
lew247
Posted: 08:22am 10 Feb 2021
Amazon link to the board
Chopperp
Posted: 08:57am 10 Feb 2021
Hi Peter
Probably a bit much to ask but can the Serial only version be updated.
I now have 2 boards with the USB interface U/S.
You did email me an updated version at the time which worked. (25/09/2019)
No dramas if you can't.
  Quote  One last try: This version slows down flash access and disables cacheing. It is about 20% slower but does it work?
2019-05-25_213711_ArmmiteF4.zip
Original post
Brian
ChopperP
Posted: 01:04pm 10 Feb 2021
  Quote  Probably a bit much to ask but can the Serial only version be updated.
This version (V5.06.01) should be switchable. Program the firmware as usual. Then hold down KEY0 while you reset the board and it should switch it into serial console mode
ArmmiteF407.zip
NB: I've also tested this version on a "black pill" and it works fine. HOWEVER, the black pill is missing a 1.5K resistor from D+ to 3.3V. In the picture I've used a 1206 1.5K resistor between the top of R3 and 3.3V. With this mod W10 sees the USB CDC and I can connect with teraterm. The SDcard works fine. I haven't tried the display header as the pinout is non-standard but it should work suitably wired with a ILI9341. Do note that the standard of production of the black pill seems to be extremely poor. The usb connector fell off on mine the first time I pugged a cable in so I re-flowed all the components
Chopperp
Posted: 01:20pm 10 Feb 2021
  Quote  This version (V5.06.01) should be switchable. Program the firmware as usual. Then hold down KEY0 while you reset the board and it should switch it into serial console mode
OK, will try in a day or two. Thanks
ChopperP
Posted: 02:09pm 10 Feb 2021
am not sure if this has been discussed before, but has anyone looked at a port to the STM32F411:
https://www.ebay.com/itm/264823841719
https://www.st.com/en/microcontrollers-microprocessors/stm32f411ce.html
512k flash, 128k RAM, available on a 40-pin DIP PCB with USB-C connector for less than $10. this would be a nice alternative to a micromite E64. no onboard SD card, but a small daughterboard is cheap:
https://www.ebay.com/itm/312526713209
rob   :-)
IanT
Posted: 10:57am 11 Feb 2021
I haven't been able to find that version of the Black Pill Peter. Can you provide a pointer please?
Rgards,
IanT
Posted: 11:15am 11 Feb 2021
  Quote  I haven't been able to find that version of the Black Pill Peter. Can you provide a pointer please?
here but you can find much cheaper elsewhere
But I do not recommend it. The target board is better in every respect
Posted: 11:31am 11 Feb 2021
Not sure about the name of the board. If you google at STM32 black pill the things that show up are boards that have the shape of the "blue pill"
They typically have STM32F401/F411 chips on them.
That is why you might have been confused.
here
here
here
Posted: 11:39am 11 Feb 2021
  Quote  To me, a much better fit would be the 480x320 SPI ILI9488, which would give an 80x40ish edit screen with font 7. Of course, it would also require a backpack to bring out the interface pins.  I would propose to design one which would also include a PS/2 keyboard connector, socket for RTC & ESP-01, mini-stereo socket, IR capability, and a 20x2 pi-type connector like that on the CMM2. The 3.5" ILI9488 can be had for $10US including shipping. There is apparently a 'loadable' driver for this LCDI think for the MM+ (and perhaps MMX). This would make a very capable "MMBasic computer").
If you design a backpack I'll commit to getting the ILI9488 working. Be aware though that the display is slow: 480x320 16-bit is a lot of data over SPI
Better would be something like this
IanT
Posted: 11:51am 11 Feb 2021
OK, thanks Peter - noted.
IanT
Posted: 03:13pm 11 Feb 2021
  matherp said
  lizby said  To me, a much better fit would be the 480x320 SPI ILI9488, which would give an 80x40ish edit screen with font 7. . . . This would make a very capable "MMBasic computer").
Excellent. I've ordered one of the "3.5" inch 480x320 TFT LCD Touch Screen Display Board For Arduino UNO R3 Mega2560" LCDs from here
Is the connection from the F4 LDC header straightforward?
disco4now
Posted: 11:40pm 11 Feb 2021
I have two  candidates for higher resolution 16bit parallel screens. They both have the XPT2046 touch. I don't think the one you link to has touch.
One is 3.5"  320*480  ILI9486  (I have not tried it yet)
Other is 3.97" 800*480 OTM8009A/NT35510 IPS Display  (I have this working)
They are 34 pin connectors , so you need a 32pin to 34 pin adaptor with wiring lined up correctly.
The 800*480 has a transistor driver on the BL pin so can be driven from the BACKLIGHT command. I think the 320*480 is the same.
320*480
800*480
I only have the OTM8009A 800*480 version which now seems to come with a later NT35510 driver chip which I have not tried.
The 800*600 OTM8009A I have working on the ARMMite F4 with touch.
I checked OPTION LCDPANEL CONSOLE and seems to work.
Although small in size for 800*480 is very crisp as its IPS.
I compiled it into the recently released ArmmiteF4 source, it added about 3K.
I was intending to ask Peter to consider adding to the code, but wanted to verify with the later NT35510 chip first.
There is probably not much room for too many displays so just want to put my bid in for the 800*480 to be included.
Gerry
Edited 2021-02-12 10:19 by disco4now
F4 H7FotSF4xGT
morgs67
Posted: 12:48am 12 Feb 2021
  disco4now said  I have two  candidates for higher resolution 16bit parallel screens. They both have the XPT2046 touch. I don't think the one you link to has touch.
Gerry
+1
Following with interest as I have several F4s and a larger screen at a reasonable price would be great.
Tony
Posted: 01:44am 12 Feb 2021
  disco4now said  I have two  candidates for higher resolution 16bit parallel screens. They both have the XPT2046 touch. . . .
Those look quite nice. The 3.5" one has the ILI9486 controller. The 32 pin to 34 pin adaptor would be similar to the 32 pin to 40 pin which Peter made previously for the larger (and more expensive) 16-bit displays for the F4.
To me, 480x320 is adequate for running the editor with OPTION LCDPANEL CONSOLE--but if only one could be implemented, the 800x480 would be better, I guess--especially if you already have a driver working.
Can you post a picture of the editor on the 800x480 screen in CONSOLE mode?
     Page 1 of 3
