Forum Index : Microcontroller and PC projects : Retro computing - sliderule
This is 'real' retro. ![]() You can move the slide using the left and right arrows or the cursor using up and down. In both cases, 'shift' moves fast and 'ctrl' move real slow. If you have a mouse, simply drag the slide or cursor. You will have to edit line 10 to suit your mouse port (or zero if no mouse) I need to experiment with the various blit/sprite methods to see if I can reduce the flicker. 'TassyJim December 2020 ' 'simple Mannheim type slide rule ' translated for a post on the LIberty Basic forum by tsh73 'If you need instructions on operating slide rule, you can check 'https://www.sliderulemuseum.com/ ' OPTION EXPLICIT OPTION DEFAULT FLOAT CONST mouseport = 2 ' use 0 for no mouse else 1-3 for the corresponding port DIM WW = MM.HRES DIM x0=1 DIM x1=10 DIM n = 1000 DIM h0 = (x1)/n DIM firstXX=30 DIM SCALE = (WW - 2*firstXX)/LOG(x1) 'vertical scale positions in pixels CONST Tedge = 30 CONST Lline = Tedge + 35 CONST Kline = Lline + 35 CONST ABline = Kline + 35 CONST CDline = ABline+ 70 CONST Sline = CDline+ 70 CONST Tline = Sline + 35 CONST Ledge = Tline + 10 DIM x,i,h,d,xx, lastxx, dd, quit, kp,sp, nudge DIM oldFirstXX, k, slidepos, oldpos, cursorpos, oldcursorpos DIM mx, my, ms, mc, mlb, oldmx, oldlmb CONST bg1 = RGB(255,255,128) CONST bg2 = RGB(WHITE) CONST gra = RGB(32,32,32) MODE 1,8,RGB(BLACK),moveslide CLS PAGE WRITE 1 CLS IF mouseport > 0 THEN CONTROLLER MOUSE OPEN mouseport GUI CURSOR ON 1,MM.HRES/2,MM.VRES/2,RGB(RED) ENDIF BOX 10,Tedge+5,WW-10,Kline-Tedge,1,bg1,bg1 BOX 10,Kline+5,WW-10,Sline-Kline,1,bg2,bg2 BOX 10,Sline-30,WW-10,Ledge-Sline+35,1,bg1,bg1 '=============== Draw scales ================ 'C, D scales (main) ------------------------------------- x = x0 i = 0 DO WHILE i<=900 SELECT CASE x CASE IS <2 h = 1 CASE IS <4 h = 2 CASE ELSE h = 5 END SELECT xx = firstXX+LOG(x)*SCALE d=7 IF i MOD 5 = 0 THEN d=d+2 IF i MOD 10 = 0 THEN d=d+3 IF i MOD 100 = 0 THEN d=d+4 LINE xx,CDline,xx,CDline-d,1,gra LINE xx,CDline+2,xx,CDline+2+d,1,gra IF i MOD 100 = 0 THEN TEXT xx-3,CDline-27,LEFT$(STR$(x),1),,7,1,gra,bg2 TEXT xx-3,CDline+27,LEFT$(STR$(x),1),,7,1,gra,bg2 ELSE IF i MOD 10 = 0 AND x<2 THEN TEXT xx-7,CDline-24,"1."+RIGHT$(STR$(x-1),1),,7,1,gra,bg2 TEXT xx-7,CDline+24,"1."+RIGHT$(STR$(x-1),1),,7,1,gra,bg2 END IF END IF i = i+h x = x+h*h0 LOOP lastXX=xx 'Pi mark on C,D scales ------------------------------------- xx = firstXX+LOG(ACOS(-1))*SCALE d=5 dd=12 TEXT xx-3,CDline-28,"pi",,7,1,gra,bg2 TEXT xx-3,CDline+28,"pi",,7,1,gra,bg2 LINE xx,CDline-dd,xx,CDline-dd-d,1,gra LINE xx,CDline+2+dd,xx,CDline+2+dd+d,1,gra ' 'L scale ------------------------------------- n=200 h=(lastXX-firstXX)/n FOR i = 0 TO n x=i/200 xx=firstXX+i*h d=7 IF i MOD 2 = 0 THEN d=d+2 IF i MOD 10 = 0 THEN d=d+6 IF i MOD 20 = 0 THEN d=d+4 LINE xx,Lline,xx,Lline-d,1,gra IF i MOD 20 = 0 THEN TEXT xx-8,Lline-24,STR$(x,1,1),,7,1,gra,bg1 '+4*(i=200) '#gr "\";right$(using("#.#",x), 3 + (i=200)) END IF NEXT i ' 'A, B scales (square) ------------------------------------- oldFirstXX=firstXX FOR k=1 TO 2 x = x0 i = 0 DO WHILE i<=900 SELECT CASE x CASE IS <2 h = 2 CASE IS <5 h = 5 CASE ELSE h = 10 END SELECT xx = firstXX+LOG(x)/2*SCALE d=7 IF i = 50 THEN d=d+3 IF i MOD 10 = 0 THEN d=d+2 IF i MOD 100 = 0 THEN d=d+5 LINE xx,ABline,xx,ABline-d,1,gra LINE xx,ABline+2,xx,ABline+2+d,1,gra IF i MOD 100 = 0 THEN TEXT xx-3,ABline-27,LEFT$(STR$(x),1),,7,1,gra,bg2 TEXT xx-3,ABline+27,LEFT$(STR$(x),1),,7,1,gra,bg2 END IF i = i+h x = x+h*h0 LOOP firstXX = xx NEXT k ' 'K scale (cube) ------------------------------------- firstXX= oldFirstXX FOR k=1 TO 3 x = x0 i = 0 DO WHILE i<=900 SELECT CASE x CASE IS <3 h = 5 CASE IS <6 h = 10 CASE ELSE h = 20 END SELECT xx = firstXX+LOG(x)/3*SCALE d=7 IF i MOD 10 = 0 THEN d=d+2 IF i MOD 50 =0 THEN d=d+3 IF i MOD 100 = 0 THEN d=d+5 LINE xx,Kline,xx,Kline-d,1,gra IF i MOD 100 = 0 THEN TEXT xx-3,Kline-27,LEFT$(STR$(x),1),,7,1,gra,bg1 END IF i = i+h x = x+h*h0 LOOP firstXX = xx NEXT ' ' S scale (sine) ' todo ' ' T scale (tangent) ' todo ' 'labels ------------------------------------- TEXT 15,Kline-10,"K",,7,1,gra,bg1 TEXT 15,ABline-12,"A",,7,1,gra,bg2 TEXT 15,ABline+5,"B",,7,1,gra,bg2 TEXT 15,Lline-10,"L",,7,1,gra,bg1 TEXT 15,CDline-12,"C",,7,1,gra,bg2 TEXT 15,CDline+5,"D",,7,1,gra,bg2 TEXT 15,Sline-10,"S",,7,1,gra,bg1 TEXT 15,Tline-10,"T",,7,1,gra,bg1 BLIT READ 1,10,Tedge,MM.HRES,ABline-Tedge,1 BLIT READ 2,10,CDline,MM.HRES,Ledge-CDline,1 SPRITE READ 3,10,ABline+1,MM.HRES,CDline-ABline,1 ' make cursor as sprite CLS BOX 10,Tedge-5,50,12,1,RGB(CYAN),RGB(CYAN) BOX 10,Ledge-2,50,12,1,RGB(CYAN),RGB(CYAN) LINE 35,Tedge-10,35,Ledge+10,1,gra SPRITE READ 4,10,Tedge-5,50,Ledge-Tedge+15,1 PAGE WRITE 0 BLIT WRITE 1,10,Tedge BLIT WRITE 2,10,CDline SPRITE SHOW 3, slidepos, ABline,0 SPRITE SHOW 4,cursorpos,Tedge-5,0 TEXT MM.HRES/2,Ledge+20,"Left and right to shift slide",CM TEXT MM.HRES/2,Ledge+35,"Up and Down to shift cursor",CM TEXT MM.HRES/2,Ledge+50,"Shift for rapid, ctrl for slow",CM TEXT MM.HRES/2,Ledge+65,"Or drag with a mouse",CM TEXT MM.HRES/2,Ledge+85,"Q to quit",CM DO IF KEYDOWN(0) > 0 THEN kp = KEYDOWN(1) sp = KEYDOWN(7)' either shift key IF sp = 2 OR sp = 32 THEN nudge = 1 ELSE nudge = 0 ' single step or continuous IF sp = 8 OR sp = 128 THEN sp = 10 ELSE sp = 1 ' shift key for rapid movement SELECT CASE kp CASE 128 cursorpos = MIN(cursorpos + sp,WW-1) CASE 129, 161 cursorpos = MAX(cursorpos - sp,1-WW) CASE 131, 163 slidepos = MIN(slidepos + sp,WW-1) CASE 130 slidepos = MAX(slidepos - sp,1-WW) CASE 113 quit = 1 END SELECT IF nudge THEN DO : LOOP UNTIL KEYDOWN(0) = 0 ' single step with 'ctrl' key ELSE PAUSE 50 ENDIF ENDIF IF mouseport THEN ' we have a mouse mx = MOUSE(x,mouseport) my = MOUSE(y,mouseport) GUI CURSOR mx,my IF MOUSE(L,2) = 1 THEN IF oldlmb = 0 THEN ' left button just pressed. oldmx = mx oldlmb = 1 ENDIF ELSE oldlmb = 0 ENDIF ' move the slide with the mouse IF oldlmb = 1 AND my > ABline AND my < CDline THEN slidepos = MIN(slidepos + mx-oldmx,MM.HRES-3) slidepos = MAX(slidepos,1-MM.HRES) oldmx=mx ENDIF ' move the cursor with the mouse IF oldlmb = 1 AND (ABS(my -Tedge)<10 OR ABS(my -Ledge)<10) THEN cursorpos = MIN(cursorpos + mx-oldmx,MM.HRES-3) cursorpos = MAX(cursorpos,1-MM.HRES) oldmx=mx ENDIF ENDIF LOOP UNTIL quit = 1 ' tidy up things MODE 1,8 CLS IF mouseport THEN CONTROLLER MOUSE CLOSE mouseport GUI CURSOR OFF ENDIF END SUB moveslide IF slidepos <> oldpos OR cursorpos <> oldcursorpos THEN SPRITE HIDE 4 IF slidepos <> oldpos THEN SPRITE SHOW 3, slidepos, ABline, 0 SPRITE SHOW 4, cursorpos,Tedge-5,0 oldpos = slidepos oldcursorpos = cursorpos ENDIF END SUB You should be able to use any of the high resolution modes. Jim VK7JH MMedit |
brilliant! |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1784 |
I like it! |
That's one program I have no desire to play with. I threw out my old sliderules when I moved house along with my copy of Logarithmic and Other Tables. Bill Keep safe. Live long and prosper. |
Heathen they are beautiful things |
I know, I know. But when I tell the grand kids about sliderules and telephones with dials you had to stick your finger in and turn to dial the number, inkwells and pens with nibs that we used to make darts out of and throw into the ceiling of the classroom their eyes glaze over and they ask me about the dinosaurs I saw. Bill Keep safe. Live long and prosper. |
Back in the early '70's when I was at Tech, got one lot of exam results back which included: .... Sliderule F I didn't even know we had an exam on it. Not impressed. Mine looked similar to matherp's (Faber-Castell) (cheaper than a HP-35 for $500.00 at the time though) ChopperP |
| SimpleSafeName Guru Joined: 28/07/2019 Location: United StatesPosts: 351 |
Indeed! Oh, the humanity! I still have mine from the seventies. |
| NPHighview Senior Member Joined: 02/09/2020 Location: United StatesPosts: 222 |
Still have mine (actually, my wife's) in the display cabinet right next to my HP-35, my HP-15c, my HP-42, and our SwissMicro DM41x, the latter of which gets the most use. They're all on the shelf right above the fossils :-) Live in the Future. It's Just Starting Now! |
| romba6 Newbie Joined: 04/07/2020 Location: United KingdomPosts: 39 |
Great work Jim - I will have a play later !! I still have my slide rule from college days (60s) so a bit old now, but more importantly I can still remember how to use it !!! It beats my abacus any day - or is that next on your list .... ? |
My slide rule is one of those new fancy plastic ones. My brothers and father weren't impressed. I think (hope) I have my father's bamboo(?) one in the store room somewhere. To the younger generations, I point out that it hasn't had a flat battery yet. Jim VK7JH MMedit |
My HP15C LE is right here, on top of my HP16C. They still get used. I've got several others as well (HPs, TIs, a couple of Casios, and a Russian job), but these are my favorites. |
| GerryL Regular Member Joined: 24/01/2019 Location: AustraliaPosts: 46 |
this is great Jim, below is pix of my 20+ slide rules that I rediscovered hiding in my shed that I had all but forgotten about. In the background is the culprit that started their demise, a Friden 130 calculator. The 130 was the first solid state desk top calculator that was released in mid 1960's and takes pride of place in my electronic calculator collection. It used discrete components and an acoustic delay line for the memory plus a CRT for the display, amazing for its time. Gerry |
For those who insist on a printed manual: ![]() No date unfortunately but the price was 2 shillings and 6 pence. Update to my code with all the flickering gone. I now print to page 1 for everything and do a PAGE COPY 1 TO 0 ,B I changed a few sequences and now very happy with the results. 'TassyJim December 2020 ' 'simple Mannheim type slide rule ' translated for a post on the LIberty Basic forum by tsh73 'If you need instructions on operating slide rule, you can check 'https://www.sliderulemuseum.com/ ' OPTION EXPLICIT OPTION DEFAULT FLOAT CONST mouseport = 2 ' use 0 for no mouse else 1-3 for the corresponding port DIM WW = MM.HRES DIM x0=1 DIM x1=10 DIM n = 1000 DIM h0 = (x1)/n DIM firstXX=30 DIM SCALE = (WW - 2*firstXX)/LOG(x1) 'vertical scale positions in pixels CONST Tedge = 30 CONST Lline = Tedge + 35 CONST Kline = Lline + 35 CONST ABline = Kline + 35 CONST CDline = ABline+ 70 CONST Sline = CDline+ 70 CONST Tline = Sline + 35 CONST Ledge = Tline + 10 DIM x,i,h,d,xx, lastxx, dd, quit, kp,sp, nudge DIM oldFirstXX, k, slidepos, oldpos, cursorpos, oldcursorpos DIM mx, my, ms, mc, mlb, oldmx, oldlmb CONST bg1 = RGB(255,255,128) CONST bg2 = RGB(WHITE) CONST gra = RGB(32,32,32) MODE 1,8,RGB(BLACK) CLS PAGE WRITE 2 CLS IF mouseport > 0 THEN CONTROLLER MOUSE OPEN mouseport GUI CURSOR ON 1,MM.HRES/2,MM.VRES/2,RGB(RED) ENDIF BOX 10,Tedge+5,WW-10,Kline-Tedge,1,bg1,bg1 BOX 10,Kline+5,WW-10,Sline-Kline,1,bg2,bg2 BOX 10,Sline-30,WW-10,Ledge-Sline+35,1,bg1,bg1 '=============== Draw scales ================ 'C, D scales (main) ------------------------------------- x = x0 i = 0 DO WHILE i<=900 SELECT CASE x CASE IS <2 h = 1 CASE IS <4 h = 2 CASE ELSE h = 5 END SELECT xx = firstXX+LOG(x)*SCALE d=7 IF i MOD 5 = 0 THEN d=d+2 IF i MOD 10 = 0 THEN d=d+3 IF i MOD 100 = 0 THEN d=d+4 LINE xx,CDline,xx,CDline-d,1,gra LINE xx,CDline+2,xx,CDline+2+d,1,gra IF i MOD 100 = 0 THEN TEXT xx-3,CDline-27,LEFT$(STR$(x),1),,7,1,gra,bg2 TEXT xx-3,CDline+27,LEFT$(STR$(x),1),,7,1,gra,bg2 ELSE IF i MOD 10 = 0 AND x<2 THEN TEXT xx-7,CDline-24,"1."+RIGHT$(STR$(x-1),1),,7,1,gra,bg2 TEXT xx-7,CDline+24,"1."+RIGHT$(STR$(x-1),1),,7,1,gra,bg2 END IF END IF i = i+h x = x+h*h0 LOOP lastXX=xx 'Pi mark on C,D scales ------------------------------------- xx = firstXX+LOG(ACOS(-1))*SCALE d=5 dd=12 TEXT xx-3,CDline-28,"pi",,7,1,gra,bg2 TEXT xx-3,CDline+28,"pi",,7,1,gra,bg2 LINE xx,CDline-dd,xx,CDline-dd-d,1,gra LINE xx,CDline+2+dd,xx,CDline+2+dd+d,1,gra ' 'L scale ------------------------------------- n=200 h=(lastXX-firstXX)/n FOR i = 0 TO n x=i/200 xx=firstXX+i*h d=7 IF i MOD 2 = 0 THEN d=d+2 IF i MOD 10 = 0 THEN d=d+6 IF i MOD 20 = 0 THEN d=d+4 LINE xx,Lline,xx,Lline-d,1,gra IF i MOD 20 = 0 THEN TEXT xx-8,Lline-24,STR$(x,1,1),,7,1,gra,bg1 '+4*(i=200) '#gr "\";right$(using("#.#",x), 3 + (i=200)) END IF NEXT i ' 'A, B scales (square) ------------------------------------- oldFirstXX=firstXX FOR k=1 TO 2 x = x0 i = 0 DO WHILE i<=900 SELECT CASE x CASE IS <2 h = 2 CASE IS <5 h = 5 CASE ELSE h = 10 END SELECT xx = firstXX+LOG(x)/2*SCALE d=7 IF i = 50 THEN d=d+3 IF i MOD 10 = 0 THEN d=d+2 IF i MOD 100 = 0 THEN d=d+5 LINE xx,ABline,xx,ABline-d,1,gra LINE xx,ABline+2,xx,ABline+2+d,1,gra IF i MOD 100 = 0 THEN TEXT xx-3,ABline-27,LEFT$(STR$(x),1),,7,1,gra,bg2 TEXT xx-3,ABline+27,LEFT$(STR$(x),1),,7,1,gra,bg2 END IF i = i+h x = x+h*h0 LOOP firstXX = xx NEXT k ' 'K scale (cube) ------------------------------------- firstXX= oldFirstXX FOR k=1 TO 3 x = x0 i = 0 DO WHILE i<=900 SELECT CASE x CASE IS <3 h = 5 CASE IS <6 h = 10 CASE ELSE h = 20 END SELECT xx = firstXX+LOG(x)/3*SCALE d=7 IF i MOD 10 = 0 THEN d=d+2 IF i MOD 50 =0 THEN d=d+3 IF i MOD 100 = 0 THEN d=d+5 LINE xx,Kline,xx,Kline-d,1,gra IF i MOD 100 = 0 THEN TEXT xx-3,Kline-27,LEFT$(STR$(x),1),,7,1,gra,bg1 END IF i = i+h x = x+h*h0 LOOP firstXX = xx NEXT ' ' S scale (sine) ' todo ' ' T scale (tangent) ' todo ' 'labels ------------------------------------- TEXT 15,Kline-10,"K",,7,1,gra,bg1 TEXT 15,ABline-12,"A",,7,1,gra,bg2 TEXT 15,ABline+5,"B",,7,1,gra,bg2 TEXT 15,Lline-10,"L",,7,1,gra,bg1 TEXT 15,CDline-12,"C",,7,1,gra,bg2 TEXT 15,CDline+5,"D",,7,1,gra,bg2 TEXT 15,Sline-10,"S",,7,1,gra,bg1 TEXT 15,Tline-10,"T",,7,1,gra,bg1 BLIT READ 1,10,Tedge,MM.HRES,ABline-Tedge,2 BLIT READ 2,10,CDline,MM.HRES,Ledge-CDline,2 SPRITE READ 3,10,ABline+1,MM.HRES,CDline-ABline,2 ' make cursor as sprite CLS BOX 10,Tedge-5,50,12,1,RGB(CYAN),RGB(CYAN) BOX 10,Ledge-2,50,12,1,RGB(CYAN),RGB(CYAN) LINE 35,Tedge-10,35,Ledge+10,1,gra SPRITE READ 4,10,Tedge-5,50,Ledge-Tedge+15,2 PAGE WRITE 1 BLIT WRITE 1,10,Tedge BLIT WRITE 2,10,CDline SPRITE SHOW 3, slidepos, ABline,0 SPRITE SHOW 4,cursorpos,Tedge-5,0 TEXT MM.HRES/2,Ledge+20,"Left and right to shift slide",CM TEXT MM.HRES/2,Ledge+35,"Up and Down to shift cursor",CM TEXT MM.HRES/2,Ledge+50,"Shift for rapid, ctrl for slow",CM TEXT MM.HRES/2,Ledge+65,"Or drag with a mouse",CM TEXT MM.HRES/2,Ledge+85,"Q to quit",CM PAGE COPY 1 TO 0 ,b DO IF KEYDOWN(0) > 0 THEN kp = KEYDOWN(1) sp = KEYDOWN(7)' either shift key IF sp = 2 OR sp = 32 THEN nudge = 1 ELSE nudge = 0 ' single step or continuous IF sp = 8 OR sp = 128 THEN sp = 10 ELSE sp = 1 ' shift key for rapid movement SELECT CASE kp CASE 128 cursorpos = MIN(cursorpos + sp,WW-3) CASE 129, 161 cursorpos = MAX(cursorpos - sp,1-WW) CASE 131, 163 slidepos = MIN(slidepos + sp,WW-3) CASE 130 slidepos = MAX(slidepos - sp,1-WW) CASE 113 quit = 1 END SELECT IF nudge THEN DO : LOOP UNTIL KEYDOWN(0) = 0 ' single step with 'ctrl' key ENDIF ENDIF IF mouseport THEN ' we have a mouse mx = MOUSE(x,mouseport) my = MOUSE(y,mouseport) GUI CURSOR mx,my IF MOUSE(L,2) = 1 THEN IF oldlmb = 0 THEN ' left button just pressed. oldmx = mx oldlmb = 1 ENDIF ELSE oldlmb = 0 ENDIF ' move the slide with the mouse IF oldlmb = 1 AND my > ABline AND my < CDline THEN slidepos = MIN(slidepos + mx-oldmx,WW-3) slidepos = MAX(slidepos,1-WW) oldmx=mx ENDIF ' move the cursor with the mouse IF oldlmb = 1 AND (ABS(my -Tedge)<10 OR ABS(my -Ledge)<10) THEN cursorpos = MIN(cursorpos + mx-oldmx,WW-3) cursorpos = MAX(cursorpos,1-WW) oldmx=mx ENDIF ENDIF PAUSE 10 moveslide LOOP UNTIL quit = 1 ' tidy up things CLS PAGE WRITE 0 MODE 1,8 CLS IF mouseport THEN CONTROLLER MOUSE CLOSE mouseport GUI CURSOR OFF ENDIF END SUB moveslide IF slidepos <> oldpos OR cursorpos <> oldcursorpos THEN SPRITE HIDE 4 IF slidepos <> oldpos THEN SPRITE SHOW 3, slidepos, ABline, 0 SPRITE SHOW 4, cursorpos,Tedge-5,0 oldpos = slidepos oldcursorpos = cursorpos PAGE COPY 1 TO 0 ,b ENDIF END SUB Enjoy... Jim VK7JH MMedit |
Boy oh boy that bring back memories of my time at Technological Engineering when Mr. Laker Gave me one of these for my 16th birthday. I still have it and later TI handed out calculators to us. But the Rule Ruled LOL side note may be do one with the MM170 and 3.5" or 4" TFT LCD just to have on my desk. Edited 2020-12-07 19:14 by Quazee137 |
| William Leue Guru Joined: 03/07/2020 Location: United StatesPosts: 411 |
Very nice! I still have my old slide rule from undergrad engineering days. -Bill |
I'm older than dirt. I've got seven of these things. One of them is three feet long! Most of them are basswood Keuffel & Essers or aluminum Picketts. If you're designing a switchable voltage divider to control the gain of an op amp you set the slide once and read off all the proportional resistor values without any further fooling around. They were very efficient for many tasks. Paul in NY |
Ah ! When he big EMP kills all your binary bits, and batteries are no longer available. You can sit around the camp fire in front of your cave, and do things not possible by just counting on your fingers. Cheers, Tony. |
I threw mine away when I got my first TI57. Now I regret it. The TI57 stopped working after something got defective inside the battery box (there is a convertor in it). Followed up by a "cheap" Casio FX82 with broken ON/OFF switch that I bypassed relying on it's build in low power standby mode. It is still working on it's second set of AA batteries ! .... real low power.. This calculator is really amazing quality. Even the keys all work flawless without a cleaning or anything after almost 45 years. On the second set of AA's. And I gathered on a flea market a HP12c (a broken one for $0.25 that I cleaned and repaired) that I use daily. But it has no geometry (sin/cos/tan). It is a financial calculator. Still looking for a HP10c, 11c, or 15c on flea markets... But prices are outrageous now, especially when not defective. Volhout Edited 2020-12-08 21:47 by Volhout PicomiteVGA PETSCII ROBOTS |
| RetroJoe Senior Member Joined: 06/08/2020 Location: CanadaPosts: 290 |
Ah, the TI-57! The TI-57 was my first calculator, too, and one of the very first electronic devices I learned how to program (a TRS-80 Model 1 was the other). It was quite a powerful little machine, and had all the basics (!) to learn procedural programming: 50 program steps with labels, 8 registers for intermediate results, conditional branching, and an all-purpose GOTO for loops and subs. And, I do remember the proprietary (and anemic...) battery pack. A real pain in the a$$, because you could never be sure if it would last you through an entire school day (“battery anxiety” was a thing even in the 1970s !). The TI-57 had a big brother, the TI-59, which included a magnetic card reader. It was frightfully expensive so I couldn’t afford it, but I had a friend with one - it was very cool :). Check out the video - the idea was you would save custom functions on the mag strip, then write their names on the strip with a Sharpie so you could invoke them with assignable function keys. Also note the long delay between the key press and the result appearing on the display. The TI-57 and TI-59 just blanked the display during lengthy calculations, but the designers of the entry-level TI-30 went to the trouble of putting a “working...” animation on the display, which was the last digit of the display doing a circular chase around the 7-segment LED. For all I know, it may have been the first appearance of the ubiquitous “spinning widget” you see on all contemporary computers. Edited 2020-12-09 00:45 by RetroJoe Enjoy Every Sandwich / Joe P. |
