Local Time 14:26 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: V5.05.06RC19: Scotty more power
     Page 1 of 4
Posted: 04:21pm 14 Nov 2020
V5.05.06RC19
This version has two small changes that have made an amazing difference. Thanks to the guys playing with the tetrahedron challenge we found out that processing a hex number was much faster than a decimal number - wtf . Investigating this revealed the problem and has resulted in a much bigger gain than was expected because it related not only to simple assignments e.g. a=123 but also things like a(1)=b and PIN(5)=1. Basically anytime a scalar value appeared in the program.
The second change is to add yet another command which again can yield a huge benefit
Consider the line a=a+1: In this simple example the interpreter has to search for "a" twice, search for the LET command, and then the + operator.
To overcome this I've added the INC command
INC var [,increment]
If the optional increment is missed var is incremented by 1. If the increment is specified (and it can be another variable of course) then var is updated by the value of the increment. This command is available for integers and floats and any mix thereof.
In addition it can be used for strings in which case the "increment" is mandatory and is appended to the first string
INC string1$, string2$
is the same as "string1$ = string1$ + string2$"
The difference the INC command makes can be extraordinary if used in a tight loop which may often be the case.
The simple speed lines-per-second test code is:
Dim integer i, cnt
SETPIN 3,2 : SETPIN 5, 8
lines = 5
loops = 1000000
TIMER = 0
' start of the timed section (5 lines)
for i=1 to loops
inp = PIN(3)
PIN(5) = inp
cnt = cnt + 1
'inc cnt
next
PRINT "Speed is"; INT((cnt * lines)/(TIMER /1000)); " lines per second."
The results in successive releases have been as follows:
V5.05.05       325826
V5.05.06RC13   358830
V5.05.06RC19   437480 'using cnt=cnt+1
V5.05.06RC19   540578 'using inc cnt
Other benchmarks relative to V5.05.05 are as follows:
Test           V5.05.05   V5.05.06RC19    Measure
Grainbench      15968      17916       Arbitrary simple benchmark
zmim            1210       1866        Instructions per second
Solar Eclipse   14.08      7.49        Time to complete complex calculation
Speedtest       325826     540578      MMBasic Lines/second
Benchmark       0.328      0.170       Simple benchmark with GOSUB and GOTO
Wolf3D          14         21          Framerate per second
Darkness        13         23          Framerate per second
Bucky Ball      68         46.9        Time to calc and display new position (mSec)
NB to thwill: Tom, I've modified zmim to use the INC command in lots of places to get the above result
This version has been tested on every single program in the Welcome pack, Gauntlet, Wolf3D, FFight and many of my small test programs and so far is looking good.
Pilot352
Posted: 04:47pm 14 Nov 2020
Great idea. But what about a DEC command??
You know how we are... We always need more power!
Edited 2020-11-15 02:48 by Pilot352
Posted: 05:00pm 14 Nov 2020
  Quote  But what about a DEC command??
What about using a negative increment
CircuitGizmos
  Pilot352 said  Great idea. But what about a DEC command??
INC var, -1
Edit: Simultaneous posting.
Edited 2020-11-15 03:00 by CircuitGizmos
CircuitGizmos
Posted: 05:02pm 14 Nov 2020
I expect you'll hear others ask:
"Can I have var++ ?"
Edited 2020-11-15 03:03 by CircuitGizmos
twofingers
Posted: 05:05pm 14 Nov 2020
  Pilot352 said  Great idea. But what about a DEC command?? ...
Hi,
how about to use INC var, -1? The slots for commands are limited.
Michael
EDIT: I'm too slow!
Edited 2020-11-15 03:11 by twofingers
LeoNicolas
Posted: 05:14pm 14 Nov 2020
Again matherp, thank you for the improvements.
I'll adapt the octahedron to the RC19. My current version is using hex numbers in all places. I'll compare the same source code using decimal x hex and post here the results.
William Leue
Posted: 05:27pm 14 Nov 2020
Good deal! I can't keep up with the blizzard of release candidates, but that is a Good Thing.
-Bill
CircuitGizmos
Posted: 05:37pm 14 Nov 2020
  William Leue said  Good deal! I can't keep up with the blizzard of release candidates, but that is a Good Thing.
-Bill
INC when it is also DEC and CAT will be confusing. I can't think of any token word that would be less confusing, however.
Hopefully, it will be described clearly in the manual.
Posted: 05:50pm 14 Nov 2020
  matherp said  NB to thwill: Tom, I've modified zmim to use the INC command in lots of places to get the above result
More impressive work Peter and another thing to go on my TODO list. You do realise we're going to have to seriously consider sedating you so the rest of us can catch up.
  matherp said  This version has been tested on every single program in the Welcome pack ...
At least it is good for something
Exhausted from just keeping up with the Release Candidates,
Posted: 05:58pm 14 Nov 2020
  CircuitGizmos said  INC when it is also DEC and CAT will be confusing. I can't think of any token word that would be less confusing, however.
Subject to Peter's will I believe he could use the CMM2's pre-process step to allow CAT, CONCAT, APPEND or something to be a synonym for INC without consuming a command slot (and pulling this trick elsewhere is how I understand he has magically manage to shoehorn in the recent additional commands).
With sufficient will DEC could presumably be handled that way too, but he'd also need to negate the argument whilst handling the case that it could be a complex expression.
PeteCotton
Posted: 06:21pm 14 Nov 2020
Once again THANK YOU! That is an incredible speed boost.
LeoNicolas
Posted: 06:39pm 14 Nov 2020
My octahedron code was running in 1004ms using the RC18 with all numbers coded as hexadecimal and variables as float (because in the previous version float variables were fastest than integer). After upgrading to the RC19 these were the results:
1) Without changing the code: no time difference
2) Using decimal instead of hexadecimal (with all variables as float): 1045 ms
3) Using decimal but changing some variables to integer: 978ms
I run the following test:
option explicit
option default float
dim rf,l,vf=1.0
dim integer vi=1,ri
print "starting test"
timer=0
for l=1 to 1000000
 rf=vi
next l
print "float <= vint : "+str$(timer)
timer=0
for l=1 to 1000000
 ri=vi
next l
print "int   <= vint : "+str$(timer)
timer=0
for l=1 to 1000000
 rf=vf
next l
print "float <= vflt : "+str$(timer)
timer=0
for l=1 to 1000000
 ri=vf
next l
print "int   <= vflt : "+str$(timer)
timer=0
for l=1 to 1000000
 rf=1
next l
print "float <= int  : "+str$(timer)
timer=0
for l=1 to 1000000
 ri=1
next l
print "int   <= int  : "+str$(timer)
timer=0
for l=1 to 1000000
 rf=1.0
next l
print "float <= float: "+str$(timer)
timer=0
for l=1 to 1000000
 ri=1.0
next l
print "int   <= float: "+str$(timer)
timer=0
for l=1 to 1000000
 rf=&H1
next l
print "float <= hex  : "+str$(timer)
timer=0
for l=1 to 1000000
 ri=&H1
next l
print "int   <= hex  : "+str$(timer)
These are the results:
My conclusion is setting hex to float variables still a little fastest than decimal to float variables, but for decimal to integer variables the improvement is huge.
RetroJoe
Posted: 06:40pm 14 Nov 2020
  CircuitGizmos said   I can't think of any token word that would be less confusing
“Incrementing” by a negative value feels a little quirky, but not much more so than a STEP -1 construct in a FOR loop. The cognitive difference is people understand that “steps” can go up or down, but that “increment” typically only means “up”.
Three possible syntax alternatives to INC:
1) ACC (a, -1) would be more orthogonal and semantically accurate than INC. Yes, “accumulate” also generally means to “increase”, but a computer accumulator register, or a variable used as such, is expected to accumulate both positive and negative values
2) ASSIGN (a,-1). Same idea as above, with an implied addition operation.
3) Adopt the “a += -1” shorthand from C and Python. This would be the cleanest and most elegant approach, IMHO, assuming MMBasic can pre-process the += “add and assign” operator for acceleration. It’s not standard BASIC... but neither is “INC”.
Cheers,
Enjoy Every Sandwich / Joe P.
elk1984
Posted: 06:47pm 14 Nov 2020
  matherp said  This version has two small changes
Please, please, please release it!  There's so many toys but I'm too frit to install betas and RCs
We all know there's a 5.05.07 coming sometime.  For my interest, what merits major, minor, revision in the versioning.  I'd have thought the wholescale upgrade of varaible lookup and the performance that brings must be worth a "minor" increment?
Edited 2020-11-15 04:49 by elk1984
markboston36
Posted: 09:07pm 14 Nov 2020
..............numbers make my eyes bleed. ill take your word its faster.
Turbo46
Posted: 09:15pm 14 Nov 2020
Please, please, please release it! Plus one.
I'd love to have an up-to-date printed manual.
For info this INC or += suggestion came up for MMBasic before and was rejected. I'm glad it finally made it.
I'd love to know which (if any) of these improvements Peter has made will make it to MMBasic for the Original Maximites and the Micromites.
Thank you Peter and Geoff.
Posted: 10:39am 15 Nov 2020
Hi Peter,
I'm having issues with RC19, here is an "easy" one for starters that I ran across whilst trying to reproduce the "real" problem:
Colour Maximite 2
MMBasic Version 5.05.06RC19
Copyright 2011-2020 Geoff Graham
Copyright 2016-2020 Peter Mather
> list "bug.bas"
#Include "bug2.inc"
Sub foo()
> list "bug2.inc"
Sub foo()
> run "bug.bas"
Error in bug2.inc line 1: Duplicate name
> ls
> edit
> Print "Hello World"
> new
> clear
> Print "Peter, I think this is broken!"
Edited 2020-11-15 20:40 by thwill
Posted: 02:15pm 15 Nov 2020
  Quote  I'm having issues with RC19
Not specific to RC19 - will fix
Posted: 03:23pm 15 Nov 2020
Thanks Peter.
But I'm just warming up ... unfortunately RC19 has broken parts of my tool-chain which has made reducing the problem to a reproducable small example harder.
Edited 2020-11-16 01:23 by thwill
     Page 1 of 4
