Local Time 19:45 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Circuit advice
lew247
Posted: 09:57pm 30 Oct 2020
I need an output from a Pic pin to switch the shutdown on a buck converter that converts 3.3 to 5V
If the Shutdown pin on the  buck converter is below 0.4V the buck converter is switched off
if the pin is high the converter switches on
I'm making a circuit that needs 3.3V from the pic easy enough but it also needs 5V for a different ic and it's being powered from batteries so the current draw needs to be as low as possible, ie the converter only turned on when needed
Should this circuit work? it's only to switch the Shutdown pin on THIS module
Turbo46
Posted: 10:09pm 30 Oct 2020
I don't think so. You need a converter configuration with a pull-up resistor.
If the PIC has a 5 volt compliant pin a direct connection should be OK.
Sasquatch
Posted: 10:25pm 30 Oct 2020
Well, No!
The data sheet specifies that the power converter module has a 100K pull-up resistor on the shutdown input.
Assuming that your Pic is running at 3.3V, you will need the collector of the NPN transistor tied to +3.3V and move the 1K resistor to connect the emitter to ground.  then your shutdown signal would be connected at the junction of the emitter and resistor as in your diagram.
                   +3.3v
                    /c
                b|/
Pic Pin -----|    NPN
                    \e
                    |--- shutdown
                    \ 1K
                   Gnd
Edit:  Well my diagram got mangled, but you get the idea.
Edited 2020-10-31 08:30 by Sasquatch
-Carl
Sasquatch
Posted: 10:31pm 30 Oct 2020
  Turbo46 said  I don't think so. You need a converter configuration with a pull-up resistor.
The spec says  < 0.4V, I don't know if a OC output would reliably take the signal low enough?  Would need to check the specs on the PIC
Also need to consider the state of the pic output when uninitialized would likely result in the converter being on.
Edited 2020-10-31 08:46 by Sasquatch
-Carl
Sasquatch
Posted: 10:57pm 30 Oct 2020
Or you could eliminate the NPN transistor if you are using a push-pull output with a 5K resistor to ground.
-Carl
Turbo46
Posted: 11:16pm 30 Oct 2020
I would be very surprised if a PIC output could not reliably pull 100k down to below 0.4v.
This is the circuit I meant.
Use 100k for RB and you can omit RC if the inverter has a pullup resistor on board. If not a 100k resistor would do. Any small signal NPN transistor will do the job.
An active pull down for a logic 0 is far better than using a resistor divider.
But a straight connection to a 5v compliant pin is just so simple.
twofingers
Posted: 11:33pm 30 Oct 2020
  Turbo46 said  I would be very surprised if a PIC output could not reliably pull 100k down to below 0.4v.
Sorry, I would expect 0.6-07V. Or?
Michael
Turbo46
Posted: 11:47pm 30 Oct 2020
From a datasheet:
That's for 10mA not a few uA.
twofingers
Posted: 11:56pm 30 Oct 2020
opps, I thought you meant V-out from the transistor.
Turbo46
Posted: 12:02am 31 Oct 2020
I'd still expect 0.1 to 0.2 volts or there-about from a saturated small signal transistor at that current.
twofingers
Posted: 12:27am 31 Oct 2020
@Bill
I think you are right! I was confused.
But is it clear that the circuit inverses the voltage?
That means: OUT is LOW when IN is HIGH (>0.6V).
Edited 2020-10-31 10:44 by twofingers
hitsware2
Posted: 01:42am 31 Oct 2020
http://www.csgnetwork.com/transistorcalc.html
my site
Turbo46
Posted: 01:49am 31 Oct 2020
Thank you Michael.
  Quote  But is it clear that the circuit inverses the voltage?
I perhaps should have made that clear. I did mean to type inverter and not converter on my first post.
But hopefully a direct connection to a 5v compliant pin is all that is required.
@Hitsware2, That circuit could work but it relies on the transistor being open circuit when the input is low and R2 pulling the input to the buck converter low. But when the input is high the base current drawn from the PIC would be high and the voltage at the base of the transistor would only be approximately 2.8 volts (3.3v-0.7v) maybe not enough to enable the buck converter. Thank you for the interesting site.
Edited 2020-10-31 12:06 by Turbo46
Sasquatch
Posted: 03:07am 31 Oct 2020
The only problem with the inverter circuit would be that the connected device would be ON until the pic turned it OFF.  I would assume that it would be desirable to have the connected device be OFF until the PIC starts up and turns in ON.
-Carl
Posted: 03:11am 31 Oct 2020
Hi Lew, All,
You might not get the output low enough using an NPN transistor, if not try a PNP transistor as per this cct
It was mentioned that there is a 100k pullup on the buck convertor so the 1k on output should pull that pin LOW when the PIC output pin is HIGH.
When the PIC pin is LOW the 3v3 volts (HIGH) should get switched through to the output.
If you need the buck convertor ON or OFF when the PIC is not powered you might need a pull up or pull down at the PIC pin
Kind Regards
Sasquatch
Posted: 03:25am 31 Oct 2020
The old joke comes to mind:
"Ask 4 engineers and you'll get 5 opinions!"
-Carl
lew247
Posted: 09:36am 31 Oct 2020
Apologies
I completely messed up in the first post
It should have said Micromite pin (actually Armite), not pic
I'd been looking at numerous microprocessors during the day and my mind went to mush
I'm wondering if I could drive that pin low by directly connecting it to the Armite pin (with a capacitor across it)
Edited 2020-10-31 20:05 by lew247
MustardMan
Posted: 11:01am 31 Oct 2020
Suggest a FET... I was scared of them until I dived in and found out how they work, and what cautions you need to apply (ie: ESD), but for what you want to do that is what I would use.
Cheers,
Turbo46
Posted: 11:34am 31 Oct 2020
I don't know why you would want a capacitor but if you have a 5 volt compliant pin then that's all you need.
Posted: 12:06pm 31 Oct 2020
  MustardMan said  Suggest a FET...  that is what I would use.
+1
