Forum Index : Microcontroller and PC projects : CMM2 stich
| MikeAlves Newbie Joined: 29/07/2020 Location: United StatesPosts: 16 |
Hey guys, I finally got my switch. Just to be sure, I remove the wire that bridges the two holes and solder the pins of the switch into the PCB (see picture)? I am ok with a soldering iron, but I just don't want to mess this up. Thanks, Mike |
| RetroJoe Senior Member Joined: 06/08/2020 Location: CanadaPosts: 290 |
Mike, I can't see the picture, but "yes" - the switch needs to replace the "always on" jumper that came pre-installed on your PCB. I used an old push-on / push-off switch I had lying around, and it happens to illustrate the point perfectly! Edited 2020-09-08 10:28 by jpusztai Enjoy Every Sandwich / Joe P. |
![]() Here's the pic. I forgot to upload the picture. Am I lining this up correctly? |
Yes ON will be UP or DOWN depending on your switch. Jim VK7JH MMedit |
Thanks so much! |
Are there any versions of that switch where up is on? Visit Vegipete's *Mite Library for cool programs. |
| mkopack73 Senior Member Joined: 03/07/2020 Location: United StatesPosts: 261 |
Not that I'm aware of. Honestly, you get used to it pretty quickly... |
Are there any versions of that switch where up is on? Someone on your side of the wold found one but I didn't make a note of the part number or supplier. I am happy with down for on. Jim VK7JH MMedit |
I have come to accept and appreciate down for on - for this particular application. Fitting for something invented down under. ;-) Visit Vegipete's *Mite Library for cool programs. |
Do any of you know how to switch the vegimite port to peanut butter? Honestly, I did think the battery was faulty because the date was always wrong. Then I realized it had to be read Day Month Year instead of Month Day Year. :) |
G'day Mike, Another one from down-under here. Re the date, how about you try with the battery in up the other way? Cheers, Andrew |
| Womble Senior Member Joined: 09/07/2020 Location: United KingdomPosts: 267 |
This might work |
Looks good. Does it ship to the US? |
| Nimue Guru Joined: 06/08/2020 Location: United KingdomPosts: 450 |
Hi Another "switch" related question. Preassembled CMM2 To make life easier for my target audience of teachers, is there anything "wrong" with replacing the jumper that we move to flash the ROM with a SPDT switch? In theory, what I want to achieve is an outside the box switch that one way is "run" - ie normal operation and the other way is "flash" so that the device can be upgraded. I have wired this up and it works fine for running / flashing. If the device was accidentally moved to "flash" setting - but was otherwise set up to use (ie keyboard and power) -- are there any negative consequences? Reluctant to try in case I fry as they say.... Nim Entropy is not what it used to be |
| thwill Guru Joined: 16/09/2019 Location: United KingdomPosts: 4406 |
Unless I'm misunderstanding what you are talking about ... Hmm, I'm sure it is a switch on mine. Anyway you don't need it, search the manual for "UPDATE FIRMWARE", this performs the "switch" in software until the next reset/reboot. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Unless I'm misunderstanding what you are talking about ... Hmm, I'm sure it is a switch on mine. Anyway you don't need it, search the manual for "UPDATE FIRMWARE", this performs the "switch" in software until the next reset/reboot. Best wishes, Tom - defo a jumper inside mine. Ok -- software switch is good. I should learn RTFM.... Nim Entropy is not what it used to be |
Ok -- software switch is good. I should learn RTFM.... Nim I think yours must be an all in one board whereas mine has the Waveshare module and the switch is on the module. If you aren't obsessively reading and re-reading the manual then you aren't capturing the full 1980s microcomputer experience ![]() Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
If you aren't obsessively reading and re-reading the manual then you aren't capturing the full 1980s microcomputer experience ![]() Tom I read mine in bed -- spiral bound and all. Nim Entropy is not what it used to be |
Little switch This is a switch that can be used. Micromites and Maximites! - Beginning Maximite |
