Local Time 18:21 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LINUX: Need serial port terminal software...
Posted: 11:17pm 09 Aug 2019
Hi all.
Now I am in Linux full-time, I need a serial-port terminal. Most of my searching results in either Linux terminal softwares(not serial terminal softwares), or Windoze only ones like Tera Term etc.
I want a Linux one.
I did find CuteCom, and installed that, but for some reason, it won't let me talk to the COM port.
If I plug in an E28 module, Linux sees it there at /dev/ttyACM0, but if I select that device and 38k4 baud, 8N1 and try to open it, Linux replies with 'Permission denied'
I know I have the correct path in Linux to the E28 device, but why CuteCom won't let me open the port eludes me at present.
Can anyone here suggest other terminal programs I can try?
If Rob is reading this, I don't suppose you have a Linux version of your excellent GFXterm application do you? It was my go-to terminal when I was running Windoze...
SimpleSafeName
Posted: 12:08am 10 Aug 2019
Serial ports are off limits to users outside of the "dialout" group. This should fix you:
https://askubuntu.com/questions/210177/serial-port-terminal-cannot-open-dev-ttys0-permission-denied
Posted: 12:35am 10 Aug 2019
Putty for Linux works.
And yes, you have to add yourself to the dialout group.
If you install ser2net, you should be able to run Rob's program (or TeraTerm or MMEdit) under Wine and use a TCPIP link to localhost to link to ser2net.
I find that easier than trying to battle with serial ports and Wine.
Something more for you to learn in your new adventure.
PeterB
Posted: 12:43am 10 Aug 2019
Good morning Grogster.
For the first (and only) time I am ahead of you
Have a look at ZORIN WINE & USB.
Quazee137 is a very good bloke
Peter
Quazee137
Posted: 01:11am 10 Aug 2019
I use minicom for my USB/ACM serial ports.
When I use GFXTerm I have to start it under wine then go delete the links
wine makes relink the first 8 and then CONNECT in GFXTerm.
to get a list of what wine does.
ls -l ~/.wine/dosdevices/com*
you'll find any USB/ACM some where in the list of comm's.
Posted: 04:38am 10 Aug 2019
@ SimpleSafeName: Thanks very much. I added myself to the dialout group, and I now have access to the MM console.
@ TassyJim: Thanks, I will download a copy of MMEdit now, and see if I can make it work. I will also have a look at ser2net.
EDIT: Installed Putty, and it can talk to the console just fine too now. I would like to make the terminal text green instead of white, and have changed a few things in the Putty settings, but I cannot make the text green. I have been able to change the cursor to green and make it blink, but have not yet found how you make the text change colour from the white it is now.
Edited 2019-08-10 14:41 by Grogster
Posted: 05:47am 10 Aug 2019
You can change the colours and save the default configuration in Putty then any new session will have the new settings
The saved settings should be in a folder .putty/sessions
You can edit these directly rather than using the gui panels.
If you change
colour0=0,187,0
colour1=0,255,0
you will be green with envy.
That changes the default foreground normal and bold.
Be prepared for strange things once you start doing things with non standard colours. MMBasic might not know what you are using and will expect standard colours.
To see the current serial devices, from a command prompt:
dmesg | grep tty
Posted: 06:45am 10 Aug 2019
I am now green with envy.
Thanks, Jim.
I am going to have to start a LibreOffice file for useful Linux things like this, and for program equivalents to Windoze ones.
Posted: 09:24am 10 Aug 2019
Maybe one of these
screen
moserial
gtkterm
picocom
gterm
qtterm
Not sure of these
aterm
xterm
eterm
I tend to use screen, not least for its -L (log to file) feature e.g.
screen -L /dev/ttyUSB0 57600
Posted: 09:43am 10 Aug 2019
https://www.ssh.com/ssh/putty/linux/
works with com ports
Posted: 11:23am 10 Aug 2019
  Grogster said  If Rob is reading this, I don't suppose you have a Linux version of your excellent GFXterm application do you? It was my go-to terminal when I was running Windoze...
not yet, though i do plan on a port to linux using Lazarus/FPC.
i've been going through a similar process to you, getting linux mint running on several HP stream 11 netbooks. i also have a desktop machine in storage with 16gb of RAM running linux and a win7 VM. but it is still early days, and i don't have enough spare time at the moment to get much done in terms of programming - am in the middle of a High Court action to get an apartment building sold, and as a result am living in an empty apartment (that leaks) with just a few cardboard boxes of possessions accessible.
rob :-)
Posted: 11:16pm 10 Aug 2019
I have installed GFXterm and MMEDIT inside the XP VM, and they run fine in there.
In the settings for the XP VM, SERIAL PORTS/Port 1/Enable as COM1. Port Mode=Host Device, connect to existing pipe/socket, Path/Address: /dev/ttyACM0.
That done, GFXterm in the XP VM sees the E28 module as COM1 @ /dev/ttyACM0 on the Linux system.
Learning more and more each day as I play around with Mint.
I did try to run MMEDIT via PlayOnLinux and WINE, but it went insane, loading more then 12,000 lines of junk code as soon as I ran it, and when I clicked on NEW, the cursor went nuts flicking between a normal arrow, and a watch icon and back again. I killed it. It runs just fine in the XP VM though, so that has solved those two.
I also have a Linux copy of Putty on the Mint desktop I can use if I want.
tgerbic
Posted: 08:27pm 12 Aug 2019
I have played around with a bunch of terminal/serial emulators on linux over the years but seem to always gravitate back to putty or minicom. They work fine.
I worked in the MODEM industry for many years and used a lot of really great serial terminal applications on Windows. Many did telnet and/or had many VT emulations as well. Nothing comes close on any linux or modern Windows machine. As MODEMs died out, so did the great serial terminal applications.
PeterB
Posted: 11:58pm 12 Aug 2019
Good Morning grogster
I get 12059 lines of rubbish.
Mine is white text on black or green and can be cleared by 'select all / delete
That is on MINT and ZORIN.
Are other people seeing this?
Peter
Edited 2019-08-13 09:59 by PeterB
Posted: 03:25am 13 Aug 2019
Yes, that is what I am seeing. Or at least, what I WAS seeing under WINE. It runs just fine in the XP VM though.
Posted: 07:19am 13 Aug 2019
I assume you both are referring to MMEdit under Wine.
I don't see any such problems here.
Wine V 1.6.2 and Linux Mint 18.2
PeterB
Posted: 12:01am 14 Aug 2019
Good morning Jim et al
Sorry if I'm a bit slow but I need my beauty sleep.
I an using the latest of every thing (I think)
I started a topic ZORIN WINE & USB a few days ago just to get the USB ports working.
Quazee137 and others helped and I thought it was fixed but when I turned it on a few days later it failed. So I started poking around and that is when the rubbish started.So I decided to compare my MINT with my ZORIN and pretty soon I had rubbish on both. At least I'm consistent. And I am no longer terrified of the command line just ignorant of it.
Peter
PeterB
Posted: 06:33am 14 Aug 2019
Well I fixed that problem, I reinstalled MINT. I have not done the ZORIN one yet.
But I still can't talk to the USB ports.
These are the steps that don't work:
dmesg | grep tty to see what is connected
I get ttyACM0 for the E64
and ttyUSB0 for the nano
cd .wine/dosdevices
then ls to list ports
then rm com1 & rm com2 so that they are free
ln -s /dev/ttyUSB0 ~/.wine/dosdevices/com1 for nano
ln -s /dev/ttyACM0 ~/.wine/dosdevices/com2 for E64
Then ls -l /dev/ttyUSB* gives ttyUSB0
and  ls -l /dev/ttyACM* gives ttyACM0
Quazee suggested I should disable the ModemMamager but that doesn't seem to do anything
Another suggestion was sudo before the ln.
There is a missing link and it aint me, I hope.
Peter
Posted: 07:41am 14 Aug 2019
  PeterB said  Well I fixed that problem, I reinstalled MINT. I have not done the ZORIN one yet.
Peter
Did you remember to make yourself a member of the dialout group?
Apart from that, I am not much use with Linux.
I do know that later versions of Wine use the registry to configure ports but they are supposed to be detected on startup anyway.
I forget how I setup my symbolic links. Too long ago and too slow thinking.
PeterB
Posted: 07:50am 14 Aug 2019
I didn't do it after the reinstall and then thought "that's it" but it wasn't.
I have got MINT talking to USBs twice now so what am I doing wrong?
Peter
