Local Time 07:35 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite and Chromebook
SteveA
Posted: 02:00pm 04 Apr 2018
I'm trying to get a Micromite and MM+ working with my Chromebook.
I can connect to the MM and enter commands etc.
But I can't get the built in editor to work, I can enter a program, move the cursor around and using 'backspace' delete characters. However, the Chromebook doesn't have function keys, so I can't save, run, etc.
There are two ways to access function keys on the Chromebook, either by holding the search key and pressing 1 thru 9, -, and +. Or by reassigning the top row of buttons which are used by chrome to func. by changing a setting in the keyboard dialogue. Neither work!
Pressing what should be F1 sends 'OP', F2 - 'OQ', F3 - 'OR', etc.
I've tried a couple of different serial terminal apps, BeagleTerm and SerialTerm for example but they all behave the same way.
Does anyone know how to get the function keys working?
Posted: 02:24pm 04 Apr 2018
Page 33 of the manual
You can also use control keys instead of the functions keys listed above. These control keystrokes are:
LEFT Ctrl-S RIGHT Ctrl-D UP Ctrl-E DOWN Ctrl-X
HOME Ctrl-U END Ctrl-K PageUp Ctrl-P PageDn Ctrl-L
DEL Ctrl-] INSERT Ctrl-N F1 Ctrl-Q F2 Ctrl-W
F3 Ctrl-R ShiftF3 Ctrl-G F4 Ctrl-T F5 Ctrl-Y
SteveA
Posted: 02:46pm 04 Apr 2018
Thanks Matherp that works a treat.
A case of RTFM!
SteveA
Posted: 03:48pm 04 Apr 2018
Following on from the above, I can see from SerialTerm that the MM is on /dev/ttyUSB0, it would be great to get MM Edit working!
So using Crouton (Chromium OS Universal Chroot Environment) I installed Ubuntu with a KDE desktop and GtkTerm.
At first GtkTerm couldn't access the serial port, but entering 'sudo chmod 666 /dev/ttyUSB0' in the terminal did the trick. GtkTerm can communicate with my MM, so I know Ubuntu is working.
Next I installed Wine and MM Edit. MM Edit starts up but doesn't find ttyUSB0.
So I needed to tell it where to look for the MM, in the terminal I entered:
'ln -s /dev/ttyUSB0 ~/.wine/dosdevices/com7'
MM Edit now works!
I hope this helps others.
Steve
sagt3k
Posted: 08:25pm 04 Apr 2018
Hi SteveA
Here you can find MicromiteCons v.0.933 which is optimized to work with wine.
To make sure you can add a COM on Linux platform port just double click in the "UART LIST (0)" section and add a number. For example digit only 7 to add in list COM7.
Here you can find discussion on MicromiteCons.
AntonioEdited by sagt3k 2018-04-06
SteveA
Posted: 09:10am 05 Apr 2018
Looks very interesting Antonio, I give it a try.
SteveA
Posted: 02:58pm 09 Apr 2018
Hello Antonio,
I had the the time to try your program, it runs, but unfortunately it doesn't detect any of the UARTS on my Chromebook, the drop down list is empty.
GtkTerm (Linux) and MMedit (Windows) both list all the available ports and allow me to select one.
It works on my Windows machine, so I'll have a play with it on that instead.
Steve
Added:
I,ve reread your post and had another quick play. I can double click and assign a port number, then when I click connect the program thinks its connected, buts it's not!
In the terminal window I get the following:-
fixme:ntdll:server_ioctl_file Unsupported ioctl 1b0048 (device=1b access=0 func=12 method=0
fixme:comm:set_queue_size insize 4096 outsize 4096 unimplemented stubEdited by SteveA 2018-04-11
sagt3k
Posted: 03:33pm 09 Apr 2018
Hi SteveA
Generally COM (only on Windows) are recognized by extracting from the list of "COMx" strings.
I read the list from regedit "HLM\hardware\devicemap\serialcomm"
What kind of UART HW/USB are you using?
AntonioEdited by sagt3k 2018-04-11
SteveA
Posted: 03:50pm 09 Apr 2018
Our posts overlapped!
<quote>What kind of UART HW/USB are you using?</quote>
Micromite plus.
sagt3k
Posted: 04:02pm 09 Apr 2018
  SteveA said   Our posts overlapped!
Micromite plus.
Hi SteveA
Are you using wine on linux?
Antonio
SteveA
Posted: 04:52pm 09 Apr 2018
Yes, wine running on Ubuntu with KDE desktop,running in a chroot on ChromeOS.
sagt3k
Posted: 07:17pm 09 Apr 2018
Hi SteveA
I try on Devian with a VMachine. My system see MicromitePlus connected by USB as "ttyACM0". Then in Linux I try with "ln -s /dev/ttyACM0 ~/.wine/dosdevices/com7".
Then start "wine MicromiteCons.exe" , add COM1 and I connected with console.
Antonio
SteveA
Posted: 07:55pm 09 Apr 2018
  Quote  My system see MicromitePlus connected by USB as "ttyACM0". Then in Linux I try with "ln -s /dev/ttyACM0 ~/.wine/dosdevices/com7".
I did exactly the same and gtkTerm and MM edit can connect to the MM.
  Quote  Then start "wine MicromiteCons.exe" , add COM1 and I connected with console.
This is the bit that doesn't work, the program runs but the dropdown list isn't populated and although I can add a port it doesn't connect.
There is obviously something very obscure going on between wine/ubuntu/chromeOS! I'm not a Linux expert, and I don't think I'll get to the bottom of it, so I'll carry on using MM edit.
Thanks for your help.
Steve
sagt3k
Posted: 05:48am 10 Apr 2018
Hi SteveA
Ok, thank you gor sharing you experience. Now I will work to give more suport on linux/wine.
Antonio
Posted: 08:45am 10 Apr 2018
hi steve,
i'd be interested to hear if you have any success with gfxterm:
http://www.thebackshed.com/docregister/ViewDoc.asp?DocID=22
this also uses the registry to locate comm ports.
rob :-)
SteveA
Posted: 10:12am 10 Apr 2018
  Quote  i'd be interested to hear if you have any success with gfxterm:
No problem, it runs but says 'No Serial Ports Found'
sagt3k
Posted: 10:25am 10 Apr 2018
Hi SteveA
If you use wine on linux,you need execute a link between /dev/ttyXXX and logic link comx win compatible
Antonio
SteveA
Posted: 10:46am 10 Apr 2018
  Quote  If you use wine on linux,you need execute a link between /dev/ttyXXX and logic link comx win compatible
I've been doing this:
'ln -s /dev/ttyUSB0 ~/.wine/dosdevices/comx'
where 'comx' is the port number I want to assign, for example com1..com2..etc
Is that what you mean?
sagt3k
Posted: 11:10am 10 Apr 2018
Hi SteveA
With command dmesg in linux you can see exatly how your device is,recognized. Micromite Plus perhaps it seen a ttyACM0.
Antonio
SteveA
Posted: 12:53pm 10 Apr 2018
MM+ show as ttyACM,USB to serial adaptors show up as ttyUSB.Edited by SteveA 2018-04-11
