Local Time 07:44 25 Oct 2026 Privacy Policy
Forum Index : Electronics : Inverter PCB’s
     Page 1 of 29
Posted: 03:58am 21 Mar 2018
Thought I better open a seperate thread for this instead of hijacking Aarons thread.
For those who are interested I am getting numbers to order PCBs to build your own Inverter. This is based on Oztules design but the power board has the addition of Totem pole drivers. They can be bypassed with a few jumpers if you prefer to stick to Oztules circuit.
It would depend on the total numbers ordered the more ordered the cheaper each PCB is, exchange rates change daily also.
5 ordered around $50 AUD each
10 ordered around $40 AUD each
15 ordered around $30 AUD each
20 ordered around $25 AUD each
You can go to www.pcbway.com and check the numbers the boards are 200 X 300 MM 1.6 thick 2 oz copper. Prices above include freight to me from china, there would be local postage as well. I used 65 cents as the exchange rate because when you pay with paypal you don't get a very good exchange rate.
Control boards are around $10 - $15 each, I need to redo the design to include the latest update. I would have to start from scratch in the software I use so would take a week or 2 to do that.
So far I have people we have put their hands up for 6 PCB's, I want at least 2 more for myself, a few more will put us into the 15 buy price.
Here is a list of the power board components
6 100uf 63v electrollytic cap
7 104 50v 2.54mm Caps
1 10uf 50v 5.08 cap
4 10nF 103 3KV capacitors (Snubbers)
6 100V 10000UF Electrolytic (Can) Capacitor 35mmX60mm
1 4.7uF 250V Metallized Polyester Film CBB Capacitor 475J,
2 CAPACITOR, SAFETY, 10NF, 250V, 20%
1 18V Zener
2 UF4007 Diode
1 Tip35c
4 Tip41c
4 Tip42c
24 HY4008w MOSFET
24 IN4148 Diodes
1 120 Ohm 5W Resistor
1 10K 0.5w resitor
4 47 Ohm 3W Resistors (Snubbers)
4 5k 0.5W
4 20 Ohm 0.5W
24 10 Ohm 0.5W
24 20k Ohm 0.5W
4 10k Ohm 0.5W
Edited by Madness 2018-03-22
ryanm
Posted: 04:19am 21 Mar 2018
I'm up for a set of power and control. I'll get two sets if we can hit the 15 pricing.
Posted: 04:24am 21 Mar 2018
A couple more and we will be over 10.
Here is the Silkscreen.
2018-03-21_142334_8_KW_Power_TIP4142_-_PCB.pdf
Boppa
Posted: 05:15am 21 Mar 2018
put me down for 2 Madness, then I'll have to get some toroids...
Posted: 05:36am 21 Mar 2018
I have just been asked by PM if these boards work with Grid Tie Inverters. Yes they do, I am running 2 GTI's ATM both 5KW one has 5KW of panels and the other 1KW. You do need to use some form regulator on it as have done as per this thread. During the day my Inverter is mostly running backwards charging the batteries when there is excess power. I am working on having 11KW of panels connected via the GTI's but limiting the maximum AC power back via the inverter to 5KW. This is to not overload the inverter and also to limit the battery charge rate to the manufacturer's specifications. This will still allow the GTI's to run at full power when there is enough load on the system.
I had some issues with the regulator which have been all sorted out and it works perfectly now. They were having arc to ground which was due to a bodged together design and the other was dividing the drains of the MOSFETs where it is on a GTI with 2 MPPT channels.Edited by Madness 2018-03-22
Posted: 05:43am 21 Mar 2018
We are now at 10.
poida
Posted: 06:19am 21 Mar 2018
I would like 2.
Payment when and how?
Posted: 06:48am 21 Mar 2018
Once I have the numbers then I would prefer payment before ordering via Paypal. If I rip you off (which I won't) paypal will refund you.
renewableMark
Posted: 07:08am 21 Mar 2018
Up to 12, reckon you'll get 20 by nightfall tomorrow.
I'll go from 2 to 3 sets if it gets us into the next bracket.
If something goes pop (lightning etc) it's normally just the power board that needs swapping yeah, prob handy to have a tested one made up as a spare.
Cheers Caveman Mark
Off grid eastern Melb
Posted: 07:20am 21 Mar 2018
Add another 2 John has doubled his order, we might get to 20 yet.
If you have strike who knows where it will stop, Revlac had his Inverter blown up via a disconnected power line. My power board includes 4 MOVs to try to clamp any lightning strikes.Edited by Madness 2018-03-22
Bryan1
Posted: 07:58am 21 Mar 2018
Madness you can put me down for one power and one controller board. Been thinking about making one for yonks so may aswell make a start.
Regards Bryan
poida
Posted: 08:01am 21 Mar 2018
no worries, post here the price and I will pay via paypal (tell me the PP address you use)
Posted: 08:21am 21 Mar 2018
That's 16 plus a couple for myself so we are very close to the 20 board price.
renewableMark
Posted: 09:08am 21 Mar 2018
Maybe list them on Ebay?
Edit, that may not be such a great idea, as you'll get too many gumbies like me you have to help along too much. Edited by renewableMark 2018-03-22
Cheers Caveman Mark
nickskethisniks
Posted: 09:23am 21 Mar 2018
For that price I want 2 boards as well. How much would je transport to Belgium?
Posted: 09:25am 21 Mar 2018
I am not making anything out of this, the price is very close to cost. You can check with the figures on the 1st post and key them into PCB ways quote system. Keep in mind the poor exchange rate plus PCBway charge a fee that you don't see till you go to pay for an order.
Revlac
Posted: 10:11am 21 Mar 2018
Put me on for 1 or 2 if that helps make the number.
Im not in a hurry
I still have to setup an account.
Thanks Gary
Aaron
Edited by Revlac 2018-03-22
Cheers Aaron
Off The Grid
Posted: 11:07am 21 Mar 2018
  nickskethisniks said   For that price I want 2 boards as well. How much would je transport to Belgium?
Just under $50AUD for 1 KG economy air which takes around 2 weeks for delivery, the economy sea is $5 less and takes up to 3 months.
yahoo2
Posted: 03:11pm 21 Mar 2018
Put me down for 4 inverter PCB's and 4 control boards Please.
RFburns
Posted: 07:36pm 21 Mar 2018
Put me down for 2 inverter PCB's and 2 control boards Please.
Strong like horse smart like tractor!
     Page 1 of 29
