Local Time 04:31 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I2CPort
jman
Posted: 07:30am 16 Mar 2018
Hi
I am having an issue with I2CPort CFunction the following code using standard I2C commands works as expected
I2C open 100, 100
I2C write INA219_ADDRESS, 0, 1, Register
I2C read INA219_ADDRESS, 0, 2, GetData()
With the folowing code
r=I2CPort(1, 15, 16, INA219_ADDRESS, 1, Register)
r=I2CPort(2, 15, 16, INA219_ADDRESS, 2, GetData())
The output is totaly incorrect with GetData(0) always 127 and GetData(1) always 255 no matter what the value of Register.
r returns 1 indicating the I2C commands were succesfull
So is the issue with I2CPort or I2CPort does not like the INA219 or i am i missing something
Jman
goc30
Posted: 10:31am 16 Mar 2018
Hi
have-you seen adafruit_ina library ?
https://learn.adafruit.com/adafruit-ina219-current-sensor-breakout?view=all
in exemple, lib send 1word (0xffff) in begin sequence
void Adafruit_INA219::wireWriteRegister (uint8_t reg, uint16_t value)
_i2c->beginTransmission(ina219_i2caddr);
#if ARDUINO >= 100
_i2c->write(reg); // Register
_i2c->write((value >> 8) & 0xFF); // Upper 8-bits
_i2c->write(value & 0xFF); // Lower 8-bits
#else
_i2c->send(reg); // Register
_i2c->send(value >> 8); // Upper 8-bits
_i2c->send(value & 0xFF); // Lower 8-bits
#endif
_i2c->endTransmission();
Edited by goc30 2018-03-17
GoodToGo!
Posted: 12:00pm 16 Mar 2018
Hey jman,
Have you managed to get the INA219 working on a standard I2C port? I ported the adafruit code to micromite a while ago. Have a look at Fruit of the Shed - INA219 code for an example....
Hope the above helps,
GTG!
Posted: 12:56pm 16 Mar 2018
It should work. I don't have a INA219 to test with but I did a lot of testing when I developed the CFunction and it never showed something so catastrophic as this.
jman
Posted: 07:13pm 16 Mar 2018
I am using the port of the Adafruit library from GTG located here
http://www.fruitoftheshed.com/MMBasic.INA219-Current-Sensor.ashx
and this works perfectly using the standard I2C the issue ONLY occurs when using the I2CPort CFunction.
Orginal code
' I2C read and write routines
Sub ReadRegister(Register, Value) 'Reads a 16 bit value over I2C
Local GetData(1)
Value = ((GetData(0) <<8) Or GetData(1))
Sub WriteRegister(Register, Value) 'Writes a 16 bit value (2 x 8 bit) in a regis
Local MSB,LSB
MSB = Value >> 8
LSB = Value And &hff
Local WriteData(2)=(Register, MSB, LSB)
I2C write INA219_ADDRESS, 0, 3, WriteData()
I2CPort Code
Local GetData(1),r
r=I2CPort(1, 18, 17, INA219_ADDRESS, 1, Register)
r=I2CPort(2, 18, 17, INA219_ADDRESS, 2, GetData())
Local MSB,LSB,r
MSB = Value >> 8
r=I2CPort(1, 18, 17, INA219_ADDRESS, 3, WriteData())
@GoodToGo! If you have a spare INA219 could you be so kind as to test the I2CPort CFunction and post the results
Many Thanks
Jman
Posted: 10:01pm 16 Mar 2018
Ah, all the arguments to I2CPort must be integers. Including the data to send and the array receiving the data.
I bet that is it.
GoodToGo!
Posted: 12:36am 17 Mar 2018
r returns 1 indicating the I2C commands were successful
Yep, I'm getting the same results. All variables are Integers and they are sending ok. Just the return results are up the creek.
I'll continue testing......
EDIT. Everything getting read from the INA219 are "1"'s. The module has onboard 10k pullup's on the SDA and SCK lines, I wonder if that coupled with the weak pullup's in the MM that the CFUNCTION invokes are the cause?
GTG! Edited by GoodToGo! 2018-03-18
Posted: 01:12am 17 Mar 2018
What do you have set for INA219_ADDRESS
Some of the options involve connecting the address setting pins to SDA or SCL which might cause grief.
GoodToGo!
Posted: 02:22am 17 Mar 2018
  TassyJim said   What do you have set for INA219_ADDRESS
const INA219_ADDRESS = &h40 '&b1000000 = (A0,A1=GND)
This is the default address with the solder pads open.
If I select a different address there is no response. So the address is ok. The routine works fine using the normal MM I2C port, just not using the CFunction.
GTG!
GoodToGo!
Posted: 02:38am 17 Mar 2018
Some results on the normal I2C port using the below amendment to the Fruit of the Shed code:-
sub ReadRegister (Register, Value) 'Reads a 16 bit value over I2C
local GetData(1), r
i2c write INA219_ADDRESS, 0, 1, Register
i2c read INA219_ADDRESS, 0, 2, GetData()
print "Register = " +str$(register)
'r = I2CPort(1, 15, 16, INA219_ADDRESS, 1, Register)
'r = I2CPort(2, 15, 16, INA219_ADDRESS, 2, GetData())
print bin$(GetData(0)) + " " + bin$(GetData(1))
Value = ((GetData(0) <<8) or GetData(1))
print bin$(value)
end sub
sub WriteRegister (Register, Value) 'Writes a 16 bit value (2 x 8 bit) in a register over I2C
local MSB, LSB, r
MSB = Value >> 8
LSB = Value and &hff
print "WD(0)= " +bin$(WriteData(0))
print "WD(1)= " +bin$(WriteData(1))
print "WD(2)= " +bin$(WriteData(2))
i2c write INA219_ADDRESS, 0, 3, Register, MSB, LSB
'r = I2CPort(1, 15, 16, INA219_ADDRESS, 3, WriteData())
end sub
  Quote  > run
WD(0)= 101
WD(1)= 10000
WD(2)= 0
WD(0)= 0
WD(1)= 111100
WD(2)= 11001111
Register = 1
0 11
11
Register = 2
100110 11111010
10011011111010
Register = 4
0 110
110
Register = 2
100110 11111010
10011011111010
Register = 1
0 101
101
Register = 3
0 10
10
Bus Voltage: 4.988V
Shunt Voltage: 0.03mV
Supply Voltage: 4.98805V
Current: 1mA
Power: 4mW
Calc. Power: 4.988mW
Now using the Cfunction by commenting/uncommenting the appropriate lines above:-
  Quote  run
WD(0)= 101
WD(1)= 10000
WD(2)= 0
WD(0)= 0
WD(1)= 111100
WD(2)= 11001111
Register = 1
1111111 11111111
111111111111111
Register = 2
1111111 11111111
111111111111111
Register = 4
1111111 11111111
111111111111111
Register = 2
1111111 11111111
111111111111111
Register = 1
1111111 11111111
111111111111111
Register = 3
1111111 11111111
111111111111111
Bus Voltage: 16.38V
Shunt Voltage: 327.67mV
Supply Voltage: 16.7077V
Current: 3277mA
Power: 65534mW
Calc. Power: 53677.3mW
As you can see, all "1"'s. One thing to note, that using the Cfunction is resulting in a s-l-o-w response. I wonder if it's timing out?
Cheers,
Posted: 05:55am 17 Mar 2018
  GoodToGo! said  One thing to note, that using the Cfunction is resulting in a s-l-o-w response. I wonder if it's timing out?
This is strange, if it was timing out I2CPort would have returned zero indicating an error. But then why is it slow? I2CPort is the master so it controls the clock (100KHz) so that cannot be the issue. Perhaps the INA219 is slow to respond but is less than the timeout (which is 5ms).
The I2C command uses the PIC32 hardware while I2CPort is bitbanged in software. Perhaps something (signal levels, timing, noise, etc) is marginal and the hardware I2C is better at handling it.
GoodToGo!
Posted: 06:17am 17 Mar 2018
  Geoffg said  Perhaps the INA219 is slow to respond but is less than the timeout (which is 5ms.)
I wonder if this has something to do with it? The normal MM I2C timeout is a minimum 100ms. I normally start the I2c with "I2C OPEN 100, 100". The INA219 datasheet mentions "The INA219 includes a 28-ms timeout on its interface to prevent locking up an SMBus".
The thing can interface with either I2c or SMBus using the same pins. Is it possible that the larger timeout to make it compatible with SMBus is causing issues with the CFunction?
Your thoughts?
GTG!
jman
Posted: 06:58am 17 Mar 2018
And some more food for thought
Screenshots of the write and we can see the timing is not the same.
The working write is below the bit in RED is 10.1us
The NON working write the bit in RED is 9.988ms
Export of the trace in txt format, seems odd the reads are missing from the NON working one
Working
Time [s],Packet ID,Address,Data,Read/Write,ACK/NAK
0.621046166666667,0,'128','5',Write,ACK
0.621140333333333,0,'128','16',Write,ACK
0.6212345,0,'128','0',Write,ACK
0.637430666666667,1,'128','0',Write,ACK
0.637524833333333,1,'128',<,Write,ACK
0.637619,1,'128','207',Write,ACK
0.640441,2,'128','4',Write,ACK
0.640916833333333,,'129','0',Read,ACK
0.641014083333333,,'129','3',Read,NAK
Not Working
0.902392583333333,0,'128','5',Write,ACK
0.992295416666667,0,'128','16',Write,ACK
1.08219,0,'128','0',Write,ACK
1.30808975,1,'128','0',Write,ACK
1.39799591666667,1,'128',<,Write,ACK
1.48789825,1,'128','207',Write,ACK
1.70038208333333,2,'128','4',Write,ACK
So it seems the timming is an issue
Jman
Posted: 07:13am 17 Mar 2018
The I2c and SMBus are essentially the same thing so it is hard to see how that is the problem. The 28-ms timeout also could not be the issue - from the data sheet: SMBus timeout in the INA219 resets the interface any time SCL or SDA is low for over 28 ms.
I believe we need to get a logic analyser on to this.
EDIT: JMan beat me to it.Edited by Geoffg 2018-03-18
Posted: 07:40am 17 Mar 2018
The screenshots don't help - I presume that the red patch is the transfer but it is unreadable.
The difference in "the trace in txt format" is that that the two reads at the end are missing. Otherwise the listings are identical.
We need some correlation between what your program was doing and the trace. Can you modify your program to print the arguments to every write and read? Comparing that to the trace might shed some light on the issue.
Frank N. Furter
Posted: 10:08am 17 Mar 2018
@Jman,
did you tried another pullup? In the data sheet a pullup of 3.3K is recommended...
Frank
Posted: 11:09am 17 Mar 2018
The symptoms you are seeing are consistent with the CFunction thinking the clock is being stretched - this would explain the slow response but no error. The Cfunction code implements clock stretching properly which many hardware implementations don't. I would double check you don't have a dry joint on the clock pullup and as Frank suggests go with a more aggressive pullup - say 2K7
jman
Posted: 08:35pm 17 Mar 2018
Hi
The frirst thing i did prior to the orginal post was to replace the 10k pullups with 4k7 ones these have now been replaced with 2k7 pullups and we still have the issue.
I will do a few more takes with the logic analyzer and post the results
Jman
jman
Posted: 09:11pm 17 Mar 2018
Some more info from the logic analyzer
Working read
Non working read
Working export
0.567969875,0,'128','5',Write,ACK
0.568064,0,'128','16',Write,ACK
0.56815825,0,'128','0',Write,ACK
0.57616525,1,'128','0',Write,ACK
0.576259375,1,'128',<,Write,ACK
0.576353625,1,'128','207',Write,ACK
0.58779375,2,'128','4',Write,ACK
0.58826975,,'129','0',Read,ACK
0.588367,,'129','4',Read,NAK
Not the non working one has NO ack after the setup to read but instead has a second setup to read ?
NON Working export the read is missing :(
0.784313625,0,'128','5',Write,ACK
0.8742155,0,'128','16',Write,ACK
0.964119375,0,'128','0',Write,ACK
1.181285875,1,'128','0',Write,ACK
1.271188875,1,'128',<,Write,ACK
1.36108075,1,'128','207',Write,ACK
1.5783975,2,'128','4',Write,ACK
Jman
GoodToGo!
Posted: 05:47am 19 Mar 2018
Finally got around to trying this on my logic analyser. (Saleae knock off)
The first thing I noticed is that the I2c clock for the MM port is 100KHz. However the CFunction appears to be 100Hz!
Using the dedicated I2C port:-
Using the Cfunction:-
Attached are the analyser files (in LOGICDATA format) for anyone to have a look at.
2018-03-19_154535_I2C_INA219_Logicdata_files.zip
The clockspeed explains why it's slow I guess......
Thoughts?
GTG!
