Local Time 02:47 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : The PIC32MZ board from OLIMEX
Micro-80
Posted: 06:05pm 26 Feb 2018
The new version of the board PIC32-HMZ144 is now available with a microcontroller PIC32MZ2048EFG144.
Posted: 06:44pm 26 Feb 2018
That looks suitable for the MMX MMBasic.
Have I understood correctly?
Posted: 06:53pm 26 Feb 2018
  Quote  That looks suitable for the MMX MMBasic.
The SDcard won't work as wired
Posted: 07:15pm 26 Feb 2018
Thanks, Peter.
Posted: 07:36pm 26 Feb 2018
Also the MMBasic I2C is compromised by the way the SDcard is wired and the only thing on the Olimex UEXT port that works is MMX I2C2 on the pins they specify for I2C.
This is the one problem with the Peripheral select mechanism on the PIC MX and MZ chips. It gives flexibility but also means that PCBs developed by different organisations are likely to be incompatible to a greater or lesser degree.
Posted: 03:43pm 27 Feb 2018
Would it not be possible to make those pin assignments configurable in mmbasic?
Maybe with OPTION and only available after a restart.
Then every board can be supported.
Posted: 04:25pm 27 Feb 2018
There's only one matherp :)
But I expect anyone can ask for the source, and make the changes (if they're possible i.e. if the board can be made to do what is wanted).
Then it would help to offer the result back to Peter (if he will take it?) and/or Geoff.
Posted: 05:28pm 27 Feb 2018
  Quote  Would it not be possible to make those pin assignments configurable in mmbasic?
I've thought about that but it is very difficult. For a start the flexibility is limited. There is a complicated set of tables in the datasheet that say what pins can do what and it is easy to run out of any available pins for a specific use. Also, some pins are not flexible at all (All I2C pins and all SPI CLK Pins)
So if we take the Olimex board as an example, they have completely compromised I2C channel 1 by using its clock pin for SPI.
The whole philosophy of the Microchip development environment (Harmony) is that pin allocation is done before coding starts and is then fixed. MMBasic already complicates this by only allocating "extended" functions like I2C, SPI, UART, Count when they are used and allowing the user to de-allocate them. I know Geoff has considered removing this flexibility on the higher pin-count chips where it isn't so important.
Basically, then if you allowed the user to choose allocations they could only do so with the PIC datasheet in front of them and they would find it easy to completely b....r things up. This would be a nightmare to support and document
Posted: 05:52pm 27 Feb 2018
It's most odd that Olimex managed to foul things up so badly.
Posted: 07:08pm 27 Feb 2018
  Quote  It's most odd that Olimex managed to foul things up so badly.
They haven't really - they have just chosen a different allocation.
There are 6 I2C channels on the MZ each with fixed pinouts. I happen to use 1 and 2 and Olimex have compromised 1. The problem with flexibility is that there are lots of ways of doing the same thing but it isn't possible in code to easily change between them. For example each I2C channel uses 3 Interrupt addresses which are hard coded to that channel and of course the control register addresses are also fixed by channel. It would be completely impracticable for me to code I2C in a way that allowed flexibility but had I started using channels 4 and 5 on day one then there wouldn't have been an issue with that particular conflict.
Posted: 08:14pm 27 Feb 2018
Oh well, one of those things then.
Might have meant an affordable ready-made board for people who don't fancy the soldering but I suppose they can just use the RPi and side-step all such issues!
It's Sod's Law that both this Olimex board and the PIC32-EMZ64 Olimex board are unsuitable.
JohnEdited by JohnS 2018-03-01
Posted: 11:25pm 27 Feb 2018
perhaps what one wants for the MZ may well be:
- a minimal board with just the processor, Vcap, crystal and 3v3 regulator/caps on board (ie, no sockets or LEDs).
- 0.1" header for SD that matches up with the pinout of the cheap SD socket boards available on ebay, in a location where the ebay board can just hang out the side
- 0.1" header for power, ICSP and serial console combined.
- a 0.1" header for VGA output.
- all 100 of the pins brought out to four 2x13 headers arranged around the processor.
- strictly fits within a 100mm x 50mm footprint.
very similar to the snadpic boards that folks were using early on, and that can be sold with just the MZ processor populated. also, that can be posted around the world in a standard envelope.
if limited to 100mm x 50mm, the PCBs can be fabricated in 4 layers for around us$2.50 each.
rob :-)Edited by robert.rozee 2018-03-01
Posted: 05:47am 28 Feb 2018
I have done something similar in 2013 with a qfp-100 chip (MX795) for a customers project.
The absolute minimum can be done on a 37x37mm board, double sided.
with components on both sides.
All 100 pins is not really necessary as a lot of pins are VCC and GND.
Also the OSC pins would not need to be available.
This included a 32Khz crystal for the onboard rtc, a supervisory circuit and a 3.3v power supply.
Bump the board size to 50x50mm and you would have some room for specific pins, but this will probably need a 4 layer as the pins would be in the way. You can even add a 1455 to this to make it even easier to use.
Edited by MicroBlocks 2018-03-01
isochronic
Posted: 07:36am 28 Feb 2018
maybe I should rework this a bit : sn-7x
I have been considering it, mainly putting a rtc (spi) on it and feeding the
32khz to the MZ and nudging the seral io to be more compatible.
Fun, but ... there was not much interest.
Posted: 07:51am 28 Feb 2018
It would be a way to get a prebuilt board so I imagine would be interesting - but price may be a major problem.
Olimex make an entire board (PIC32-HMZ144) for 21.95e (US $27, £19).
Reinventing the wheel is looking costly.
Posted: 08:03am 28 Feb 2018
Boards that are already available can most of the time not be beaten by price.
If we were to make another specific one then it would only sell a few and that would not be enough to even recoup the costs.
This remains solidly in the hobby/have too much time domain. :)
My suggestion to adapt the software, maybe only as a compiler switch, to adapt for certain easily available boards is better.
It would be a bunch of defines that have to be worked out but ones that is done a specific version for a board is just a compile away.
Posted: 01:18pm 28 Feb 2018
all far too complicated. concentrate on the absolute mimimal requirements:
the MZ processor and 3v3 regulators will be the only active components. passives will be filter caps, resistors for the VGA mixing/levels, and a pullup on the reset line. plus the 24MHz (?) clock crystal. the SD 8x2 header leverages off the adapters available on ebay.
NO onboard 1455, NO onboard connectors beyond footprints for 0.1" pin headers. this is a board that can be shipped with just the MZ processor fitted for minimal cost, and the end user can then add whatever they want.
rob :-)
Posted: 01:41pm 28 Feb 2018
You are almost there. Just draw some traces and it is ready.
Don't wait for someone else.
Posted: 05:36pm 28 Feb 2018
Each persons 'perception' of minimum requirements will vary.
Take one of the many TQFP (or LQFP) Breakout Boards and use that as the 'minimum'. Some versions specific for the PIC32 will have provision for the decouplers and ICSP. However, ICSP is redundant if you have a MicroBridge module. And if you do have a MicroBridge, then no need for any vReg.
Add one of Grogsters SD Card modules (that he did for the E100) and you have SD functionality.
Add three 120R resistors along with three 1N4148s and you have VGA functionality. To save a VGA connector, simply cut and solder on a 'spare' VGA lead that you may have lying around.
By the way, the is how I built my test MMX144 module whilst Peter was working on the code (apart from I used a BoB with onboard vReg since the MicroBridge module wasn't available at that time).
And by the time you add a beeper, TFT 40-way, and general I/O connectors, then you have the MMX144 module - PCB already designed!
So really depends what people perceive as a 'minimum' . . .
Edited by WhiteWizzard 2018-03-02
Posted: 05:57pm 28 Feb 2018
Here is another early prototype of the MMX144 module!
This one used an E64 PCB (for the power supply), one of Grogster's SD Modules, and a jumper-lead linked VGA lead.
Note on this Break-Out-Board that it was simply an LQFP PCB - I had to solder the decouplers and other minimum components - seen on the right hand side of the photo below
I then added a NunChuck PCB/Module I had lying around (not seen in this photo)
