Local Time 02:46 31 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Quick One for TassyJim.
Phil23
Posted: 04:12am 22 Feb 2018
Printing code in colour?
Just printed 13 pages for a school project & it came out B/W.
Didn't actually check my settings, but can MMEdit print colour?
If not is there an easy way to take TBS formatted code to another application & print in colour from there?
Phil.
Posted: 04:21am 22 Feb 2018
I'm not Jim, but FILE/SAVE AS RTF works for me.
This outputs a colour RTF file, which I then save as a PDF - job done.
Posted: 05:37am 22 Feb 2018
Grogster has it spot on.
Printing colour was a pain so I let some other program do it...
Chopperp
Posted: 08:21am 23 Feb 2018
Hi,
I wanted to know this to, but I must be missing something. Didn't find an option to save as an RTF file so I replaced the .bas with .rtf but it still only opened as a normal B&W file in a word processor.
Chopperp
ChopperP
Posted: 08:41am 23 Feb 2018
Click FILE menu at the top left of the window, then moved down to 'Save as RTF', and left-click. Follow your nose from there.
Chopperp
Posted: 08:47am 23 Feb 2018
Can't see 'Save as RTF'. Ill up date MMEdit & see if it is there
ChopperP
Chopperp
Posted: 08:48am 23 Feb 2018
OK, that worked. Thanks
ChopperP
Posted: 08:52am 23 Feb 2018
I was about to suggest the latest version of MMEDIT, but you thought ahead of me.
Chopperp
Posted: 09:07am 23 Feb 2018
Another question..
Anyway of printing the line numbers?
ChopperP
Posted: 09:56am 23 Feb 2018
Pass.
Jim?
Posted: 08:31pm 23 Feb 2018
I did experiment with printing line numbers.
I can't remember why I gave up, I think it got too unreliable.
Getting the line-number colours correct is not difficult but the line-wrapping really stuffs up the display.
I don't want to do my own line-wrapping, it would only add more problems.
JimEdited by TassyJim 2018-02-25
Phil23
Posted: 10:11pm 23 Feb 2018
Had a little play, notice also that RTF retains the original case of the code as typed.
[Quote]
String
Vs
String
Other thought that came to mind was what can be done from NotePad++.
I did play around with a User Defined Language as metioned here.
Didn't ever try printing.
The language mostly works Like MMedit in it's colour coding but I never got it 100% right.
One big bonus though is that I did get it to the stage where it would let you list Subs & Functions in a box; really use for jumping around code.
Npp should have a line numbering plug-in, think I played with that & noticed there's an RTF add-on language as well.
Phil.
Posted: 11:14pm 23 Feb 2018
Phil,
If you want to print with the keywords in your chosen case, you need to select "Save Keyword CASE" in the Program menu first.
That will permanently alter your file with the format that you chose in Preferences.
It doesn't affect any new typing so you have to run it as required.
The process is too slow to automatically run too often.
Chopperp
Posted: 11:40pm 23 Feb 2018
OK
Thanks Jim
ChopperP
Chopperp
Posted: 11:45pm 23 Feb 2018
  TassyJim said   I did experiment with printing line numbers.
Found the Quote button
Thanks Jim
ChopperP
Chopperp
Posted: 12:08am 24 Feb 2018
For Jim again
For the CMM V4.5. Noticed that the Alpha-Numeric pin numbers (A0 etc) don't come up in red as do the normal pin numbers.
No real issue.
setpin 9, ain 'analog I/P for solar panel
setpin A0, ain 'Analog I/P for switches
setpin 10, inth, Rain_Gauge 'Rain Gauge Interrupt
setpin 20, INTL, Sw_Press 'Switch press detect
setpin D9, DIN 'Grey Water ON switch
lcd init D2,D3,D4,D5,D6,D7
Chopperp
ChopperP
Chopperp
Posted: 12:42am 24 Feb 2018
Just realised that Jim has all numbers come up in Red not only pin numbers so not really applicable to alpha-numeric pin numbers, though that would be good
ChopperP
ChopperP
Azure
Posted: 12:45am 24 Feb 2018
You also need to make sure the end quote or is after the quote or code you want to mark otherwise it wont do what you wanted.
Chopperp
Posted: 12:56am 24 Feb 2018
I thought I was doing something wrong
Chopperp
ChopperP
Posted: 01:51am 24 Feb 2018
If it starts with a digit, &H (hex), &B (binary) or &O (octal), it's a number
27BDFFC0
&HAFB1001C
&B01000011000010000000010001001111
&OA6410015
AFB1001C
anything else is a 'word'
It does cause a few issues with CFUNCTIONs
I will add the option to print line numbers to RTF, but you will have to live with any consequences. My main objection is, you loose the ability to copy and paste back into MMEdit because of the pesky line numbers.
