Local Time 18:51 24 Oct 2026 Privacy Policy
Forum Index : Wanted : Twisting the stator fingers
leftcliq
Posted: 12:30pm 09 Jul 2013
Hi Guys,
I have a F&P Type 4 cogless smart drive and I am trying to get the rotor to be as frictionless as possible. I have replaced the bearings. Has anyone tried to twist the fingers on the stator so that the rotor is easier to turn? If so, what technique did you use? Will this work with the type 4 stator? Is there any reduction in output?
Dale.
