Local Time 18:25 24 Oct 2026 Privacy Policy
Forum Index : Wanted : solar tracker thingo
brucedownunder2
Posted: 06:47am 11 Nov 2011
Ok, hi crew ...
I'm nearly ready for the solar tracker electronic movement thingo ..
So, If anybod out there has a good idea of a Cct , I'm interested --a bit of background ,,, I have a 'polar" tracker under construction -IE --3 way tracker - and I'm running a 12 wire multi pair cable out to the tracker for most of the controlling I might have to do . plus a pair of 16mmm square building wire main current carrying conductors -it's a 880 watt 4 panel array..
so, if anyone has an unused tracker gismo or a lead to a good Cct , please let me know .
Bruce.
Bushboy
TexAcoon
Posted: 03:12am 14 Nov 2011
G'Day Bruce!
New to the forum .. Here is a link on building a cheap solar tracker ... I think it's really cool .. Check it out ..
Cheap Solar Tracker
I would add a MOP (motor operated potentiometer) at the end of the servo to supply voltage to a small dc motor with an "all threaded rod" to the array .. As the solar tractor detects movement the servo will operate the dc motor to move your array .. It would take a little tweaking but once finished I think you'll have a really cool automatic tracker that doesn't cost a bunch ..
Here is another site to checkout ... Gives parts list for single axis tracking with a dark sensor that allows the array to swing back to the east after dark.
Phoenix Navigation
YouTube Video of operation
Doug
Cortland, Nebraska
Edited by TexAcoon 2011-11-15
brucedownunder2
Posted: 01:45am 15 Nov 2011
Thanks Tex -or Dougie....lol
u gave me some good stuff to research -- thanks
I'll keep u posted how I go
Bruce
Bushboy
TexAcoon
Posted: 02:23am 15 Nov 2011
Excellent! ... Good luck on your project ..
Tex or Doug is good enough for me ...
I'm as smooth as silk just to blend in with the crowd ..
Doug
Cortland, NebraskaEdited by TexAcoon 2011-11-16
