Local Time 18:37 24 Oct 2026 Privacy Policy
Forum Index : Wanted : wanted - used grid interactive inverter
milkwood
Posted: 06:36am 27 Jul 2006
I am considering connecting a wind turbine (under construction) to the grid but the inverters are so expensive. Hoping to find a cheaper used one. If you can supply one or have any suggestions please reply.
Ronald
RossW
Posted: 07:52am 27 Jul 2006
  milkwood said   I am considering connecting a wind turbine (under construction) to the grid but the inverters are so expensive. Hoping to find a cheaper used one. If you can supply one or have any suggestions please reply.
Tell me about it :(
I purchased a generator-interactive 10KVA RAPS unit 2 years ago. While it's a ripper unit, it cost a small fortune.
One of these days, I'll be able to afford some decent batteries to connect to it - but for now I have 8 x 6V/220AH trojans (10 KWH) - which are just too small - but the contractors destroyed the 48 x 2V/300AH glass-mat cells I had for it (30 KWH). Going on my present demand, that would have been pretty close to the mark, I'd be able to go a full day, perhaps two, before I needed power (genset, wind turbine or solar) - at the moment I'm hard pressed to make more than 12 hours. (ok, so I'm trying to keep discharge depth to <30%, maximum 50% overnight)
