Local Time 18:13 24 Oct 2026 Privacy Policy
Forum Index : For Sale : dc motor
helicable
Posted: 09:48pm 12 Dec 2007
hey , can anyone help me with input ?
i have a 180volt dc motor which came off a treadmill.
with no load it rotates free, with a 12 volt dc bulb(tail/light of an car) , it lights up with a slow turn using my fingers, however there is friction on the pully, if i turn it faster the bulb will blow with over voltage, i think if a larger load or many bulbs are used ithink it would be impossible to turn the pully?
can this be used as a wind mill? any details are appreciated.
thanks
wind-pirate
Posted: 05:41am 16 Dec 2007
Hi helicable
Best thing is to turn the motor with a drill and check the D.C. open voltage. and note the rpm's. If you can burn out a 12 volt bulb by turning this motor by hand that is uncommon for a treadmill motor, they usualy need a lot of rpm's to reach 12 volts. Check the motor out.
THE Pirate.
stealing wind & solar energy is fun
Tinker
Posted: 02:26pm 16 Dec 2007
  helicable said   hey , can anyone help me with input ?
thanks
Yes, it takes power to light a bulb and the power is felt as you try to turn the pulley.
I should imagine the motor is suitable, you just have to spin it up with something more powerful than your hand. Connect several (maybe 10?) 12V bulbs (same wattage) in series and see what voltage you get at the RPM you'd expect from your windmill. Start spinning it slowly, say 50RPM upwards rather than too fast. If you know somebody with a lathe, it would make an ideal driving source.
Klaus
Klaus
robbo
Posted: 11:00am 09 Feb 2008
Can you tell me what type of Treadmill you get this from ?
What brand, and how old ?
Wouldnt mind getting my hands on one of those.
javascript:AddSmileyIcon('')
"the Earth was not given to us, by our fathers, rather, it is lent to us by our children".
helicable
Posted: 04:29pm 11 Feb 2008
  robbo said   Can you tell me what type of Treadmill you get this from ?
helicable
Posted: 04:32pm 11 Feb 2008
hey there,
i'm not sure what brand name it is, but it came from a hospital a heavy duty one, it weighted
about 300-400 pounds,
but it was difficult to turn by hand when i had 6
12 volt bulbs hooked up, in other words the more bulbs the harder it was to turn,
i'm not even sure if its suitable,, ??
robbo
Posted: 11:04am 25 Feb 2008
Do you think you can get blades (3 or more) to turn it, with the wind in your area. If so, Great ! What are the total watts of the bulbs ? Eg. if it equals 100 watts then that is 8.3 amp at 12 volts.(12 x 8.333333 equals 100 watts) The motor can charge at 8.3 amps. Its just about getting the motor to turn with the resistance that is there.
helicable
Posted: 04:35pm 19 Aug 2008
not sure? i have to play with it a bit more,
but anyone out there with a wind mill that has a load hooked up to it, does it do the same? or does it react differently when suppling a battery?
robbo
Posted: 08:00am 28 Jan 2009
Generally, when a load is applied (such as charging the batteries), the mill has to work harder.
If a mill is spun up to produce 24 Volts, unloaded, then it should only produce about half this amount at the same RPMS, when under load.
Note*** Must take into account the power band of each unique motor.
Enjoy your tinkering , and have fun.
javascript:AddSmileyIcon('')Edited by robbo 2009-04-05
