Local Time 17:32 24 Oct 2026 Privacy Policy
Forum Index : For Sale : downsizing - everything inverter & solar related must go
Murphy's friend
Posted: 08:40am 29 Sep 2025
Sadly, the time to unload all this gear has come. There is no place for it at my new house.
Available: 6KW, 3KW, 1.5KW 48V inverters plus one 1KW/24V inverter as used in a caravan (it will start & run the A/C.)
There are spare parts & PCB's for the above. These inverters were very well built to the latest forum design and run trouble free.
Also, toroidal cores (partly wound ex warpinverter) 1KW, 0.5KW, 0.2KW.
Lots of inverter building related equipment also available.
This would be a great opportunity for somebody in or near Perth, WA, to go completely off grid. Shipping, unfortunately, will not be possible due to the weight.
Everything will be well below parts cost, you could just about name your own price and it will be accepted, if reasonable.
As mentioned, everything must go and it's too good for scrap.
I no longer read here regularly so please contact via email: az_100@msn.com
Klaus
Murphy's friend
Posted: 08:44am 29 Sep 2025
There is a mistake in the above, the toroidal core sizes are: 3KW, 1.5KW, 0.5KW.
Sorry - it won't let me edit it.
Godoh
Posted: 12:17am 30 Sep 2025
Hi Klaus, that sounds like a very serious bit of downsizing.
Good luck with the move,
pity that freight is so expensive and that WA is at the opposite end of the country.
Moving is never one of my favourite things.
I hope you can downsize your stuff enough
pete
