Local Time 10:39 25 Oct 2026 Privacy Policy
Forum Index : Electronics : non polarised capacitors
Tinker
Posted: 10:40pm 26 Oct 2017
I found a bag of 10uF/50V non polarised electrolytic caps among the bits & pieces in my shed and wonder if these are OK for the filter caps on the IR2110's and for general 5V power line filtering?
Somebody mentioned tantalums are no good for that application and as I have not used non polarised electrolytics before I want to be sure.
They measured exactly 10.0uF and have a nice 105 deg C rating as well as being physically of similar size then the polarised 10uF/25V types.
Klaus
oztules
Posted: 02:16am 27 Oct 2017
non polarized are just two normal caps in series... ie two 20uf electro's in series... so should behave exactly the same chemically I would expect.
....oztules
