Local Time 11:02 25 Oct 2026 Privacy Policy
Forum Index : Electronics : Soldering Iron Tip.
Phil23
Posted: 12:04pm 23 Jul 2017
Hi All,
The Tip on my Weller TCP is not much over 12 months old, but it's never been that great in staying tinned properly; almost as if the coating is bad.
Looking on RS, (where it came from), they list 4 different 0.8mm tips, but I can't distinguish the difference.
Can anyone offer advice?
They list:-
[code]
RS Part# Weller Code
661-510 4PT07-1
661-649 4PT08-1
661-526 4PTP7-1
661-655 T0054134899
[/code]
I'd be tempted to just get one of each, but rather not have unsuitable ones as opposed to a few spares.
Phil.
Warpspeed
Posted: 12:21pm 23 Jul 2017
Radio Parts stock Weller spares too, may be worth a look.
These tips also have a rated temperature, not absolutely certain but a fair guess might be the last figure "7" or "8" might be the temperature. There is often that number stamped on the back of the tip.
http://www.radioparts.com.au/search-products?productsearch=WellerEdited by Warpspeed 2017-07-24
Cheers,  Tony.
Phil23
Posted: 12:40pm 23 Jul 2017
Thanks,
Was aware of the temp codes, 7,8 x100°F.
Just not sure about the PT O7 Vs PT P7 variants for example.
The existing bit just has the temp code.
The current one is an 8 which is probably too hot.
Most others I have are 7's (bigger though).
The one in in now is a 661-649 & the packet (still in the drawer!) says lead free...
Wondering if that means it's coating is for lead free solder & that is the reason I've always found it not as good as my older tips (As in 20+ years older).
Phil.
Warpspeed
Posted: 03:30pm 23 Jul 2017
There are two different families of Weller tips. One has the conventional magnet and operates a reed relay in the usual fixed temperature self contained irons.
The other type are used in the hugely expensive "soldering stations" that have a variable temperature control and a digital temperature readout.
These are physically quite different.
I have never had to buy tips. I was once very lucky and worked for a company that went broke. I was given a huge handful of brand new assorted Weller tips that I have been using for over thirty years, and still have plenty left. So the mysteries of Weller part numbers are something I know nothing about.
Cheers,  Tony.
