Local Time 11:31 25 Oct 2026 Privacy Policy
Forum Index : Electronics : is a Blocking diode needed here
Rubes
Posted: 01:47pm 07 Jan 2017
Hi all again
I have a f&P micro hydro genny connected to bridge rectifiers which will then feed a mppt controller for 12v battery charging, the question is does the bridge rectifier setup act like a blocking diode to stop current from going from batteries via the charge controller back to the genny or do I need to put another diode inline after the bridge rectifiers and if so any suggestions on which one.
Posted: 04:46pm 07 Jan 2017
The bridge will act as a blocking diode between battery and generator.
One of the few times a blocking diode is used is to prevent a dump load discharging the batteries when the generator load is diverted to dump.
For a hydro system there is most likely no need for a dump load as to disconnect the geny from the batteries would not really hurt anything because it is not likely to runaway in overspeed like a windmill will.
Rubes
Posted: 06:50pm 07 Jan 2017
Thanks Downwind thats all I need to know, and yes because of limited head on the hydro plant the unloaded rpm is acceptable so I am not running a dump load.
