Local Time 11:01 25 Oct 2026 Privacy Policy
Forum Index : Electronics : Micro Inverter Build.
Phil23
Posted: 01:01pm 03 Jan 2017
Have read many of the build threads.
Has anyone considered micro inverters?
Are the feasible?
Pros, Cons, build difficulties & limitations would be interesting to hear.
Phil.
Posted: 01:11pm 03 Jan 2017
Depends on what you need it to do. As I understand it, it is not just the load current you want to suck from it, but the start-up surge current that you have to take into account for starting things like motors or compressors etc - they all suck quite large start-up currents. Not for long, but long enough to shutdown or otherwise disable a light-weight inverter.
Considering the trouble you have to go to to build a micro inverter, a little more cash can allow you to build a much gruntier unit.
It is better to have the capacity and not need it, then need it and not have it.
Having said that, again - what were you thinking of trying to run with a micro one?
Phil23
Posted: 04:50pm 03 Jan 2017
Just curious,
A friend has just put in a 20kVA micro inverter system. 64 panels each with their own inverters. 10 Lithium battery packs, each 1.2kVA from memory.
Would be interesting if I could run my office off something similar. It consumes a base load of about 1kVA.
It's interesting to see the monitoring on the 64 panel, all outputs varying when a bit of shading hits.
