Local Time 10:39 25 Oct 2026 Privacy Policy
Forum Index : Electronics : Inverter input current waveform
davef
Posted: 09:10am 22 Sep 2016
On my PowerMaster PM3000L 24V inverter with, for example, a 1kW resistive load the input current varies at a 100Hz rate and looks like a reasonable sinewave.
The current varies from quite a low value, say a few Amps up to 100A then back down to a few Amps over the 100Hz period. Average current about 50Amps and inverter efficiency about 90%.
There are quite a few inverter projects underway on the forum and I was hoping that people could tell me if what I see is common, or are there inverters that draw a steady DC current from the battery?
Thanks,
Dave
Madness
Posted: 11:16am 22 Sep 2016
I am no expert but you see mentioned a lot "Ripple" which is what you are seeing, what capacitors does it have across the input?
davef
Posted: 05:35pm 22 Sep 2016
No idea.
I have since been told that all inverters behave like this. The capacitance required to filter out the 100Hz would be very LARGE.
Tinker
Posted: 11:36pm 22 Sep 2016
I'm curious. How did you measure (with what) that current?
BTW, the capacitors used in my inverter add up to 60,000uF/100V electrolytics.
Klaus
oztules
Posted: 12:09am 23 Sep 2016
Yes what goes out must come in ......with a few losses.
At low power, the 60000uf I have will cover it pretty well, but as you get up to 2kw it is a significant flattened sine wave with the carrier impressed in it as well, and more pronounced as you climb up the scale.
..........oztules
davef
Posted: 08:04am 23 Sep 2016
Using at 90A 100mV shunt and a 'scope.
Thanks guys.
