Local Time 10:03 25 Oct 2026 Privacy Policy
Forum Index : Electronics : 2 digit BCD to 7 segment circuit?
Tinker
Posted: 10:16pm 26 Nov 2015
I have a requirement for a 7 segment display that shows 0-15 from a binary input.
The 74LS47 chip does 0-9 and I have been trying to use two 74LS47 chips & 2x 7 seg display to show a higher binary input than 1001, no luck.
Trolling through many posted articles & circuits on google only made this idea more confusing, is it at all possible to cascade 74LS47 chips without using many more IC's?
Any advise is welcome.
Klaus
VK2MCT
Posted: 06:23pm 27 Nov 2015
Have a look at a 74ls185 or equivalent to convert binary to BCD.
John.
Tinker
Posted: 12:45am 28 Nov 2015
  VK2MCT said   Have a look at a 74ls185 or equivalent to convert binary to BCD.
John.
Thanks John, that would do the trick.
However, it seems its no longer available, even the TI website does not offer it for sale.
Did you buy one recently, if so, where?
Klaus
VK2MCT
Posted: 01:08pm 28 Nov 2015
Never bought one.
Have you thought about using a micro.
Something like a Micromite maybe a one chip solution ?
John.
Tinker
Posted: 01:56am 29 Nov 2015
Thanks again John.
I know a micromite would work but as my circuit already gets the binary data from a picaxe chip that is also busy doing other things I do not want to complicate things with another microprocessor.
After trawling through the literally hundreds of relevant circuits that google brings up I found this:
http://forum.allaboutcircuits.com/data/photos/o/0/230-1233754129-0b80d412c3f18d255daa9df5b288785c.jpg
Which actually might work, it certainly looks simple enough and full adder chips are available here in Perth.
Klaus
VK2MCT
Posted: 02:42pm 29 Nov 2015
Why not output data from the picaxe as BCD rather than binary ?
Tinker
Posted: 06:56pm 29 Nov 2015
  VK2MCT said   Why not output data from the picaxe as BCD rather than binary ?
John, as mentioned above, the picaxe chip does other things which is easiest to do with binary data.
Just in case you wonder what I'm doing, I am presently converting my stand alone battery system from 24V to 48V.
With 24V I used the binary data to connect to 1 of the 8 cells at a time and sample & log the voltage at it. A single 7 segment display showed which cell was monitored with the corresponding cell voltage displayed on a DPM.
With 48V there are 16 cells so 2 x 7 segment displays are required. The common decoder/ driver chips for a 7 segment display do not allow cascading them, they show funny characters above binary 1001 inputs.
Klaus
VK2MCT
Posted: 01:22am 30 Nov 2015
Maybe then two 'banks of 8 cells".
3 bits LSBs count from 0 to 7 (8cells) 0000 0001.. 0111 then sets MSB
1 bit (1000) selects 1 then LSBs cycle 0-7.
enough,
John.
