Local Time 10:03 25 Oct 2026 Privacy Policy
Forum Index : Electronics : high voltage rectifier
irishron40
Posted: 12:06pm 25 Oct 2015
Hi. I just wonder can high voltage (600volt) GBU406 rectifier be used for a low voltage circuit say upto 30 volt.
thx
Posted: 12:30pm 25 Oct 2015
Yes. Results may vary.
High voltage rectifiers are more expensive, and generally have a higher voltage drop across the junction(s). A high voltage diode from a microwave oven wont even test properly unless you can feed a hundred odd volts through it, I used a megga meter to test those diodes when I fixed microwaves back in the 90's.
Ideally, you use a diode with a voltage closer to your circuit voltage. Less voltage drop and better current handling.
irishron40
Posted: 01:52pm 25 Oct 2015
ok thx glenn. i came across a couple of different ones, and just wondered could i use them for small projects.
thx
ron
