Local Time 19:43 24 Oct 2026 Privacy Policy
Forum Index : Electronics : Solid state relay - any good?
domwild
Posted: 10:52am 26 Sep 2007
Hi friends,
Bills Machinery in Perth has 500 relays, 280VAC 45A for $10 each. From little that I know about triacs, etc. I learned the following in the meantime:
To switch AC use:
Low amps - triac + snubber + opto
Middlish amps: relay
High amps: contactor
This seems to fall into the high amp category as it can switch 280V x 45A or about 12 KW resistive load.
I am easily confused!
I may need to switch 15A inductive and $10 does not seem to be much money if only I would stop drinking, so is this a good buy??
Winston Churchill
herbnz
Posted: 07:37pm 27 Sep 2007
Hi
Sounds good value I have been keeping a eye out for these at present I use a relay to control 230v to my water heater as a dump load on a 10sec cycle I would like to make solid state. trouble is importing to NZ would be worth it does firm have a email address ?
But yea very uasuful units if quality Ok Opto 22 a brand name but cost maybe $40.
Herb
domwild
Posted: 04:48am 01 Oct 2007
Herb,
Google Bills Machinery Perth - AUS. web sites only to get the email address. They did not reply to my email so I had to ring them - slack!
If you are stuck, then I can get the telephone number for you.
Winston Churchill
