Local Time 09:49 25 Oct 2026 Privacy Policy
Forum Index : Electronics : ATX PSU to Power Supply - Shunt Size?
wallablack
Posted: 07:42pm 15 Dec 2014
Hi All,
I am in the process of converting an old 300W ATX PSU from an old computer into a bench top power supply which will be more than handy.
Plan is is to have a stable 12V and 5V power supply. Both the 5V and 12V will run into a voltage converter (boost buck I think they call them)so I can have a bit of regulated power.
The ATX conversion was pretty easy thanks to Dr. Google.
My issue is is that I have noooo idea what size shunt to use for the amp meter below.
WHAT SIZE SHUNT DO I USE?
Ill have three of these...
One measuring 5V
One measuring 12V, and
One measuring "Boost Buck" OUTPUT.
Specs are:
Operating voltage:DC 4.5 ~ 30V
Measure voltage: DC 0 ~ 100V
Minimum resolution(V): 0.1V
Measure current :DC 50A (require external shunt)
Minimum resolution(A): 0.1A
Operating Current: <20mA
Display: three 0.28\" LED digital tube
Display color: Red (dual display)
Dimensions: 48 x 29 x 21mm
Mounting cutout: 45.5 x 26.5mm
Refresh rate: about 500mS / times
Measure accuracy: 1% (± 1 digit)
Operating temperature: -10 to 65° c
Operating Humidity: 10 to 80% (non-condensing)
Working pressure: 80 to 106 kPa
The wiring is as follows...Not much to do with the shunt size but I thought I'd throw it in for kicks.
Black line (thin): vacant or buck circuit (module) negative
Red line (thin): power supply+
Black line (thick): COM, common measuring
Red line (thick): PW+, measuring terminal voltage input positive
Yellow line (thick): IN+, current input+
(Please refer to the wiring diagrams for more details)
Thanks in advanced....
Progress on the power supply.
If anyone has a decent schematic or "how to" to use a pot etc to make the 12v and 5V adjustable please let me know...Dr. Google is good but also confusing lol.
Foolproof systems do not take into account the ingenuity of fools.
davef
Posted: 11:31pm 15 Dec 2014
I think there is some important information missing. For 50A what voltage do they expect across the external shunt? 100mV is common and Jaycar may have something. Don't see why is it limited to 50A, maybe that what the readout is set up for.
You can't do anything about the voltage ranges, as 5 and 12V are within the current voltage range. You could add a DC amplifier to make 5V put out 50V to increase resolution. But, that would be not be an easy task. Do you need more than 0.1V resolution?
wallablack
Posted: 02:00pm 16 Dec 2014
God I wouldn't be expecting to use anything over 10A...One shunt will measure amperage on the 5V side, the other on the 12V side and the third will measure the variable voltage of 12V to 30V produced from the voltage converter/boost buck thingo.
I actually want to do without the voltage regulator circuit board and make the voltage variable with a pot similar to the following one I found.
I would imagine the off the shelf ammeter/voltmeter is just at 50A because it "sound" user friendly...who knows.Edited by wallablack 2014-12-18
Posted: 02:04am 17 Dec 2014
Personally i think you are going about it the wrong way, where you should build a variable power supply with current limiting, as that way you have some protection to current overloads.
Have you looked on the forum and viewed the design i put forward for a power supply here.
http://www.thebackshed.com/windmill/articles/VariablePowerSu pply.asp
I struggle to see why you need a fixed 5v and 12v supply when a variable supply will do that anyway, if you do want a fixed supply simply add a switch to select 5v, 12v, variable voltage, that way its just a single volt meter and a single current meter.
With current limiting you can stuff up and not blow up your power supply.
I often end up with a short in a circuit and dont kill my supply due to current limiting, i can clip my DC supply leads together and still not kill the power supply due to current limited.
If you do enough with a power supply sooner or later you will short something and kill it if you dont have current limiting, then its back to square one with rebuilding it.........been there done that several times in the past.
Pete.
Gordz
Posted: 12:24am 18 Dec 2014
IMHO I would stick with the buck boost as it is more efficient being a switching topology. The shunt for your ammeter would depend on the designer of the unit. If it measures up to 50A max then it will likely be around 0.1 ohms or so, I would email the supplier and ask. If you do want to build a simple V regulator perhaps the LM338K will do as this will give you 3 to 5 amps. Either way I agree with Guru that no current limiting is a recipe for disaster especially when you are using an ATX power supply ad the bulk source.
Posted: 09:45pm 18 Dec 2014
I thought that PC PSU's already have built-in short-circuit and overload protection, do they not?
...perhaps not.....
VK2MCT
Posted: 10:18pm 18 Dec 2014
Yes PC supplies usually have protection of different sorts.
Bear in mind that 5v could provide at least 25amps and 12v at least 10amps approx.
So the load may become crispy very quickly.
I use a PC supply at times when lots of current is needed, but purchased a commercial supply because the current limit can be preset. This helps me from unnecessarily creating expensive brown smoke. The supply can also source more than 12v when occasionally needed.
John B
VK2MCT
Posted: 11:00pm 18 Dec 2014
Yes, that makes sense. Overload short-circuit kind of protection, but it would/could happily supply 20-amps or so into a load(read: fault!) without shutting down. Understood.
Meanwhile, in silicon heaven.....
Posted: 05:32am 19 Dec 2014
I think some of you have missed the point of current limiting, as why wait for a huge current overload to trip a shutdown on the supply PSU.
The view of a built in current limit to the PSU to protect the circuit is just asking for release of the magic smoke from a circuit.
With a controlled power supply you have some control to current limited supply, and not just a arc welder at 25 amps plus blasted into a circuit.
Pete.
Posted: 12:51pm 19 Dec 2014
Yes, good point.
I also would be inclined to spend the cash, and get a proper lab PSU with full adjustable current limiting.
PC PSU can deliver some serious current, but as has been pointed out, with overload current-limiting only.
I did see a video on YouTube a while back where a guy used a PC PSU and a heap of polyfuses via a switch to preselect various current limits. I guess that worked OK, but was probably a bit crude compared to the accurate current limit you can get on a proper adjustable lab PSU. With even these PSU's now going to switchmode, you can get some very juicy lab PSU's that are fully adjustable, yet much, much lighter then the older transformer based units, so they are nowhere near as expensive as the big and heavy high-current lab PSU's that used to be about.
Posted: 03:14pm 19 Dec 2014
I know you already have your LED modules etc, but I found this on ebay.
0-32v adjustable output voltage, 0-8A adjustable current limit - US$25 with free freight.
Because I am something of a sucker myself, I have bought one of these to play with.
While I won't be feeding it with an ATX supply, I will feed my test module with a 15v or 18v laptop PSU, as these can be had in 5A current flavours very cheaply.
wallablack
Posted: 03:50pm 23 Dec 2014
  Grogster said   I know you already have your LED modules etc, but I found this on ebay.
Looks like I am a bigger sucker than you lol...I just bought 2....always want a spare cos I'll probably blow one apart playing...
Eugeneo
Posted: 11:37am 12 Apr 2015
In case anyone is interested - The Corsair 550 watt non-modular version has a TL431 on the output side before the optical isolation feedback and can be converted to a variable voltage supply with a single pot and resistor from 3.5 to 15V (careful of the cap rating). You can put an shunt op-amp to feed back and get a switch mode regulated current supply as well. I suspect all the newer power supplies use this type of circuit and can be converted. Careful - if you decide to disable the current limiter, the thing can supply a few hundred amps and surprisingly not crater.
My local computer store had these on a blow out sale for like $30 so I bought 4 of them and now I have a 50V - 50A continuous variable supply.
Let me know if anyone is interested and I can dig up the mods.
Edited by Eugeneo 2015-04-13
Posted: 11:07pm 12 Apr 2015
I am very interested, so if you can dig out the mods it would be great.
There has been a few threads years back on modding PSU to variable supplies but was not as simple as you have suggested.
Look forward to knowing more detail about the mod.
For example i can buy a new PSU as listed below, although im sure i have an old one here somewhere.
Pete.
Edited by Downwind 2015-04-14
Eugeneo
Posted: 07:09pm 13 Apr 2015
Hi Pete,
I'll dig up the photos and post them up when I get a chance. The particular model would probably be a couple years old now but I will get a model number just in case they have it for sale.
I can only assume that the other Corsair supplies would all use the same type of topology for the feedback circuit. Basically it's really simple. you will need to find the TL431. It's a TO-92 package with three terminals.
The Anode was connected to the ground.
The Cathode is connected to a resistor then to the input side of a optical isolator (4 pin dip).
The reference is connected to a 2 resistor divider.
All you have to do is put the pot and resistor between the high side of the 2 resistor divider and you have voltage control.
I used a 50K ohm pot with an inline 10K resistor.
To make sure you are soldering the connections in the right place, you can measure the reference to Anode and it should be very close to 2.5V
WARNING: Be VERY careful when you do this. The high side DC voltage can be 170 to 400 VDC depending on what your AC input is.
There's a stand-up module that controls the PWM to the fan based on temperature and current load / overcurrent trip / power on input (green wire).
You need to disable the overcurrent trip by cutting the trace.
I'll try to post the rest soon.
Later,
Edited by Eugeneo 2015-04-15
Posted: 12:37am 14 Apr 2015
Eugeneo,
Thanks for the reply, it do sound rather simple to make the mod.
Im not your average beginner in electronics, but there is others that my follow your information so you do need to cover all bases.
i look forward to more detailed info, as i can see a huge use for cheap power supplies, for example increasing the voltage on my CNC mill.
Pete.
Eugeneo
Posted: 02:53pm 14 Apr 2015
Wow, I don't remember it being this complicated!
Completion
PCB
Bring out a Green wire
Bring out a White wire
Bring out a Black wire from any ground
Bring out a Red wire from the +12 volt rail
Solder these if you want the over current protection disabled (optional)
The connections to the pot. These resistors values will give you about 3.5V to 15V output
Use this circuit if you want to current limit using VR2 from 1.48A to 50A
Good luck!
Edited by Eugeneo 2015-04-16
Posted: 03:33am 15 Apr 2015
Hi Eugeneo,
All looks rather simple, and if i can find the right PSU here i will have a go at the mod.
Thanks for the info thus far.
Pete.
Eugeneo
Posted: 08:09pm 15 Apr 2015
Hi Pete,
You're welcome, this was a fun one.
Let me know how you make out and give me a shout if you run into any problems.
