Forum Index : Electronics : fisher&paykel
PlanetPresident
Posted: 08:12pm 02 Nov 2013
How can I get the f&p motor to run as a motor? I've tried using a Variable Frequency Drive to control the motor, it was a 120vac single phase to 240vac 3 phase controller, that didn't work, ran very slowly couldn't get it to run fast I'd like to use the motor as a prime mover. how can I make this work?
Tinker
Posted: 02:46am 03 Nov 2013
You could try using the electronic board that was in the washing machine your F&P came from.
You might have to modify the washing program or figure out how the board drives the motor.
That way your motor gets the drive it was designed for. Reverse engineering that looks like a lot of work for questionable gain to me.
Klaus
PlanetPresident
Posted: 08:56am 03 Nov 2013
I have several of these motors, I made a wind turbine out of one and due to there compact size and power it be nice to use as a motor to power other things. I'd hate to see them go to waste, I like to reuse, recycle and repurpose. I don't have the electrical training to reverse engineer the control board that came with the washer. maybe I can find someone close to me that can, but thanks for your input! oh yea I tried using the board that came with the unit, but the timing circuit won't let it run continuously.Edited by PlanetPresident 2013-11-04
Posted: 12:35pm 03 Nov 2013
Using the F&P as a motor is difficult and in my opinion not worth the effort. You need some fancy electronics and the end result isn't that great. There was an article in Silicon Chip magazine February 2012 about a motor controller that would drive the F&P, it was a commercial unit and worth about $100 from memory.
You could experiment with a brushless motor controller, like those used for remote control aircraft these days.
PlanetPresident
Posted: 11:07am 04 Nov 2013
That was just what I was looking for thank you very much, now I can move forward with a couple of my ideas thanks again.
